Question about Ingersoll Power Force By Rand PF235 Touch Up Spray Gun Hvlp
Ingersoll Power Force PF235 Question
How should i clean and store my spray gun once I've finished using it?
Thanks.
  • 35 Answers
If you want to have the use of it for a long time you have to clean it realy well every time you used it. I assume you used it to paint oil based paint in which case you have to use the same liquid that you used to thin the paint, like therpentyne or thinners. After washing the excess paint out, blow some of the thinners through - about 200ml. To make sure there is no paint inside on the needle and the spring, take the bits out and make sure they are clean. You can spray it with some 3-in-1 oil to make sure it's not stuck when you want to use it again. It might not be practical for you with this model but I always left some of the thinning liquid in the bottle. Also, if it is possible, I took the nossle off and left it in the this bit of thinning liquid.
Posted on Nov 01, 2008
What is the best way to lay down the clear coat over my finish coat on the fender I just painted but ruined when I shot the clear coat?
Refer to the paint manufacturer's data sheet to ensure the new gun has the right setup for clearcoat.
Could be the new gun was supplied setup for spraying a high solids primer or something that needs something like a 0.7 mm fluid tip. Clearcoat would need a 0.4 mm tip, an appropriate needle and a different air cap.
Data sheets are very valuable things. Don't forget to pick one up when you buy spray paint. A viscosity cup is another useful addition to the tool kit along with a graduated paint stirring stick.
Nov 24, 2015 | Air Tools & Compressors
We are using an a Campbell Hausfeld Airless Spray Gun and wondering where to buy a new nozzle should it not last for the whole house? We live in South East, SA
the nozzle should last as long as it is cleaned properly when the day is finished. Walmart sells Campbell equipment and/or many hardware stores do as well, the tip may not need to be specifc to your brand to fit, take the tip with you when go shopping. Also, check with your Cities maintenance department and find out where they buy there tools and parts, most likely you will find the parts you need there.
Mar 22, 2011 | Campbell Hausfeld Airless Spray Guns &...
Ingersoll-Rand G25 generator had been operating normally. Output stopped today with generator running and 120/240V breaker closed. Continuity test shows a short between ground/neutral and A phase with...
A ground to neutral short should not stop the machine and may be how the breaker panel was wired. Single phase 240 volt power just has two hot lines and the neutral just center taps the transformer winding supplying the 240 volts. The twin breakers that supply this voltage, should both trip even if only one line has a short on it. Check the resistance of L1 and L2 lines to neutral that feed the motor with the breakers off. Each should read nearly equal resistance which usually is only a few ohms when correct. Make sure the motor turns freely by hand as a locked compressor can certainly pop the breakers. If the compressor appears locked, remove the cylinder head(s) and try to turn again. If still locked, one of the connecting rods may have broken in the crankcase. The other problem could be a broken valve assembly in a head. If the motor has a capacitor start and/or run capacitor, it can cause a breaker trip because the motor cannot start with a defective capacitor. Hope some of this helps!
Jun 14, 2010 | Ingersoll Power Force By Rand PF235 Touch...
Paint sprayer won't pump
Ok, go to campbel hausfeld web site and download a manual for your sprayer : http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?langId=-1&storeId=10051&catalogId=10001
Find your model number and look at parts view. Pay paticular attention to the inlet and outet valves. They must be absolutely clean to function. These pumps must be thoroughly cleaned when finished.
May 15, 2010 | Campbell Hausfeld Airless Spray Guns &...
What are the controls of a gravity fee spray gun
most spray guns are basically the same gravity feed is no different, air pressure into gun and out nozzle,spray pattern fan to spot and last the amount of fluid comin out of cup to the nozzle.
Aug 28, 2009 | Ingersoll Rand 1.4MM HVLP GRAV FEED SPRAY...
BROKEN PART 270G
buy a new gun, parts wil cost as much as a new gun, beside having to hunt forever for parts( all most impossable to find!)
Aug 05, 2009 | Ingersoll Rand HVLP Gravity Feed Spray...
Finish is rough
Spraying smooth needs both the right airflow and right viscosity. Since your getting lap lines I would say your putting it on too thick. Thin down your coat, it should be approximately the thiness of water.
Apr 03, 2009 | Accuspray 4 Stage Turbine Sprayer...
Vaper primer gun has intermittent air supply
Does it come with instructions? The material thickness is VERY IMPORTANT when choozing the proper nozzle.
Nov 17, 2008 | Northern Tool Vaper 2.0mm Hvlp Spray Gun...
Ingersoll Power Force By Rand PF235 Touch Up Spray Gun Hvlp Logo
162 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
