Question about Sharp Viewcam VL-A10U Camcorder
I do not get the estimated amount of recording time from my battery.
    Master:
  • 425 Answers
All battery times are estimates. Maximum battery time will be achieved by less frequent use of zoom, digital circuits and auto focus. We recommend following the instructions in your operator manual for proper recharging procedures for your battery.
Posted on Sep 07, 2005
SOURCE:
During recording, how do I know how many minutes left on the CD?
If you have determined the total playing time, you can use a separate countdown timer such as the kind used for kitchen cooking to estimate remaining record time. I have found this to be a useful recording accessory, along with a stopwatch.
Jan 31, 2016 | Audio Players & Recorders
How do I calculate the amount of paint needed for walls in a 12 foot by 16 foot room with 8 foot ceilings?
Ceiling paint estimator
Use the following formula to estimate the amount of ceiling paint you need. Double the result if the ceiling requires two coats.
1. Multiply the length of the ceiling times its width to find its area.
14 × 20 = 280 square feet
2. Divide that number by 350 (the estimated square feet covered per gallon) to figure out how many gallons of paint you need.
280 ÷ 350 = .8
For this example, you want to buy 1 gallon of ceiling paint for a single coat.
Wall paint estimator
Use the following formula to estimate the amount of wall paint you need. Double the result if the walls require two coats.
Feb 18, 2015 | Tools & Hardware - Others
What does os on battery mean
Dear,
User...os on battery mean.
For this reason, the capacity values and remaining run times displayed by OS X and Battery Monitor are estimates based on previously made observations, recorded by the charge processor inside the battery unit. The capacity reading and the resulting runtime are as exact as possible if the charge processor could observe a complete discharge/charge cycle a short time before.
Thanks..
Dec 27, 2012 | ASUS Transformer Pad TF300T-DOCK-BL Mobile...
I added the wrong starting cash.and would like to know how to change it to the right amount
Changing the starting cash drawer count is not a simple procedure. You can clock the employee out. When asked for the drawer count, ignore what is in drawer and enter the incorrect starting amount. Then clock the employee back in and enter the correct starting amount.
If you wish to tidy up the records, go into time management and delete the first clockin record. Then edit the starting time of the second clockin to match the first record that you deleted.
B Mattern
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
Dec 24, 2010 | Pc America Restaurant Pro Express
What are the differences in the record modes? (HQ, SP, & LP)
The amount of recording time on a disc depends on the recording mode selected. The approximate recording time for each of these modes is listed below:
  • HQ (High Quality): Recordable time is up to 20 minutes.
  • SP (Standard Play): Recordable time is up to 30 minutes.
  • LP (Long Play): Recordable time is up to 60 minutes.
  • NOTE: If you record in LP mode, the quality of the scenes may be degraded, or scenes with quick movement may appear with a block noise when you play back the disc.
    Jul 08, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
    Keyless Remote entry is not working properly. I think it needs a battery. Do I get one from the dealer.... estimate amount??
    Anywhere that sells Duracell batteries such as a hardware store should be able to mach it. Approx cost 6-10 dollars. Hope this helps
    May 05, 2009 | 2005 Lexus ES330
    Yes i have an ONKYO TX-SV70PRO that i think just blew the amp.i need to know if it's fixable{i mean parts available} and a guess as to what the cost might be.
    Yes it is fixable, the parts are available. The cost can vary, depending on the rates of the shop you take it to and the actual amount of damage that it has.
    On average, a blown channel in a receiver will cost anywhere between $120 and $200, most of which are around the middle of that amount. I would expect to pay about $150. This is a very good receiver and is well worth the repair cost in most cases. Almost all service centers will give you an estimate before you commit to paying for a repair. If it is a free estimate, it is usually just a free guess. A paid estimate is always more accurate and will normally save you money in the long run. The reason for that is, if a shop owner gives a free estimate he is not going to have one of his technicians look at it and troubleshoot it. If you refuse the estimate he still must pay his technician if the technician has looked at it. A paid estimate will ensure the lowest cost because it will be more accurate. Free estimates are almost always a higher estimate to make sure they can cover the cost no matter what is wrong. Even if they find something small, they will usually charge you the full estimate that you have approved already. With a paid estimate they do not want to loose the job after committing the technicians time to find out what is wrong. Figuring out what is wrong is more than half the battle. Sometimes a technician must actually fix the problem completely just to be sure there is nothing else wrong and that the estimate will be good. Nobody likes to get an estimate and approve it, then a day or two later get a new estimate because they found something else wrong that they could not detect until the other part of the problem was fixed. It happens all the time, I have been a technician for over 18 years and have seen just about everything. The bottom line is, a paid estimate is better than a free estimate. Plus, when you pay for an estimate the shop will apply that payment towards the total repair cost, so in the end it is a free estimate if you get the unit fixed.
    Dave
    Nov 11, 2008 | Onkyo Audio Players & Recorders
    Recording Late
    Check your automatic clock setting. If it is on automatic, set it to manual, and set the date and time on the recorder. It may be picking up an unreliable time setting from a station that is not too accurate.
    tom
    Aug 26, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
    Battery pack for Canon ZR100 digital videocassette camcorder
    For good spare canon nb-2lh battery,or cheap replacement canon nb-2lh digital camera battery,you can search and searh to find a famed relible camera camcorder batteries store with chargers on sale,shopping online convenient and cheap !
    Jun 25, 2008 | Canon ZR100 Mini DV Digital Camcorder
    Sharp Viewcam VL-A10U Camcorder Logo
    Top Sharp Video Cameras Experts
    Marvin
    Marvin
    abdul rauf
    abdul rauf
    Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
