Question about Sharp Viewcam VL-A10U Camcorder
Can I "audio dub" onto my Viewcam? - Sharp Viewcam VL-A10U Camcorder
    Master:
  • 425 Answers
No. The audio and video signals are recorded on the same track, thus not allowing audio dubbing to be possible on our 8 millimeter Viewcam.
Posted on Sep 07, 2005
Has stopped Dubbing onto discs
Try spraying it with pressurized air. Perhaps it needs to be cleaned internally.
Nov 27, 2013 | RCA DRC247N DVD Player
Recorded onto my lg rh397d/rh399d, want to copy to dvd
You need to read page 37 "Dubbing a title"
Select the title you want to record and select the Dubbing option.
Apr 06, 2009 | LG Televison & Video
I can record to the HDD on my LG HR902TA but I can't understand the instructions to get the copy onto a DVD to finialise and use in another DVD player. Thanks Angie
I found the info for this from a friend saying, instead of 'copy' I should see if anything related to 'Dubbing', by following the instructions for dubbing I was able to copy the programme onto a DVD then finalise it for watching in another DVD player elsewhere in the house.I thought if you dubbed something you over wrote the original sound.
Jun 30, 2008 | LG Televison & Video
Transferring VHS-C tapes from a Panasonic NV-RX14B to my PC
Search Ebay for peripherals to transfer tape to PC - they come with all leads and software.
Mar 28, 2017 | Panasonic NV-VZ14 VHS-C Analog Camcorder
Dr-mh30s. stops dubbing after a few minutes.
I seem to have sorted this problem for me simply by unplugging power.
I actually left it for nearly a week before plugging in again, but I'm sure a day would do, probably less.
Dubbed 2 playlists since, no problem.
Nice simple solution if it works.
Feb 22, 2008 | JVC DR-MH30S DVD Recorder
Sherwood RD-6500 sound problem
I don't have this particular reciever, but I think the dubbing feature mentioned can be turned off. If that can't be done I suggest moving the components in video and audio 2 to the 3rd available one, it shouldn't have that feature. That's all I can offer.
Jul 18, 2007 | Sherwood RD-6500 Receiver
Can I record from my Viewcam onto a VHS cassette?
Yes you can! The most important step when dubbing from 8 millimeter to VHS, is setting the VCR that the unit is being hooked to, to the Auxiliary Mode. We suggest consulting the operator manual for your VCR for the instructions on how to set that.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Can an adaptor be used to play my 8mm tape in my VHS VCR?
With the Sharp Viewcam ®, there's no need to use an adaptor to play 8 mm tape. Simply connect the Viewcam ® to the TV or VCR for playback. You can even use your VCR to make a copy onto VHS tape.
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sharp Viewcam VL-A10U Camcorder Logo
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
