Question about Pioneer VSX-D608 Receiver
Output problem - i think
We have a VSX-D608 receiver and at the moment we only have two speakers hooked up to the 'A' speaker channel. We used it for a function recently and it must have been on for a party for around 10 or so hours and it was working perfectly. It blanked out at some point and only the tweeters were putting sound out (and it sounded tinny) - nothing from the woofers.
I assumed that it got to hot and that it needed a cool off. So after around 12 or so hours of not using it, I went back to the receiver and tried using it again - same problem. When I put my ears up to the speakers, there is absolutely no sound from the woofers from either loudspeaker, and the tweeters on both speakers are only putting out a really 'tinny' sound.
I changed the loudspeaker wiring over so that it now comes out of 'B' speaker channel - same issue.
Is this likely to be a problem with the receiver itself? If so, what is a possible solution? if not, is it likely that both loudspeakers 'went' at the same time?
  • 4,234 Answers
Based upon your description, I would suspect the speakers not the receiver. Typically, if the receiver was bad, there would be no sound at all. If the front end of the receiver was bad, this symptom could happen, but that is a rare problem. Can you try a different set of speakers? A or B won't make a difference from the receiver. Pleaes try another speaker set and update this with the results and we'll continue on from there.
Thanks,
Dan
Posted on Aug 27, 2008
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Only my left and right speakers work - they are all connected
you probably hit a button saying 2 CH or 2 Channel which cuts out the other speakers. find a button that says dolby Digital or the surround button
Aug 06, 2009 | Pioneer VSX-D608 Receiver
VSX-D608 Overload and shutdown
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Jun 22, 2009 | Pioneer VSX-D608 Receiver
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
Pioneer VSX-D308 Receiver Problem
go through your mode channels to put it on surround sound
Jun 09, 2008 | Pioneer VSX-D308 Receiver
Subwoofer
Depends on what you have it hooked up to. Check wiring and controls if it is self powered. Check receiver/amp to see if it is outputting to subw.
Apr 12, 2008 | Pioneer VSX-D608 Receiver
Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Dec 04, 2007 | Pioneer VSX-D608 Receiver
Pioneer VSX-D608 Receiver Logo
108 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
