Question about E-Machines Computers & Internet
No Power. I have an e-machine T2885. Being a novice I am pretty sure that the power source is gone. I have a couple of questions: What wattage should I replace with and is it something that I could do myself?
  • E-Machines Master
  • 3,051 Answers
Yes you can replace it your self verry easy what i do is use numbered color tape so i can mark the cords and any other thing that i might remove then i write it down on a piece of paper where they go and as far as the power requirements once you pull out the powersupply it will tell you on the lable what the wattage is i would bring it with you to the store to make sure you get the right one ok i hope that this really helps you aout ok best regards mike
Posted on Aug 27, 2008
Tassimo coffee machine
Most power inverters require the vehicle to being running to operate, and make sure it's the correct wattage, if it's a small watt inverter it doesn't have enough power, as a coffee machine is considered higher wattage, hope that answers your question ?
Feb 21, 2015 | Magnum MM1524AE : 1500 Watt, 24V Inverter...
Pc wont power on
It's very likely your power supply is gone. You will need to open up the tower, find out the output wattage (there is a sticker on the power supply), then replace it with a similar wattage model. Most likely 350W for eMachines would work just fine. Let me know if this solved.
Feb 05, 2011 | E-Machines eMachines Desktop PC
When I use the presser foot nothing happens. The machine is plugged in, turned on and everything is set up correctly. I was told my a not so reliable source that the motor may be shot. But, the machine...
even though it's only used moderately the motor can go out,
does the light come on?
try plugging the sewing machine into a different outlet
check to make sure the power cord is pushed all the way in
it also may be the power cord itself that has gone out
it could also be the on & off switch
Sep 01, 2010 | Singer 6038 Mechanical Sewing Machine
How to check if my power supply is already not ''at the limit''?
1 or 2 extra hdds and ram does not require much extra power and your coolmaster should do the job. But if you intend to use a newer graphic card you should check the requirenments for wattage at your new card manufacturer product specification webpage. I am pretty sure that almost all newer graphic cards require at least 500 watt to run without problem. My advise is to buy at least a 550 watt psu although i don't know what is your hardware. Try to post your hardware specs and calculate for each component (cpu wattage+graphics wattage +etc) your power supply need to be over 50 wattage. Hope that helped!
Mar 22, 2010 | Cooler Master (RS-430-PMSR/P) (RS430PMSRP)...
Emachine wont start up
This is a DESKTOP machine, not a laptop. It has to be plugged into a wall outlet that has power, for the machine to run.
Jan 05, 2010 | E-Machines eMachines Desktop PC
Emachines T2200 - 6 years old or so, does not power on. I am thinking it might be the power supply. Not sure about cost or how to repair. Thoughts? Fortunately not my only system!!
Will not power on would be a power supply unit around $40-$90 bucks depending on the wattage you like to get and the explansion that you want..
This would not be a repair job rather then a replacment job all you do is unhook and label your power cables inside, use a screw driver and undo all the screws on the outside of the power supply unit and pull it out. Its pretty easy..
Sep 30, 2009 | E-Machines eMachines Desktop PC
Laptop will not turn on or charge?
If the battery is fine, then the only other power source is the power adapter cord. You'll have to borrow/buy one and make sure the wattage which is on the square part of the adapter matches...if you have any questions let me know..
Apr 27, 2009 | Fujitsu AMILO PC Laptops
Need to remove fromt panel from t2885 machine
First of all, disconnect the power cable from the electrical outlet and from the back panel. Then
disconnect any cables connected to the computer.
here is the link to the pdf file (including pictures) of how to remove the face ..
http://downloads.emachines.com/userguides/Desktop_UG_Nexgen2_3_en.pdf
this require adobe reader (free) if you dont have it already. refer to pages 4-7 to 4-11 for the info your looking for.
Mar 16, 2009 | E-Machines T2885 PC Desktop
Power Source/Supply
Confirm the wattage(how many watts e.g 150W) needed by your system from your manual.Make sure the wattage of power supply you are buying exceeds it or is equal.
Jul 15, 2008 | Computers & Internet
Wiring diagram for T2885
Give me also model serial number (printed on your motherboard or on seller's receipt).
http://www.dealtime.com/xPF-E-Machines-Desktop-with-Intel-Celeron-Processor-2-8GHz-T2885
Feb 17, 2008 | E-Machines T2885 PC Desktop
Computers & Internet Logo
49 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
