Frozen. will not play or turn off. computer does not recognize device as present
  • 2 more comments
  • kimpsmith Sep 03, 2008
    Creative Zen V
  • kimpsmith Sep 04, 2008
    The manual states that I should not remove the battery. Should I ignore this and try your solution anyway? Will it make a difference now that the battery is completely run down (when it froze and wouldn't shut off)? And if it makes a difference, it is a Zen V.
    Hope someone can advise. Thanks
  • kimpsmith Sep 08, 2008
    Thank you for your help. I know have my music back. Yeah!
  • 89 Answers
Check this website for reference on things you can do:
http://www.mycreativefansite.com/2007/06/creative-zen-v-plus-frozen-cannot.html
i hope your problem will be resolve already.
Posted on Sep 04, 2008
    Brigadier General:
  • 6,966 Answers
On most MP3 players, a couple of possibilities to unfreeze:
  • see if there is a reset button, if yes, press on it. Often the reset would be recessed inside a pinhole. Of course in some cases, since the unit will reset/revert to factory defaults, all stored information may be lost;
  • check the manufacturer's website. They sometimes have recovery utility programs, or even a firmware upgrade/flash;
  • open the unit and remove the battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 03, 2008
  • 435 Answers
Please specify the model
  • Narmada Anand
    Narmada Anand Sep 03, 2008
    Thanks for giving your player model name.....Try these steps to troubleshoot your player:
    Reset the player with a pin in the little reset hole.
    The player is now Off.
    Press the Play/Pause button and hold that button.
    Turn the player on, while holding the Play/Pause button still.
    When you see the Recovery Menu, release the Play/Pause button.
    Now you have 4 options. 3 of those are usefull to you.
    First you can choose Cleanup. Player will scan itself for corrupt data,
    and clean it up. Your music will not be erased, so that's a bonus.
    When this is done, choose Reboot. Player will restart, show "rebuilding
    library" once more, and then it will work again, problem solved.
    If for some reason the problem is not solved, choose Format All in the
    same menu. This will erase all data of the player (except for the
    firmware) Again, choose Reboot, player will rebuild library and be
    fixed afterwards.
    Now your player is back to normal. What has caused the problem? Most
    probably cause is that you put Wave (wav) files on it, this player
    doesn't like those very much.
    You can improve the stability of the device by putting the newest firmware on it, Creative has a handy tool for that:
    http://ie.europe.creative.com/landing/MP...
    This little guideline is for your player, the Zen V Plus. Other people
    with other simular problems may need a slightly different guideline.
    They can send me an email if they like. If I have some time on my hands
    I will even answer it :)
    You can just email Creative as well... This is a very common thing, and
    I am surprised you would ask it on Yahoo before contacting the
    manufacturer.
    Anyway, let me know if it's resolved please.
    Thanks
  • 6,487 Answers
Can you please give us the model and brand of this MP3 player so we can help you better, By the way did you try resetting the unit?
Hope that helps.......
  • Mark Gil
    Mark Gil Sep 04, 2008
    Yes, you can remove the battery so the player will reboot itself and then check if you still have the problem..
    Good luck..........
    Master:
  • 763 Answers
Did you try to check the batteries and the connection of it? try to refresh it by unpluging it or removing the battery. hope that helps you sir!
cheers
CHARCOIS
  • 19,396 Answers
If it has a battery remove mp3 battery for five minutes. Provide device make and model for more troubleshooting.
  • 1 more comment
  • Ginko
    Ginko Sep 03, 2008
    If it has a removable battey first remove the battery to see if you can unlock it.
    If the battery is internal you will need to take it apart to reset the battery.
    If it does not unfreeze, then it is likely a problem with a firmware, but you cannot update or reinstall firmware if mp3 does not start.
    Some brands and models have a reset button that sometimes can fix this problems.
  • Ginko
    Ginko Sep 03, 2008
    Try reset button first, Then try plugging it into the computer, holding power switch in on position, then you trigger the reset button
    if it does not work see here how to fix it:
    YouTube - Creative Zen V / V Plus Help Reset Won't Work ...
    YouTube - Fixing Frozen Creative Zen V / V Plus
  • Ginko
    Ginko Sep 04, 2008
    The manual wisely suggest to call a qualified technician if you have a problem of this kind.
    As usually, if you decide to DIY you do it at your risk, damaging an electronic device is always easy.
    Ask to a local repair shop how much do they charge, and then evaluate if you want to take the risk, taking unit apart and removing battery, or you want to take the unit to a repair shop.
My gogear if frozen. Will not power off.
Hello :
Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
PLEASE DON'T FORGET TO RATE !
Apr 18, 2010 | Philips GoGear Flash MP3 Player
Creative zen became frozen
Let the battery completely drain, and after a while charge it using the charger available else thru computer without turning it on.. let it charge for 50% and then try switching it on. Try this if not get back to me.
Jan 21, 2010 | Creative Technology Zen MX Black (8 GB)...
I think mine is the e260 - 2 gig sansa. The last time I turned it on, it resumed playing the album that had been playing the previous time I used it - as normal. When the album finished and I tried to...
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Jan 09, 2010 | SanDisk Sansa e250 MP3 Player
My computer wont recognize my USB
Try the following steps:
NOTE: Resetting will turn the player off while it is frozen.
If that doesn't work, then you may download and install the Sansa Firmware Updater and update to the latest firmware.
Jun 04, 2009 | SanDisk Sansa e260 MP3 Player
USB device is not recognized
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Dec 01, 2008 | i.Trek M5 GPS Receiver
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Frozen
Try to download the "fixer" from Creatives homepage.
Apr 27, 2008 | Creative Labs Zen Stone Plus MP3 Player
My mp3 player is frozen
Did you figure it out? I have the same message on mine and nothing I do fixes it... my laptop won't even recognize the usb device so I can't look into reformatting the player.... if you figure it out let me know.
Dec 12, 2007 | Audiovox SMP3332 MP3 Player
Player frozen
You should let the battery be flat and then charge it.
It'd then work. It happened to me twice. Hope this helps.
Dec 05, 2007 | Samsung YP-T7Z MP3 Player
51 people viewed this question
 Grubhead
Grubhead
