Question about Dewalt DW744S 10" Portable Table Saw with Stand
Blade Height How can i know what is the best blade Height for my DW744S 10" table saw?
    Problem Solver:
  • 8 Answers
Basic saw safety dictates that the blade should barely clear the thickness of the material being sawed. This has saved my fingers more than once, Also, make sure you use a push stick for thin rips. They are a lot easier to replace than fingers, and are easily made from scrap stuff. As for the blade diameter, you want to use a 10" blade, but on occasion a smaller blade can be used, just be sure the arbor doesn't rub against the bottom of the table. Dado blades for 10" saws are usually only about 8" in diameter.
Posted on Oct 01, 2008
Severe vibration with Dewalt 744S Table Saw
try it with no blade
if you have unhabitual noise and vibration,probably need to change bearing
if you do not have a bearing puller do not try to do it yourself
professionals will take 2 to 3 times less time than you do the work and if there is something else damaged, (gear damaged,) he will see it and inform you
Sep 22, 2012 | Dewalt DW744S 10" Portable Table Saw with...
Blade is slightly closer to fence in back causing the material to kick back.
Hi Ken,
Sounds like you need to to adjust your fence.I use the blade from a combination square.Place the steel blade next to the saw blade(between the carbide teeth).Next loosen the fence lock,loosen the two hex bolts on the rear pinion assembly so that the fence can move side to side.Move the fence up to the combo blade and adjust the fence and lock the fence lock.Check for blade and fence for true.Tighten the hex bolts at the rear pinion bearing assembly. Thank You for choosing FixYa.com.
http://service.dewalt.co.uk/PDMSDocuments/EU/Docs//docpdf/dw744t2_xe.pdf
Jun 22, 2011 | Dewalt DW744S 10" Portable Table Saw with...
I am getting very bad kickback about 3/4 the way through my cuts. I have a new blade on the saw. I dont really know how to troubleshoot this.
Possible that the fence you are using is not on a true parallel line with the blade and as a result it is causing the wood to pull into the blade causing kickback. I would do an alignment procedure on the fence to make it as true to the blade as possible.
Sep 11, 2010 | Dewalt DW744S 10" Portable Table Saw with...
How to change mitre saw blades
you need to remove the "throat" plate and raise the blade fully. UNPLUG SAW FIRST there are 2 wrenches on the side one for the hex nut and the other for the arbor, the threads are standard. let me know if you need more assistance
Aug 25, 2010 | Dewalt DW744S 10" Portable Table Saw with...
I have a Dewalt model 7730 radial arm saw. When the on button is pushed the motor starts off real slow as if it is under a bind or load but after a few seconds it picks up speed and seems to turn at full...
most probably it is bit of timber on the bottom of the saw assembly...
1. switch off the saw
2. remove power plug
3. remove screw and clear protector assembly
4. remove centre panel (as to changing the blade)
5. remove blade and clean dust furrow below it from all debris
6. re-assemble in reverse order
7. mount safety protector assembly
7, connect power cord
8. start in shor burst and switch immediatelly off, after blade stop spinning, check blade assembly if not wobbly.
this should solve your problem.
if you find this advice useful, please do not hesitate to leave comment and give me your vote4 fo rme, thanx!
Aug 02, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
Jul 18, 2010 | Dewalt DW744S 10" Portable Table Saw with...
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
Cutting 45's on my Dewalt 744
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
Feb 28, 2010 | Dewalt DW744S 10" Portable Table Saw with...
The blade vibrates up or down after I set the height.
does this saw need an insert for the blade hole diameter or is the blade center hole too large for the spindle, that and make sure the flanges are on correctly and tightened.
Oct 31, 2009 | Jet JPS-10 ProShop Table Saw
How to set fence square to blade
dfowl:
Try this first:
http://www.makita.com/en-us/Assets/images/Products/2703X1/owners_manuals/2703.pdf
Jan 27, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Dewalt DW744S 10" Portable Table Saw with Stand Logo
165 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
