Question about HP iPAQ HX4700 Pocket PC
Ipaq stuck on blue and white screen
Thanks much for the possible solution, I'm going to pick up a new memory card and try to download it off of that since my Ipaq will not sync. Unless you have an easier way to do it. When I insert the memory card into the Ipaq will it automaticly start to boot or do I need to do anything to it. Thanks again for your assistance.
SSG Casper
  • lacasper Aug 28, 2008
    Thanks a million for the tip it worked like a charm on my older dell with xp. now i just have to find my disk with my powerpoint on it and I'll be rollin, Thanks again.
    SSG Casper
Not sure about the memory card way, active sync didn't work on mine either and from what I read it won't but my machine automatically sync'd on starting the sp29841 application file I downloaded from the HP site (the sync can take a while). Active sync didn't start to work again until it was restored through that (up to that the PC didn't recognise the ipaq as connected either). Hope you get it sorted.
Stevie
Posted on Aug 28, 2008
HP Ipaq h1940 won't sync with Vista
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx). When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
Jun 01, 2009 | HP iPAQ H1940 Pocket PC
HP ipaq with navtec gps software and sd card fails
Ok, nice job Robert,
I'm posting your solution here to remove it from the unsolved problems list.
Solution by Robert:
This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
Jun 22, 2008 | HP iPAQ H5550 Pocket PC
Ipaq rz1710
just format your memory srtick w/ the PDA and / or computer.
May 18, 2008 | Motorola Mobility A1200
HP ipaq rx3715
Have you tried other SD cards?  The box is uncheck for default install folder?  Maybe update the device.
Oct 13, 2007 | HP iPAQ RX3715 Pocket PC
Sync Files in Memory Card
Have a look at MightySync.... http://www.mydocsunlimited.com/html/mightysync.html
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
Today wallpaper
The screen size is 240x240 so you will need to reduce your picture to that size. You can put the pictures on the storage card, or other storage and then you can go into the your today screen settings and pick the storage area with the pictures in it.
Sep 08, 2005 | HP iPAQ hw6500 Pocket PC
Backing up to memory Card
On the opening screen of iPaq Backup there's a line, "File," where the backup's filename appears, and a little box with 3 dots. Tap that little box and you'll get a menu allowing you to set the location.
Sep 07, 2005 | HP iPAQ H1945 Pocket PC
Storage Memory
memory card isn't really memory it's more like a disk drive. it's not like when you add memory to a PC and the new memory is automatically used. To make use of this card you need to transfer some of your larger files to the card.... You can move files from within the ipaq... Click and hold on file. Select Copy Click and hold Select Cut Navigate with File Explorer to the SD card.... Open File Explorer Select My device Now select SD Card You can create a new folder or select an existing folder Click on Edit at bottom of screeen. Select Paste. You can also move files directly from PC to Storage card...... While IPAQ is connected, go to My Computer, then double-click on Mobile Device, then double-click on Pocket PC. Now you will see your Storage Card, and you can use this just like a folder on your PC. You can create folders within it. You can click and drag files to it or to any of it's folders.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
HP iPAQ HW6515 and SIM Card
There is a SIM manager , you can go there to download all your SIM contact to Ipaq address book.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ HX4700 Pocket PC Logo
367 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
