Question about GE XL1800 1100 Watts Microwave Oven
GE XL 1800 quit heating
This morning when warming up my cold cup of coffee my microwave made a little crackle noise, continued to run but did not heat up the coffee. The fan runs, it lights up, and turntable turns, but does not heat anything. Any ideas?
It is a:
GE Spacesaver XL 1800
Model #: JVM1851BH06
Mfg date: June 2006
  • Anonymous Mar 24, 2014
    when placing coffee cup to heat, the turntable starts to sqeak. The Sharp microwave is only about a year ol.
  • GE Master
  • 5,568 Answers
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Posted on Aug 27, 2008
We have a GE Spacemaker XL 1800 Microwave. There is dirt and moisture that has collected between the inside and outside glass. How can you clean this?
HELLO.
This is the solution to the cleaning issue.
1. Wipe the microwave inside and out with a soft cloth dampened with a warm, mild detergent solution. Rinse with a soft cloth dampened with plain water. Dry with a soft, dry cloth.
2. Put 2 cups of water into a 4-cup measuring cup. Place the measuring cup in the microwave, then heat on high for 5 minutes to loosen food particles that are stuck to the inside walls. Leave the measuring cup inside the microwave for 1 to 2 minutes, then remove and wipe the interior as in Step 2.
3. Remove the glass turntable and wash it in the sink with mild detergent or in the dishwasher. Handle carefully, as the turntable is breakable.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Heating the cup more than coffee
make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
Apr 30, 2010 | GE JVM1870 Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave quit heating. Could not warm a cup
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjjk
Oct 24, 2009 | Maytag MMC5000 Microwave Oven
Microwave GE XL 1800 Spacemaker Not Heating
have you check the fuses, maybe its open, orthe hv diode.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Wont heat food
It could be that the "grinding" noise was actually "arcing" taking place inside the cavity or uder the cover. The magnatron is possibly damaged or the h.v. diode. Should be repaired by qualified repairman
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
Jun 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 - Noise while heating
Maybe you and the person from the post below could get together and help each other? http://www.fixya.com/ThreadView.aspx?prdid=489218&thid=130453
Mar 25, 2007 | GE JVM1660 Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
395 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
