Outside unit compressor vibrating loudly and fan not functioning
Replace fan motor and capicator (the little silver can with the same manufactures specs.. before it locks the compressor up> Call the co. to see if its still under warranty. Thank-you-very-much!
Posted on Aug 27, 2008
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
My 3 year old Viking refrigerator starting making really loud noises today...what can I do avoid a repair bill???
If the loud noises sound like a fan blade hitting ice you have a defrosting problem.
You can try unpluging the unit removing the contents then doing a manual defrost with a fan blowing into the unit for a bit over 2 hours then restarting the unit to see if the noise has ceased.
If it is a noise associated with the compressor you can try pushing it gently in it's floating mounts to try and reposition the unit so the vibration absorbers are functioning properly again.
Lastly if it is the condensor fan making noises break out the crevice tool and remove the lint from the coils. If you have pets this is very important.
Sadly if the problem repeats in less than a week after doing the above the dreaded serviceman / repair visit will be required to islolate the cause or source.
Vikings' website:
http://www.vikingrange.com/consumer/footer/contact_us.jsp?id=cat50013
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Viking 42 in Built In Professional...
On tempstar heatpump the outside fan makes a loud noise
Well, that could mean a lage list of problems from which to choose, 1st I suggest you isolate the fan to be sure it is the problem; Hopefully you have an outside disconnect box for the unit, stop the power at this discoonnect and wait 3 minutes. Place a large stick or metal bar throught the topgrill to hold back the fan blade from turning. Now connect the energy at the disco box ( you may want a second person so you can hold the stick in place). You will not harm anything by holding the fan from turning for a short time. If you hear the noise that you suspect after the unit runs for 20 seconds, then the problem is most likely the compressor. If you do not hear the noise, then remove the stick and aloow the fan to turn. You at this point should be able to see if the blade is clangging, or the blade is imbalanced and vibrating, or the noise is coming from the fan motor itself. The most likely problem is the bearings of the fan motor are worn and the motor is screaching or laboring; in which case you need a new motor unless you are savy enough to replace the bearings in the motor (however, this is not always cost effective unless you really know your stuff). Check the blade for fatigue fractures in the metal and check the mounting points that hold the motor in place-----sometimes these mounting points also fatigue after years of vibrating and need to be reinforced with oversize washers or the entire top grill piece needs to be replaced if the cracks are too severe. Goodluck, Macgivor
Jan 02, 2010 | Ruud Central System Air Conditioner
Loud vibration
If it is a frost free check the fan inside. The fans can have bearing failure after a few years thus causing the vibration. Also the compressor underneath is mounted on rubber vibration dampers and if one of these rubber mounts fail then the compressor will start vibrating against the refrigerator frame causing a loud vibration. If none of these apply gently press on the side and front panel of the refrigerator to try and locate the source of the vibration as any where metal is vibrating against metal the side and front panel act as a sounding board amplifying the sound. If you cant locate the vibration then you may have a more serious problem and may need to call a technician.
Oct 09, 2009 | Roper Refrigerators
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Refrigerator Compressor has loud vibration
Clean the coils. what you are hearing is the valves as the pressure equqlizes. Also make sure that the fan by compressor is on while compressor is running.
Mar 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
A/c compressor
observe where the noise could be coming from, it could be from the fan or from the compressor.
it could also be just a loose metal vibrating.
if it is still cooling, then it could definitely be just a loose metal housing or bracket.
hold onto it and feel if the noise would disappear.
tighten all loose screws and bolts. replace the screws if necessary.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Heating & Cooling
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Loud as Hell
Is it installed in a window? Check to make sure it is installed correctly. usually there is a felt or foam strip that is used to dampen vibration when you place it in the window. It also acts as seal to keep outside air and bugs out. If you place your hand at various locations on the unit does the sound go away? If it does then you know it is a vibration problem. Just add new foam or re-adjust the foam or gasketing it already has. If that doesn't work then try to locate the source of the noise. Use a mechanics stethoscope or even a cardboard tube from paper towels will work. Once you have located the source then you can tell the store what the problem is when you take it back and get a new one. Cheap air conditioners are noisy. Some more than others, it's why they are cheap. But your problem does sound like it could be a product issue.
Sep 25, 2007 | Haier Mechanical Air Conditioner HWF05XC7
Heating & Cooling Logo
316 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
