Question about Sharp Viewcam VL-A10U Camcorder
I can't insert the cassette into my Viewcam - Sharp Viewcam VL-A10U Camcorder
  • 425 Answers
Check to see if you have a source of power to your Viewcam. We suggest using either the supplied battery or the A/C Adaptor. For further assistance, contact us at 1-800-BE-SHARP.
Posted on Sep 07, 2005
Inserted a cassette, get the message "cannot record cassette" "protect tab". A little grey piece (probably the protect tab) fell out the camera when I set it down. Not sure where this...
On the mini-DV tapes I have, the protect tab is a slider- it does not come out of the cassette. If you look at the back edge of the tape, where the long label goes, the protect tab is at the right hand end. When it is set to prevent recording it will look like a little square hole, but there should be a tiny edge of the tab showing (mine is green) which you can pull across with a fingernail or sharp object to cover the hole and allow recording.
Nov 29, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp video camera VL-AH50
Did you try cleaning the tape head?
Feb 22, 2008 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Cassett does not get inserted
Put a head cleaner tape in camera and run it for 20 seconds ever few months.
May 29, 2010 | Sharp Viewcam VL-Z1U Mini DV Digital...
Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Oct 18, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
8mm Cassette mechanism fails to eject or sometimes fails to close
This camcorder is at least six years old now, and replacements are available quite cheaply vie on-line auction sites, probably at far less than the cost of repair.
Apr 05, 2017 | Sharp Viewcam VL-AH60U Hi-8 Analog...
Sharp Viewcam VL-AH151U keeps saying "eject cassette" why is that? How or where can i send this to get fixed?
Assuming the record tab is in the correct position, download the manual for the VL-AH150U, very close to the 151U.
Page 10 of the manual shows the normal reasons for the "eject cassette" message. If not, I would call Sharp support at
1-800-BE-SHARP (237-4277) for referral to a local repair center.
Let me know if this helps.
Jan 18, 2009 | Sharp Viewcam VL-AH151U Camcorder
Canon mv300i
I have glued a small plastic square over the "switch" on the cassette that presses down more on the sensor in the camera so it can sense that on the cassette and it should clear the tape cassette. Better still have a camera tech adjust the sensor in the camera. Good luck
Aug 25, 2008 | Sharp Viewcam VL-AH151U Camcorder
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
hello i have a probleme like you with my VL DP3S
First you must cleaner the head with a cassette cleaner 5 sec max. if it's not ok you must consulting a specialist
Oct 22, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
The "DEW" indicator is illuminated on my Viewcam, what do I do to turn it off?
This means there is moisture inside the Viewcam. Try taking the tape out, leaving the cassette compartment open for 2 hours to allow any condensation to evaporate. If the DEW indicator is still illuminated call a Sharp authorized servicer.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Sharp Viewcam VL-A10U Camcorder Logo
141 people viewed this question
Top Sharp Video Cameras Experts
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
