Question about Miele T4423 Dryer
Runs but does not spin
MIele T4423: Runs all ok, but doesn't turn around, does make noise though, gets warm. Top is dry bottom still wet...
  • patje_me Aug 27, 2008
    Thanks! Hope This'll work
  • Miele Master
  • 5,568 Answers
If it still makes noise, the motor is probably OK and only a belt has failed.
Removing any access panel will probably confirm this.
Look for shredded fragments of a belt and empty pullies.
This shouldn't be an expensive fix.
Posted on Aug 27, 2008
My miele wt945s takes in some water after final spin so clothes at bottom of the drum end up wet. Can I stop this happening
There is a problem with the programming of the control board if this is occurring.
All you can do is turn off the water to the machine at the end of the full cycle and then run the spin cycle again to dry out the clothes. Then no water can enter the wash drum.
Otherwise you would need to turn off the water each time before the spin cycle concluded and thus before the machine began adding water again.
Dec 08, 2015 | Miele Washing Machines
Where can I get a service manual for dryer Miele softronic T 4422 C
Manual is normally hidden inside the case, either bottom right, or inside the console at the top.
Make sure all the vents and pipes to outside are clear of lint and obstruction.
Jul 28, 2015 | Miele Dryers
Why does my new dishwasher not dry dishes completely?undefined
Mieles do not have a drying element - this is a big energy saver. They save heat from washing and use that to dry the dishes. Sometimes they will not be quite bone dry at the end of the cycle, but most will be dry if you open the door for a little while to let air circulate.
If your vent (port on the front) is blocked then the machine will not be able to blow out the damp air, and you will have wet dishes as you describe. If you have leaking from that port, then check my answers on "the Miele problem" which I am pasting below.
You have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is an idiotic problem that Miele should have a permanent fix for. Grrrr.
The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk.muck and slop.
Doggone design sucks on an otherwise nice machine!!
Sep 29, 2014 | Miele Dishwashers
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Drying cycle - laundry comes out wet!
possibly that drain pump is not pumping out - washer dryers take in water during the dry cycle. check filter
Mar 17, 2007 | Bosch Classixx WVF 240S Front Load Washer...
Miele T4423 Dryer Logo
103 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
