Question about Saeco Aroma Espresso Machine
Primary on off switch won't turn on
The switch is not stuck mechanically but does not light up. I was using it just prior and I then cleaned the steam spout without shutting it off and returned to the machine to use it again and the lights were off and now will not turn on again. Is there a safety switch incorporated? I would love a coffee right now. Thanks
  • rgroove Aug 31, 2008
    I turned on the machine this morning to make a coffee and the red light faded out and now the lights will not come on at all. The machine does not come on.
    I bought it just a little over a year ago and I have taken very good care of it. Can someone tell what the problem could be.
  • 515 Answers
Some off the machines have a reset pin on the thermostat, take off the top and you will see the thermostat on the boiler, one off the thermostat have a pin you can press on.
Hope this will help you
Best regards
/Mirran
Posted on Aug 27, 2008
  • Mirko Blas
    Mirko Blas Sep 04, 2008
    I don´t no wy you get me a inappropriateon this case??
    If you have a Saeco Aroma and the machine is dead, in 90% it will the thermostat or fuse tha have to be reset or replaced.
    Best regards
    /Mirran
How do I raise the feed dos
Consult your owner's manual. There is a switch, lever, or knob somewhere on your machine that raises the feed dogs. If they are stuck in the down position and your machine is mechanical, could very well be it has seized due to lack of cleaning and oiling.
This may be helpful:
The feed dog knob won turn don think anything is broken haven used the...
Dec 30, 2015 | Sewing Machines
Low steam pressure
descale the heating elements with vinnegar.
Mar 20, 2014 | Rancilio Silvia Espresso Machine
Light won't turn on Shark steam mop
I posted this video explaining how to clean the heater core of the S3501...it is likely a similar design as the Euro Pro.
http://youtu.be/S4NglGXVv50
Dec 09, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Won't start but timer works
Check primary and secondary interlock (door) switches. DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Viking Professional Series VMOS200BT
Whirlpool aqua steam 6 door won't open tried resetting, cleaned out filter can you help ?
We had the same problem. Mechanic had to come and replace the lock. Took him less then three minutes to open the door, remove the old lock and put a new one in.
Jun 30, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
My machine blinking on steam, the wand does not want t o steam, the espresso does not pour. The knob is turned on stand by , but still some steaming noise comes, but no steam comes from the wand, nor...
When it is blinking on steam it means it is preparing the unit for steam. When the steam light goes solid your unit is ready to make steam.
  • Turn from standby to steam then wait for steam light to go solid.
  • When solid steam wand will begin dribbling then spitting out water, which will then turn to steam.
  • When it begins to steam, turn back to standby. NOTE: you only have 6 seconds before steaming turns off.
  • place steaming wand in jug and turn from standby back to steam.
You will hear pumping noises when you turn off your steam, because it releases the steam and puts the excess water in to the drip tray.
  • make sure your bean hopper is properly locked in to the unit. Grinder won't work if hopper not locked in.
  • Make sure your water filter has been prepped and locked securely in to the reservoir and your reservoir is filled.
  • Use fresh beans.
  • Sounds funny but use good quality water, do not use ordinary tap water. Make sure it is filtered or use bottled water (cooler bottles).
  • Try to grind your beans to a good consistancy.
  • Breville recomends about 10kg tamping pressure, use a set of scales to check the feel.
  • Tamp to about 3-5 mm below rim of grouphead (portafilter). Or the tamp has a guide on the side, that silver side on the tamp is the tamp line. Pretty vauge about that in the book.
If all else fails go to www.breville.com.au and check your model and watch some of the vid clips.
Jan 06, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Gaggia titanium. The water and steam are all going through the brew head instead of coming out the wand when I need it to. I have cleaned everything, used a pin to clean the wand (it didn't need it) ONE...
This is hard to picture. The only way water can come out the brew spout is if the brewing mechanism inside in the position to make coffee. The only way to get that mechanism into that position is to either select one of the three coffee buttons (you'd hear the grinder run, then you'd hear the motor putting the brew mechanism into place and then the pump start and water would then come out the brew spout. OR to select preground coffee and then select one of the three coffee sizes - in that case you wouldn't hear the grinder but you'd still hear the motor turn the brew mechanism into brewing position and then start the pump.
When you simply select hot water and then open the steam valve - I can't imagine any possible way for water to come out the brew spout.
Now if you mean that you don't see any water come out but water is leaking inside the cabinet and ending up in the drip tray - then that would mean a leak inside the machine. It could be the valve that the brew group locks into when it goes into brew position (you see this valve in a little recess behind the brew mechanism when you take the brew group out to clean it). Or it could be a leaking steam valve or hose inside.
You might try getting a flashlight and a cleaning brush - take out the brew mechanism and then clean around that little nozzle/valve that is in the recess just the left of center behind where the brew mechanism was. That valve should shut when you are not in brew position and not allow any water out - but it may be gummed up with coffee grounds.
If you are feeling brave - you would need a deep socket and a lot of patience with a small breaker bar (a ratchet head is too big to fit in there) and you can remove that nozzle/valve and then clean it or replace it. But it is very slow going to remove it (there must be some special tool they use at the factory). I had just the right size deep socket (like what you'd use for a spark plug in a car) but there wasn't room for a ratchet so I had to use a small breaker bar and I could only turn the valve about 1/4 turn at a time then I'd have to reposition the socket to do another 1/4 turn. It took 5-10 minutes to remove it - then it was easy to clean. I think you could clean it in place with a stiff bristle brush and some q-tips.
I don't know if that valve is the problem - but that's the only thing I can think of that would have your hot water and steam running into your drip tray instead of out the steam wand.
Oct 26, 2010 | Gaggia Titanium Espresso Machine
Frother not working
It seems that the steam solenoid valve is stuck open. This can be because of a small part from water usualy scale or lese is stuck in bettween the solenoid valve rod, or the whole valve rod is full of scale so it can not move. You can open the valve an by using a wire brush you can clean all the parts and the valve can work perfect again. If the valve is rusty or full of hard scale then you need a new one.
Good luck.
Remeber to vote for this answer.
Mar 20, 2010 | Saeco Gran Crema 2-Cup Espresso Machine -...
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
Coffee Makers & Espresso Machines Logo
269 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
