Question about Achiever SCS-6 Strip-Cut Shredder
Need to replace a belt
I have a Achiever Scs6 with a motor model "970-515. I need to purchase a belt for this motor. Where can I purchase one?
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
What causes insufficient air flow across evaporator coils
Dirty filters is number one, other blocked ducts.
Bad or slipping blower motor
Slipping belts , if you model has it/ them.
Jul 20, 2014 | Ruud RGTC07ERBGS N/A Achiever 75000 BTU...
My Achiever CCS-5000 still works fine, but emits a LOUD, LOUD, SHRILL noise when cutting. Can I fix it at home? It is seven years old, but only used in a home a couple times a week.
It could be a couple of things. I have the same unit and it is a couple of years older. I take some motor oil and dribble it across a few sheets of paper so that the cutters can be lubricated about every 1 hour of continuous use. This has decreased the noise levels immensely. The other possibility is the belt inside is slipping. The oil in the cutters can help this noise, but if the belt is worn badly, it will need replacement. To access the internals, you have to remove the unit from the stand, turn it upside down and located all of the case screws, (4). Mine has hex head screws. Turn the unit right side up and pull the cover off. Clean the unit out as much as you can, apply silicon grease to the gears (remove the old grease and clean as much as possible first). Using an oil can, squeeze some oil over the cutters. Check the belt, if you can move it without turning the pulleys or if it seems very loose, take it off, go to the nearest auto parts store and get them to size it and pick up a replacement if they have one. Otherwise, you'll have to order the replacement directly from the manufacturer.
Jun 13, 2011 | Achiever CCS5000 Shredder
It is squeaking.
Just remember that the number one cause of failure of the motor controller is high walking belt friction. I always make sense to replace the walking belt when you are replacing the motor controller on the Iron Man Treadmill.
Sep 09, 2010 | Ironman Fitness Achiever Elliptical...
Where can you purchase repair parts? the teeth are stripped on one of the gears. I need a replacement gear for my Achiever SCS-6 Shredder.
I appreciate your intent to help solve my printer problem. However, I do not think it should require me to pay a fee to get an address to locate a Company to obtain a replacement part for my Achiever shredder.
Oct 02, 2009 | Achiever SCS-6 Strip-Cut Shredder
I need a fuse for my ccs5000 achiever shredder. Do you know where one can be purchased?
Radio shack has a good selection. Make sure you match it exactly. Do not put a larger capacity fuse in there. It can burn the circuit board.
Jun 18, 2009 | Achiever CCS5000 Shredder
Achiever shredder
The fuse has blown and we need a new fuse for it. We need the fuse number that is on the tip of the fuse. Do you know where we are able to purchase them from?
Jun 10, 2008 | Achiever CCS5000 Shredder
CCS 5000 Achiever Shredder
You need to purchase a real heavy duty shredder that will handle your work applications. Call 800-342-7362 EG Brennan & Co LLC can help you in this regard!
Apr 12, 2007 | Achiever CCS5000 Shredder
Achiever SCS-6 Strip-Cut Shredder Logo
80 people viewed this question
Top Achiever Office Equipment & Supplies Experts
Gilbert Ruiz
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
