Question about HP Pavilion DV6500T Notebook
HARD DISC I bought one HP HP PAVILION DV6500T 15.4"... three months ago and now i have a problem. SMART FAILURE PREDICTED ON HARD DISC 2: SAMSUNG HM 250 JI - (S1) WARNING: IMMEDIATELY BACH-UP YOUR DATA AND REPLACE YOUR HARD DISC DRIVE. A FAILURE MT BE IMMINENT.
    Scholar:
  • 87 Answers
If you bought it new then back up any files and take it back to the shop. If it's a second hand unit then you need to immediately back up to disc or pen anything you want to save. You are being warned that there is an issue with your hard drive. If this fails then you will lose all your information and computer won't fire up until you fit a new hard drive and install an operating system (if you actually have one). Once you have safeguarded your files it might be worth checking if your laptop is running too hot, which can damage a hard drive, is the fan switching on. There are programs free to download that can test the temperature.
Posted on Aug 29, 2008
Smart failure predicted on hard disk repair
This means either your hard disk is about to fail or it already has in which case you will need to purchase a new HDD (hard disk drive) and then contact acer to purchase recovery disks or if it is still under warranty then contact for service.
Jul 19, 2014 | Acer Computers & Internet
I received the following error on my HP Pavilion laptop: SMART Failure Predicted on Hard Disk 4: WDC WD2500BEVS-60UST0-(S1) Warning: Immediately back-up your data and replace your hard disk drive. A...
SMART is used to measure your HDD health.It warns you of impending failure of your hard drive. If it goes down, it's a good idea to backup important stuff and prepare to replace the HDD.
S.M.A.R.T is an acronym for Self-Monitoring, Analysis and Reporting Technology systems (SMART) and it's usually built in to most modern ATA and SCSI hard disks.
If you need further assistance, feel free to ask. If this answers or solves your issue, please rate it. Thanks, Joe
Feb 09, 2011 | HP Computers & Internet
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
SMART failure predicted on hard disk 0:
There is a big problem with newer conponents and Win XP versions prior to SP2. Especially with newer motherboards.
You have to make a bootable SP2 disk if you don't already have one. To do this use the slipstream proceedure specified on the Ms website. Many other websites describe the process with easier language.
Slipstreaming is a common practice now. Essentially, you copy your original install disk to the c: drive then download SP2 to C: drive then download the slipstream utility from MS. Running the slipstream utility then inserts the proper drivers (ide and HD drivers too) into the licensed copy you have. You then create a bootable disk from the slipstreamed files you have.
This approach is resolving alot of blue STOP errors and SMART errors.
ALSO, you want to make sure you are installing any drivers provided by the MB manufacturer AND Drive maker.
Good Luck
Jul 29, 2009 | Computers & Internet
Smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
Feb 14, 2009 | HP Business Notebook NX9110 Notebook
SmaT FAILURE PREDICTED ON HARD DISC
okay you have seen that message simply because it did not detected any hard-disk. If you know how to open your computer all you have to do is press all the wires in there it maybe dew to loose connection. then try booting it up again be sure it has a system already. If still didn't work out no other solution but to replace the hard disk.
Dec 14, 2008 | Toshiba Satellite M30X Notebook
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
HP Pavilion DV6500T Notebook Logo
205 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
