Question about Ryobi 18V Hedge Trimmer
Ryobi 18V Hedge Trimmer Blade Question
Ryobi 18V Hedge Trimmer blades have lost their sharpness, can I sharpen then or I must buy new blades?
  • Anonymous Sep 21, 2008
    dull 18" Ryobi trimmer blades. Neither Lowes or Home Depot had this brand.
    Neither Lowes nor Home Depot had the 18" Ryobi hedge trimmer blades. Can they be sharpened?
  • 4 Answers
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
  • 163 Answers
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
Engine runs but blades dont move
John:
My bet is that the drive gears are stripped. Lay the machine on it's back and see the 4 screws that hold the sole plate on to the body of the machine, (The sole plate is also the bottom cutting frame that the blade slides against). Remove the 4 screws (be careful... there will be a small circular bushing under the sole plate and it likes to jump out, fall off of the table, and run under the nearest immovable object!) Remove the sole plate and blade and upper cutting frame as a unit. You can now see the gears that drive the blade, and one (or both) of the gears will be stripped of it's teeth. Go to the manufacturer's website and you might be able to buy new gears.
Nov 30, 2013 | Ryobi 18V Hedge Trimmer
Weedeater Excaliber Gas Hedge Trimmer. Is it possible to sharpen these blades? If yes, do you know the procedure?
You should be able to sharpen your hedge trimmer blades. There is a good video on how to sharpen hedge trimmer blades on youtube by ereplacementparts. He explains how to do it with a file or a grinder.
Aug 24, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Need to sharpen Ryobi hedge trimmer. How do you release blades?
A model number would be necessary. Look for a label with a model RYxxxxx.
You can see an illustrated parts listing by going to www.homelite.com. Click on the parts tab. It will send you to their parts vendor's website. Then type in your model number and you can see the parts breakdown. If your blades are rivited together, just buy a new set of blades. If your blades are bolted together, then it is possible to sharpen them.
I would still recommend to know how much new blades are. In my area, there are only 2 repair shops that sharpen hedgers, and they both charge more than $50 to do this.
Dec 22, 2010 | Ryobi Garden
Will I be able to have my trimmer blade sharpened?
The blade can be sharpened, the problem is that these are not sharpened to ofter. Finding a person to do it will be.....difficult. I would suggest finding a knive or scissors sharpener, they would be able to handle this.
Hope this helps
Nov 13, 2010 | Black & Decker 1 18Volt Cordless Electric...
Can I get my Ryobi Hedgetrimmer blades sharpened or replaced ? Its only 2 years old and blunt already, it struggles to cut conifer and tears rather than cuts. I am not impressed.
If the blade set is bolted together, then a local repair shop should be able to sharpen them. Look for a shop that works on Echo or Stihl hedgers, as they can be sharpened. If the blade set is riveted together, then it must be replaced as a unit. You did not list the model or item number for your hedger, but try www.ereplacementparts.com or www.ordertree.com . Both sites will allow you to type in your model or item number to look up all the available parts.
Sep 08, 2010 | Ryobi 18V Hedge Trimmer
Sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Feb 12, 2010 | Garden
Do I ever need to sharpen? If I do, how?
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
Jan 25, 2009 | Ryobi 18V Hedge Trimmer
Add on hedge trimmer ryobi weed eater
Sep 14, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Ryobi 18V Hedge Trimmer Logo
1,981 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
