Question about Stanley Pneu Roof Stapler
Stanley Pneu Roof Stapler Troubleshooting
Troubleshooting advice needed my Stanley Pneu Roof Stapler doesn't staple as before, i'm working on the same type of roofs as always, but now it just staples 3/4 of the way, needless to say that the job is looks horrible.
What's gone wrong with my stapler?
  • Anonymous Mar 17, 2014
    how to load staples in a stanley bostitch b8 stcr2115 stapler
  • Anonymous Mar 26, 2014
    who sells power shot staplers?
  • 4,234 Answers
Sorry for the delayed response, I just found this one...
The issue with depth is usually one of 2 things:
1) Insufficient pressure (bad regulator on compressor or incorrect setting).
2) Bad seals within the gun.
When was the gun last serviced? Have you looked at the O-rings for any signs of damage? All it takes is a little leakage of pressure and the plunger won't have enough thrust to set the staple as expected.
Dan
Posted on Sep 15, 2008
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
Looking operators manual for stanley bostitch rn45b
Look here for manual and parts:http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc_results.htm&Left=left_tooldoc_results.htm&partNum=WM45B&serialNum=
The two lines of address above should be all one line in the address bar. If it does not work, go to www.bostitch.com , service parts and find wm45b. Good luck
Sep 18, 2010 | Stanley Pneu Roof Stapler
Looking for user manual for craftsman stapler 9-27227
These manuals can usually be obtained and downloaded be going on line at sears.com enter model number and click on manuals
Sep 12, 2010 | Stanley Pneu Roof Stapler
How do I reload a Rapid S1 Supreme stapler?
  • Hold the gun in your right hand
  • The clip shield is spring loaded, when it released it will move toward base.
  • Near the base of the hand grip on the left side there is a metallic clip, free it with your left hand.
  • When it opens, check for obstructions, single staples, etc.
  • If it's been a busy day, add a couple drops of light oil to the moving parts.
  • Insert a clip of staples.
  • Slide the guard home, The clip will snap into place when it registers.
Then your good to go...
Best regards
Mike
May 20, 2010 | Stanley Pneu Roof Stapler
Won't shoot nails
Usually this is because the "loader" is not moving the staples into the correct position. Make sure that the staples are loading correctly and that they move on the rail smoothly. Also, the spring should be pushing the staples toward the plunger. If the spring can not move freely, this will occur as well. Without seeing the actual gun, I cannot say for sure where the problem is, but the above are the first areas to look.
Dan
Apr 29, 2010 | Stanley Pneu Roof Stapler
Do these run on gas?
this one doesn't, it requires compressed air to operate. There might be some gas fired roofing nailers out there but I would think that they would somewhat slow to operate.
Dec 20, 2009 | Stanley Pneu Roof Stapler
How do the staples stay in place in my stanley 1/4" stapler? They slide back and forth and therefore aren't in place for the stapler to work?
There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to bostitch.com to find the parts you may need
Apr 18, 2009 | Stanley Tools Staple/Brad Nail Gun
Not firing
May need cleaned and lubed. Check for bad o-ring.
Mar 19, 2009 | Stanley Pneu Roof Stapler
Multiple nails are ejected
its all about the pressure you apply...to solve this try pushing down then firing....i know its a pain and slows work a bit but it'll save you staples and from possibly firing THROUGH the shingle...pulling them up is enough of a pain anyway... also see if you can tighten the tip of the gun...that should make it less responsive, tighten the trigger as well...good luck
Feb 09, 2009 | Stanley Pneu Roof Stapler
Stanley Pneu Roof Stapler Logo
154 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
