Question about Mk Diamond 5.3 amp Tile Saw
Tile Saw Troubleshooting
My Mk Diamond 5.3 tile saw started to crack the tiles, the cut is not clean, it chips there edges.
Any Ideas?
  • 29 Answers
If your blade is newer or even well used,one way to make it cut better is find a used brick or a piece of a concrete block and cut through them,what really works best is a carborundum stone that setters use to hone cut edges of tile,you can get 1 at any tile store or home depot for 5 bucks. another trick is to lightly pull up on the table towards end of cut, if they keep breaking at end of cut, and you have the gauge set simply flip tile up side down and start your cut then back it off flip it over and cut through. all saw cuts leave minor chips on cut edge, we always stone cuts. cutting a brick cleans debris off blade. MAKE SURE WATER IS PRESENT WHEN CUTTING
Posted on Mar 31, 2009
  • 25 Answers
Options, change the blade, buy a more expensive blade, make sure the blade turns true when running, if not the armeture might bent inside the saw.
Posted on Sep 01, 2008
Easier way to cut glass wall tile
Easier than what? I use a diamond tile saw, and find that pretty easy.
Sep 11, 2014 | Saws
Cutting porcelain tile with wet saw and it breaks at the end of the cut?
Porcelain tile has to be cut painstakingly slow, especially the last inch or two to prevent the splitting problem you are having. When you are cutting tile, the sawblade rides up just a little as the tile is being fed into it. You'll notice it if you stop pushing the tile through and watch the head drop down just a bit. When you are getting to the last part of the cut, reduce the pressure you are using to push the tile into the blade so the blade can wear away the tile with little pressure and vibration as possible.
Dec 30, 2012 | Mk Diamond MK 370 TILE SAW
While checking the intake tube the power cord got on the wrong side of the cord so when I turned the saw on it cut the power cord. Can I get that replaced?
Yes, it will require that you "crack" the case, but it isn't that difficult to do. Suggest wire ties so that you don't have to do the replacement very often.
Jul 15, 2011 | Mk Diamond MK - 170 Wet Cutting Tile Saw
I am not sure I can be any clearer than to say the saw dooes not cut the tile square.
the problem is probably the slide cart you set tile on to push it into the blade,on the right side theres a roller you can adjust the the height of the tray,or look at the very bottom of the cutting arm,left hand side,on the outside,where its painted red, theres 2 bolts that hold the cutting arm to the frame of the saw body,try this first, i bet nuts got loose and the cutting arm dropped a tiny bit screwing everything up
Dec 28, 2010 | Mk Diamond Mk Tile Saw Mk-101 Pro24 10in
How do you remove the blade on tile cutter model mk470 mk diamond products, inc
Unplug the saw, raise the guard fully, grasp the blade to hold it and loosen the nut then remove the blade.
Sep 12, 2009 | Mk Diamond Products, Inc. 7 In. Wet...
Tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Jul 11, 2009 | Mk Diamond MK - 101 Pro 24, 2hp Tile
Tile saw helping tools
On most of the tile project you will need: tile nippers, 1/4", 1/8" and 3/16" spacers, grout sponge, mixing tub, mixer and various trowels.
Aug 27, 2008 | Mk Diamond MK 101Pro Tile Saw
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
Mk Diamond 5.3 amp Tile Saw Logo
782 people viewed this question
Top Mk Diamond Saws Experts
Tom Chichester
ray gallant
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
