Question about Sport & Outdoor - Others
Pool about to overflow
8 inches of rain have caused pool water to rise. how do i get rid of the excess water? new homeowner with pool with no operating manual. the pool has turned green with algae. please help
    Problem Solver:
  • 5 Answers
Syphon it (see link). It will be easier if it is an above ground pool.
http://en.wikipedia.org/wiki/Syphon
Posted on Dec 02, 2008
Can the pool overflow from rain?
A pool will over flow in the rain, the pool pump is only for circulating water not for draining overflow , you can go to a local pool supply and buy a pump to hook to a garden hose and drain it partially, be aware that the pump runs on electric power and you want to be careful not to drain the pool below the skimmer level or you will end up replacing the pool pump motor
Dec 11, 2014 | Jandy Pool & Spa
Tip
How to measure rain fall when your rain gauge overflows
Most rain gauges that you will make at home will only measure up to one inch of rain fall. The problem with this is that if you live in a place where you will get more than one inch of rain your measurement if taken incorrectly will be very skewed. If your rain gauge has been constructed correctly you should have a fail safe in place.
When you construct a rain gauge you should have a measuring tube inside of an over flow tube. The meausuring tube will hold about one inch of rain fall, but when more rain falls the inside tube will overflow into the outer tube. To measure the excess rain fall you will follow a few simple steps.
Start by reading the inner tube of the rain gauge and then carefully empty the tube. Make sure that you don't pour out the water that has overflowed into the outer tube.
Once all the water for the measuring tube has been emptied carefully pour the excess rain water into the measuring tube. To get the most accurate reading try your best to not spill any water out, you can pour the water over a bucket to make sure that if you do spill any out you will catch it and be able to measure accurately.
If there is a lot of overflow you might want to measure a little bit of overflow at a time to get an accurate read. As you measure, write down the measurements and when you finish add up the values to get the reading.
The readings are done in inches so you have a reading that is 1.00 and has an overflow that measures up to .50 then the total read out will 1.50 inches.
on Feb 02, 2014 | Garden
Tip
FREEZING CONDITIONS IN ARIZONA MAY CAUSE DAMAGE TO UNSUSPECTING POOL OWNERS
<p>February 3rd, 2011 - Peoria, Arizona<br /> <p> <br /> <p>With the inevitable freezing conditions about to sweep Arizona, unaware homeowners may feel the financial impact of these colder conditions.<br /> <p> <br /> <p>"Arizona pool owners are prepared for excessive heat, heavy monsoon rains, and extreme wind with ownership of their swimming pool, but what they are not prepared for can cost them,"<span> said Brian Morris, of WeFixUglyPools.com</span> . "Taking minor precautionary steps during colder temperatures will save a lot of aggravation, and money."<br /> <p> <br /> <p>The National Weather Service has issued freeze warnings for Maricopa County that will remain in effect from 11 PM this evening until 10 AM Thursday morning. <br /> <p> <br /> <p>Potential damages to swimming pools include: underground pipe breakages, filter cracking, damage to salt systems, pool pumps, and valves, and potential flooding of backyards due to the damages. <br /> <p> <br /> <p>"I have actually witnessed running fountains freezing today, and that is something that I have never before witnessed," continues Brian. "To believe that it will be this cold is cause for concern because most people just do not know how to prepare for this kind of weather."<br /> <p> <br /> <p>"It's important that people be made aware of these hazards," Phoenix Resident Angela Clipper noted. "There could really be some serious damages."<br /> <p> <br /> <p>We Fix Ugly Pools has also been experiencing even colder weather at its locations in Dallas / Fort Worth, with more than 150 calls flooding their office between 8 - 9 AM this morning. Rolling blackouts in the DFW area has caused additional damage to pool equipment that was being operated accordingly to the weather. With the 30-45 minute blackouts, pool equipment damage became inevitable. The financial impact to homeowners there is already in the thousands of dollars and it is expected to have an even greater impact in the Phoenix and Tucson areas as most homeowners are just not aware of how to handle this kind of weather.<br /> <p> <br /> <p> <br /> <p> <br /> <p>For more information<span>, </span>contact Brian Morris at 602-253-4499. You may also receive a quick response by emailing: info<a href="mailto:brian@wefixuglypools.com">@wefixuglypools.com</a>.<br />
on Feb 03, 2011 | Pool & Spa
Whenever it rain, water gets into the floor on the
A leaking windscreen,door seal or window seal. Run a garden hose over your car and use baby powder to pin point where the water is in running from.
Apr 20, 2010 | 2006 Ford Taurus
Water draining as it is filling
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 29, 2009 | Kenmore Washing Machines
Washer is filling up to wash but water goes out of tub before
Mar 16, 2009 | Washing Machines
Kenmore washer 23801-loses water during wash/rinse cycle before cycle completes
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as “siphoning”. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
Mar 12, 2009 | Kenmore Washing Machines
Kenmore elite clothes washer model 22952
Feb 01, 2009 | Kenmore 22422 Top Load Washer
Hot water comes, but does not fill the Washer, and therefore does not rotate the tumbler. It is a Maytag commercial washer
Jan 28, 2009 | Washing Machines
I have a zanussi fl828 it has dirty water coming in and the drum wont turn when in cycle
Jan 22, 2009 | Washing Machines
Sport & Outdoor - Others Logo
147 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
