Question about IBM 4610 TG4 Thermal Label Printer
Problem printing with IBM 4610 TF6
I have this printer and i can't print with it on windows XP, i connected the printer with RS323 cable and it doen't communicate with the computer, i tried the IBM driver and no good.
can u plz help me.
roy
  • ras81 Aug 28, 2008
    hi
    the cable is ok, because i already replaced it, the cable is new....
    i think it's some kind of driver issue, but the driver on IBM site just won't work.
  • 199 Answers
Download and use this driver instead, EPSON TM-88II Printer Driver, 4.00.
Good luck.
Posted on Aug 28, 2008
  • IBM Master
  • 1,879 Answers
Use generic text driver - go for LPT (default port) then change the installed printer properties later.
get the serial settings of the printer first (bauds etc).
  • monk3ybidzness
    monk3ybidzness Aug 28, 2008
    add:
    make sure that it is a 24/9 pin NULL-MODEM serial cable
  • monk3ybidzness
    Just use the Generic Text Driver <--- this works great even with EPSON's
  • 2,071 Answers
Follow these steps to run the print diagnostic utility.
  1. Double-click the print diagnostic utility icon on the computer desktop.
  2. The print diagnostic utility checks for issues with the following:
    • Connection
    • Spooler service
    • Print queue
    • Product status
    • Device manager
    • Wrong port
    • Wrong print driver
  3. If the print diagnostic utility identifies an issue with any of these settings, a red X appears next to the item. If the utility does not identify an issue, a green check appears next to the item.
  4. If a red X appears next to any of these items, click the Fix button to resolve the issues.
  5. Click Test Print at the bottom of the print diagnostic report to print a test page. If the test page prints successfully, the issue is resolved and there is no need to continue with further steps.
  6. If the test page does not print successfully, click Restart Computer .
  7. After the computer restarts, print another test page.
If all of these steps have been completed and the issue continues, proceed to Solution two: Resolve the issue manually. Solution two: Resolve the issue manually Complete these steps in the order presented to resolve the issue manually. Step one: Print a test page
  1. Print a self-test page to make sure that the hardware is functioning correctly.
  2. Follow one of these options to make sure that the self-test page prints correctly.
    • If the self-test page prints correctly, proceed to Step two: Restart the computer.
    • If the self-test does not print correctly, and other symptoms are evident, see the help documentation that is specific to those symptoms.
  1. Click Start and click Shut Down .
  2. Click Restart or select Restart from the menu.
  3. Click OK .
  4. After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If all of these steps have been completed and the issue continues, proceed to the next step. Step three: Check the product cable
  1. Disconnect the USB cable from the product and from the computer.
  2. Wait five to six seconds.
  3. Reconnect the USB cable to the product and computer.
Hope this may help;
Regards,
VOTIT
    Brigadier General:
  • 6,966 Answers
Initially, I would suggest:
  • run an OFFLINE Test on the 4610-TF6 to verify that the printer is operational;
  • check/replace the RS232 cable;
  • try using an EPSON TM88II driver. 4610-TF6 and 4610-TM6 can emulate a single station Epson printer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Master:
  • 848 Answers
A marginal cable which will work on one computer printer port and not on the other; not likely. It should be an IEEE-1284 (bi-directional cable). Check for pushed-in pins on the printer cable. Screw the PC end down and latch the Centronics end at the printer. Remove any other device you may have attached to the port; e.g., scanner. Click Cancel, turn the printer off, unplug the printer cable, wait a few seconds, reconnect the cable, make sure the printer is on with no error lights, restart Windows, and try again. Remove and reinstall the paper (paper out can cause a printer communications error, at least it can in DOS). Try the various printer modes in your computer's CMOS Setup. ECP+EPP usually works with bi-directional printers, but others may fix the problem. Try F8 just as Windows starts to boot, select the DOS prompt from the resulting menu, find a non-zero length text file (one that is 1-2K would be a good choice) (e.g., autoexec.bat or something ending in .txt), and print from DOS with:
C:\>type autoexec.bat>lpt1:
or
C:\>type filename.txt>LPT1:
If that works consistently, the problem is probably in Windows.
Be sure Windows is set-up correctly with the correct printer driver and something else (another printer, FAX, etc.) is not assigned LPT1: Be sure the 710 is set as the default Windows printer. Try it on another desktop computer. If that works, try another printer on the suspect computer. I have seen cases where a baby AT motherboard was upgraded, but the printer cable/header assembly from the old motherboard was used and caused problems, but that is very rare. Also, the cable connecting to the motherboard could be backwards or loose.
  • 6,487 Answers
It can be a connection problem, since the printer and the computer are not communicating, probably the cable is bad, so if you have a different cable that we can try that will be better so we can check if its only a cable problem ...
Hope that helps......
  • Mark Gil
    Mark Gil Aug 28, 2008
    If you already tried a new cable so this is really not a problem with the cable, try to download the software from IBM then try to go to printers and faxes then just try to add a new printer and follow the wizard until you're done installing the printer software..
I have a IMB 4610-TF6 and it's making weird
ummm did make sure your .exe was in english first?
Sep 06, 2009 | IBM Office Equipment & Supplies
Stopped printing
reinstall your program for printer.if it dont work.
printer is bad.let me know.ok
Jul 21, 2009 | IBM SureMark Printer TF6 Thermal Label
Printing only one side
Most likely the small 'roller' on the LHS of the paper feed shaft is missing. This roller engages the metal 'yoke' on the LHS when the printer lid closes and provides a suitable pressure for the paper to contact the thermal head. They break into 2 pieces sometimes and fall away from the shaft. Solution: remove circlip and replace the roller if you can get one. I have them made.
Mar 26, 2009 | IBM SureMark Printer TF6 Thermal Label
Cannot get printer to print
very possible but you may need to disable the firewall if you have one then disable the antivirus . then try to reinstall software for the printer and follow directions closely. biigg53566
Dec 05, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM 4610 TG4 offline.
if it printing trash more than likely you have a driver problem, where are you getting the driver for your printer?
try to look for another driver and test by going to ibm's website:
http://www.ibm.com/products/finder/us/finders?Ne=5000000&tmpl=%2Fproducts%2Ffinder%2Fus%2Fen%2Ffinders&finderN=1000188&pg=ddfinder&lc=en&cm_re=other-_-suprcn-_-download&collectionN=0&sid=304421691223506248263&cc=us&C1=5001220
good luck!
Oct 08, 2008 | IBM 4610 TG4 Thermal Label Printer
IBM 4610 suremark receipt printer
Hello all,
had the same problem and my solution was to install the latest driver available at the IBM service/driver website. Then unistall it with another IBM driver cleaning tool, then repeat both processes a couple of times, until the printer responded. There is some bug on these latest drivers an older Windows versions, so only after some installations and repairs on the first install, windows gets it right. VERY STRANGE but it worked in 2 machines, both IBM terminal and 4610-tf6 IBM printer.
By the way; RS232 ibm cable...I believe its a null modem 9 pin...not a regular serial cable.
Dip pin config: my printers have 4 so; 1ON 2ON 3OFF 4OFF which means
1 size of paper you are using 80mm
2 if you use an IBM software or other:other
3 if xon/off or DTR/DSR:hardware
4 com speed: 9600baud or 19200baud, 9600
That's what I igured out. If you need any more info: mail
fit.frederico@gmail.com
FredP
Sep 28, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM 4610 TG4 Printer configurations from windows
Hi
you onli need send commands by excel is ASCII CODE its easy
Apr 10, 2008 | IBM 4610 TG4 Thermal Label Printer
IBM 4610 TG4 Thermal Label Printer Logo
3,051 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
