Question about Epson Expression 1680 Flatbed Scanner
Having trouble with getting this scanner working on a new laptop with either firewire or usb.  Have downloaded and reinstalled drivers but Epson Scan just doesn't go anywhere and says check connection.  IT shows up in System Profiler.  Any ideas?
my email is jalayne@conpoint.com
    Genius:
  • 1,447 Answers
Hi-
Do you have any existing drivers for new epson scanners( models), if you have then there are compatibility issues between new drivers and old drivers, are you using a leopard 10.5 operating system or tiger 10.4.**? try uninstalling every epson info from applications folder and from library/image capture and library/preferences. you an use the finder to search for epson scan and drg them all to trash. Try using image capture application as well if it will scan when you run it, then reinstall driver.
One more thing, when you click on epson scan, does it bounce continouosly from the dock? if it is then look for a subfolder and install everything in it.
Keep me posted, thanks!
Posted on Sep 02, 2008
I have an Epson expression 1680 with the latest drivers and a usb hook-up to my Windows 7 computer. I can scan, the computer recognizes everything but I cannot get it to work to copy film...it won't let me...
Hi, most if not all scanners don't work when you try to use it on film. Usually, the only way for you to scan film or transparencies is you have to buy an accessory for the scanner called a "transparency unit" which does not come installed with your scanner when you buy it. Unless your scanner says that it came with that accessory then you won't be able to scan films or transparencies at all.
Feb 05, 2018 | Epson Expression1680 Professional Desktop...
During preview and scan unit will freeze up and I have to restart the computer
try to just let it chill maybe its to hot wait about 10 minutes then try again
Apr 22, 2010 | Epson Expression 1680 Professional Flatbed...
Fuzzy scanned image from Epson Expression 10000XL scanner
Make sure that the item being scanned is lying flat against the scanner's glass. If the scanned image is still fuzzy after adjusting the object, clean the scanner glass with a lint-free cloth and some vinegar or ammonia-free window cleaner.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Apr 10, 2010 | Epson Scanner Expression 10000xl Pro A3+...
SORRY MAY BE A BLONDE QUESTION
well now there's something i've never tried.... i would suppose you can but they will likely turn out like... well negatives
Robert
Feb 17, 2009 | Epson Expression 1680 Flatbed Scanner
Door/Hinge is very tight, have to push down hard when scanning
Remove the transparency unit from the scanner. Then carefully remove the six screws holding the hinge. Use WD 40 to lubricate hinge.
Jan 13, 2009 | Epson Expression 1680 Professional Flatbed...
Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Nov 28, 2008 | Epson Expression 1680 Professional Flatbed...
Scanner won't turn on
Try to test the power cord of the scanner (cable from scanner to outlet) using multitester if there is an electricity or if you have extra power cord test it. Maybe that's the defect. If that's not the problem it is now the scanner itself, have it for the repair man or technician.
Thanks
Nov 19, 2008 | Epson Expression 10000XL Flatbed Scanner
Communication with scanner
You could take it apart and see if you can lubricate the shaft the the scanner sits on with some vasoline. If that doesn't it could be that the stepper motor that controls the scanner is going bad in it.
Jul 18, 2008 | Epson Expression 1680 Professional Flatbed...
Error message on Epson 1640 XL scanner
try to fix the usb cable or just replace it and reinstall the drive software disk. bye.
Sep 28, 2007 | Epson Expression 1640XL Pro Flatbed...
Epson Expression 1680 Flatbed Scanner Logo
141 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
