Question about FrancisFrancis! X1 Espresso Machine
Francis Francis X1 too high temperature
Recently bought a defect X1 I am trying to fix.
Until now I have opened the alu-boiler and cleaned it inside, changed the boiler gasket to stop it leaking and also changed the gasket in the brew head valve to stop the dripping. Only remaining problem is that the temp. gets too high (130 °C) when the machine is turned on, and when temp is reached and the light goes out, nothing happens if the steam switch is turned on. I guess there are two possibilities, 1) the electronic thermostat is defect or 2) the wires for the PCB have been swapped around by the former owner.
Can anyone help me with a diagram for the PCB?
  • albionkh Jan 17, 2009
    i have the same problem. Machine was fine, then one day it no longer cut out at the appropriate temperature. Just kept getting hotter and hotter. I assume the thermostat is the fault, but can you get replacements?
  • Ernest R
    Ernest R May 11, 2010
    Or it is possible that the steam valve is blocked?
5 Suggested Answers
  • 3 Answers
SOURCE: model X1 overheat
I had the same problem with my Francis Francis X3 overheating. I'm certain the thermostatic controls are similar and I suspected that as the problem. I did not want to pay the roughly $180-$200 to send it in for repair so I opened the X3, located the thermostat and discovered that it was a Prodigy Italiana TR/86 30C-120C adjustable thermostat with the temperature control knob removed and the "P2" wire-lug removed. I could not find one online, but later discovered that Chris' Coffee Service sells it for the Zaffiro here: http://www.chriscoffee.com/products/home/isomacparts/zaffirothermostat.
You should probably open your X1 and confirm the thermostat(s) before ordering. Ironically, I ordered the thermostat, put my old thermostat and machine back together so I could try to use it for a few more days while I waited for the new thermostat to arrive, and all of the jostling apparently freed up the thermostat in my machine so that it started working properly again. The new thermostat arrived and it is an exact match, so I have set it aside for when the orginal one permanently fails, and I know it will. Good Luck!
Posted on May 02, 2008
SOURCE: Francis Francis X1 Electrical Problem
Hello all, I had the same problem and I was not willing to pay to repare the machine so I opened it and had a look inside but could not find anything.
Then started connecting/disconnecting different parts of the machine to isolate the problem which turned to be the boiler. There must be some short inside it so nothing I could fix myself.
Instead what I did is to disconnect the ground connections (yellow cables) and now it's working fine! I didn't notice anything in the last couple of weeks so I'm enjoying the machine again.
Of course there must be a better solution for the problem but this "quick and dirty" trick turned to work out for me!
Posted on Apr 10, 2009
  • 1089 Answers
SOURCE: Francis Francis fuse defective?
Hi
If you have power its not likely the fuse. It could be the heating element or the board.
Posted on Jun 16, 2009
  • 1089 Answers
SOURCE: Francis Francis X1 Popping noise - stopped working
Hi There are a couple of things that could have happened. The fuse could have blown, but you wouldn't get a pop usually. The main board could have blown, that will pop. There is a hole below the steam arm. up inside there is a screw that you can loosen. Then you can unscrew the steam knob. There are 4 screws on the bottom side of the cover that will allow you to remove the top. Make sure that the machine is unplugged.
Posted on Feb 14, 2010
Francis Francis X1. Why does it work sometimes and sometimes heater trips GFCI?
take it to an appliance repair shop to have it checked out
the trip is working but if you ignore the problem you may get electrocuted
Dec 25, 2015 | Coffee Makers & Espresso Machines
"francis francis" x1 blocked - Fix Suggestions?
You can tell if the pump is working by the noise it makes. Mine got blocked with scale and I took it apart and cleaned out the boiler. It's possible; the boiler is bolted together with standard bolts (metric size). If you've got the interest the Francis Francis is easy to service; you will find a way into each part of it and clean it, and if you do it will work like new.
Jun 22, 2014 | FrancisFrancis! Coffee Makers & Espresso...
Boiler Making popping sounds when heating
Not much else you can do unless you want to open the boiler to clean it out. Yes, I like the Francis Francis too!
Oct 05, 2012 | FrancisFrancis! X1 Espresso Machine
My Francis Francis x1 wont heat
You should check the temperature of the water coming out from the machine when it show that is heated. If it is lower than 90 C then the thermostat inside the machine attached to the boiler is need to be replaced. If the temperature of the water is about 90C then the problem is with thermometer, and in this case is only an accesorie since the machine can faction properly and make a good espresso.
May 21, 2012 | FrancisFrancis! X1 - Stainless Steel...
Hi
Jun 16, 2009 | FrancisFrancis! X5 Espresso Machine
Boiler gets too hot
Hi Contact Francis/Francis because you need power board.
Apr 12, 2009 | FrancisFrancis! X5 Espresso Machine
Francis Francis X1
Some leaking from the group head of the machine is totally normal while the machine is heating. The reason for this is that the valve that sits above the shower screen is simply a spring and rubber ball. The spring expands, creating a seal with the rubber ball and the boiler, once the boiler reaches a specific temperature. Until the boiler temp is reached, leaking from the group head will occur.
Feb 26, 2008 | FrancisFrancis! X1 - Stainless Steel...
Low temperature
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Dec 19, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 Espresso Machine Logo
241 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
