Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Tfh22prsb freezer coils freeze over ice builds up inside compartment
  • 90 Answers
SOURCE: Drain plugged in freezer
First of all, is it ice or frost? If it is ice, I would say you have a leaky water valve to icemaker, running down evap. coils. Replace water valve. If you have frost-find out why it is not defrosting(defrost heater, defrost thermostat, or defrost timer.
Posted on Jan 17, 2008
SOURCE: maytag side by side, bottom freezer compartment had daily ice build up
I had the same problem with mine a couple of months ago. There is a drain which gets plugged. You have to remove the contents of your freezer, and then look at the back area of the freezer. The panel that's on the back is removable. Once it's removed, you will see a drain at the bottom. Mine was clogged up with debris, and was covered with ice. I poured warm water over the drain, soaked it up...did this a few times to melt the ice, then I worked at cleaning out the drain. Mine wasn't plugged too badly, I ended up having to blow air through the drain using my air compressor, to be positive that it was clear of debris. You could poke something down the drain, but it won't go very far because there is an elbow on the drain tube(visible on the backside of the unit itself)
If you get it cleaned out, it should be fine. Mines been great ever since I cleaned mine more puddles on the floor.
Posted on Feb 18, 2008
  • 1462 Answers
SOURCE: Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Posted on Sep 25, 2008
  • 4070 Answers
SOURCE: GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 17, 2009
  • 48 Answers
SOURCE: Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Posted on Nov 13, 2009
Testimonial: "Many thanks for your help. The drain was blocked with ice as you suggested. "
GE Monogram won't freeze food
your evaporator coil in the rear area behind the panel is iced up and blocking fan air flow to the freezer compartment
Jul 25, 2010 | GE Refrigerators
Model No IK 458 -4-4T; Product No 925 780 652 02 Ser No 14100010. I get ice build-up on floor of fast freezer comp which jams pull-out basket.
If the defroster coil is not working, then ice will build up on the coils inside the back of the refrigerator.
But, you're saying that it's accumulating on the floor of the freezer jamming the pull out basket.
I would say that the timer or overflow valve is bad on this refrigerator causing ice to build up on the floor of the fast freezer compartment causing the jamming.
Jul 19, 2010 | Freezers
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
My freezer on my Frigidaire is not fully freezing?
Take the back panel off inside your freezer compartment and check to see if the defrost coils are frozen over. If they are, you can use a hair dryer to defrost them or just let it sit for a day with a fan blowing on them.
Sep 21, 2009 | Refrigerators
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
I have a roper model RT14ZKXDWOO and the freezer is working fine but the refrig is warm. I took the panel off the back of the freezer and it is full of ice. What should i do next? and is there a diagram...
Hi,maybe I can shed a little light.I don`t know where the defrost timer is,but I would melt the ice with a hair dryer and real warm water(it will make a mess so be ready).There will be a drain inside of the freezer compartment,on the inside.Some how the rear panel inside the freezer compartment comes out.You may have to take apart the whole inside of the freezer compartment just to remove this rear panel.But when you do look for ice build up on bottom of freezing unit,and the rearof the freezer compartment.Melt this ice the same way earlier described.You will find a drain that starts inside the bottom-rear of the freezer compartment.This drain goes all the way down to the bottom of the fridge.You will find a very shallow drip pan under the fridge.This pan will most of the time only receive a little amount of water at a time and evaporates quickly.Now while you thaw this drain,water will start draining threw the drain,if it is not stoped up with food particles and such.This would be a good tome to blow threw this ine from the bottom where it drains into the pan underneth the fridge.Then blow threw it at the top in the freezer compartment.You can use a air tank with a blow gun.Be sure to pour water threw and down this drain to wash out all particles left behind.Clean the freezer compartment out good(the particles of food and such) and reassemble the freezing unit.plug fridge back up and set the freezer control to a respectfull setting(not the coldest and not real cold)and set the frideration to a decent setting for food preservation. Let the fridge and freezer run 12 to 24 hours to see if your problem comes back,and then time will tell if your defrost timer is bad,or is working like it should.When the drain clogs,it starts freezing away from the defrost elements and continues freezing the blocked water untill it overtakes the coils .The defrost and the timer don`t stay on long enough,or hot enough to overcome the ice.This is the reason you should try this solution first.If I can help you anymore,let me know /let me know how it turns out
Jul 12, 2009 | Refrigerators
The freezer has ice build up on vents
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
also click the links below for more help
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge freezing
a defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Mar 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
