Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
No power, water in machine
I came home to find dirty dishes and water in the bottom of the machine, no power lights at all, is there a reset on the pump assuming its a blockage that has caused this and once I unclog it will restart?
  • rjvox Sep 02, 2008
    I have the same problem, and can't resolve it. There is no power to the machine - the light doesn't come on. There is water left in the bottom. The fuse is ok.
    any ideas?
  • 706 Answers
Depending on how your DW is wired.. it could be plugged into a receptacle like any other appliance or hard wired directly from your circuit breaker box.. I would check to see if you have any circuit breakers tripped or fuses blown... to verify that you have power.. assuming you do... and because you had water in the base .. chances are your drain filter was clogged that leads water to the pump.. or the pump itself is clogged or defective.. Try power cycling the system by either unplugging it or switching off the breaker or fuse feeding it power.. Hope that helps
Posted on Aug 27, 2008
Fixed problem after viewing 93 code but now dishes have brown film or white film. Dishes still dried on food. Have a Samsung DMT800RHS. One suggestion was to get phosphorus which is ******* for deterg
look at the arm that has the water nozzles on it to see if some of them are plugged. Also make sure the screen at the bottom of the machine isn't restricted.
Nov 06, 2014 | Samsung DMT800RHS Dishwasher
Water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Nov 02, 2012 | Kenmore Dishwashers
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Would the stainless steel make the inside of the dishwasher smell awful when half full of dirty dishes after only 2 days? I noticed under the screen on bottom of tub that not all the water completely...
stainless steel will not smell or rust that why its used,the cause of the smell is twofold 1 dirty dishes should not be left unwashed in the machine to long a bectearia starts to grow within a couple of hours and starts the smell process,2the filter system at the bottom of the machine should be checked everyday [heavy user]light use every [2/3 days],the screen at the bottom of the machine is the filters,some models do leave some water in the bottom.adrian,,,,,
Aug 12, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher not taking in water
check the water valve. if it is getting power. change the water valve
Apr 07, 2009 | GE WSXH208A Front Load Washer
Dishes are dirty when finished water still in bottom of machine
you have a drian and /or pump and motor you didnt give the brand . It would help. call 704-819-6557 for free tech support and parts.
Mar 14, 2009 | Dishwashers
My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Jan 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
I rinsed my dishes first, then i put in a tablet to wash the dishes ad never thought any more about it untill the following morning i went to empty the dishes and discovered that the dishes had not been...
Sounds like the drain is clogged, so the dirty water is not draining and the dishwasher won't cycle because if it did it would overflow (causing a mess). So I would suggest trying to remove the obstruction (could be food or a utensil, etc.... at the drain hole or in the hose itself ). I am pretty sure once you clear the blockage that your machine will operate normally again. You may have to unplug it (for a few minutes) after clearing the blockage to let it reset to default.
Apr 02, 2008 | Dishwashers
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
316 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
