Question about DeLonghi Heating & Cooling
I have a DELONGHI DE400P 40 Pint Dehumidifer.its red led starting send signal(like 3 beep every 10 seconds). I think it can not discarge water secondely, Its draing soket broken during my survy. how I can buy its spare?
I know, the drain socket just jumped off into your hand....Ther three beeps....a code,,, look inside the panel or paper-work for the code,, &for the leak, "gorilla glue"! Thank-you-very-much!
Posted on Aug 27, 2008
Electrolux EXD15DN3W dehumidifier has power to unit, but wont start operation? Display is off, on button doesnt respond, but LEDs light and beeps when bucket is removed. Any advice much appreciated.
The bucket interlock may be defective. It works correctly to signal when the bucket is removed but doesn't signal the power switch that the bucket is in place.
Nov 23, 2016 | Dehumidifiers
Bought a electronic deadbolt at Rona (Rona Collection). Installed it and i can open/close it with the remote control or a key. Can't open it by entering a code. I thought the factory code was 1234, but...
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
  • Remove batteries and put them back. You will hear a long beep and a short beep.
  • Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
  • Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
  • Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
  • Key in master PIN and press UNLOCK button
  • Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
  • Release 0 button and you are in the Add PIN mode
  • Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
  • Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
Sep 23, 2010 | Deadbolt Locks & Locksmithing
Our delonghi de400p dehumidifier shows an E3 error message. Customer Service says its a sensor but can't tell us what sensor. Any help would be appreciated.
I have a 40 pint and a 50 pint that are very similar. The 40 pint has the e3 error. Experimenting with the 50 pint, I found if I disconnected a particular sensor I got the e3 error. That sensor is a little can with two black wires (smaller than a AAA battery but shaped like that). It is attached to the cooling coils so must be a temperature sensor. This is not the little circuit board sensor mounted in the middle of the radiator in a plastic box/clip thing.
I am now about to see that part to see if I can replace it.
Jul 09, 2010 | DeLonghi DE400 Dehumidifier
Maytag Dehumidifer still works, but is leaking
Well life span is 3-15 years depends how long and hard you run them. 45 pint is about 1000sqft basment. rule of thumbs bigger better. run less and do a better job. I would start by filling the bucket and place in a dry shower see if you have a crack. cant find a source for the bucket discontinued this might be your problem. http://www.repairclinic.com/SSPartDetail.aspx?s=t-M7DH45B2A-%3d%3di1025984&PartID=1025984 Repair cost are about 40-50 and hour!!!! good luck
Nov 01, 2009 | Maytag M7DH45B2A Dehumidifier
Delonghi de400p dehumidifier does not work
if comp and fans running your out of freon or the compressor is not pumping more than likely out of freon and that means theres a leak in the sealed system high cost repair
Jul 03, 2009 | DeLonghi DE400P Dehumidifier
Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
May 17, 2009 | DeLonghi De'Longhi Energy Star174;...
Delonghi DH400P Discharge Hose
I have the same problem on ocassion.
I just remove and reseat again , making sure the front of the tank is flush with the unit. sometimes a little more push in does the trick
Aug 11, 2008 | DeLonghi DE400P Dehumidifier
Heating & Cooling Logo
117 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
