SOURCE: fanforce oven
usually you have a bake and a convection button if you only one button for baking you may not be able to use bake with out the fan good luck
SOURCE: Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
SOURCE: Frigidaire gas oven - model FGF366AWA - doesn't get hot inside
Yes it could be the thermostat, but what you need to find out and it is difficult to do, is determine what is cutting your gas back off.
The thermostat could be doing that but the most likely cause is the ignitor.
http://www.appliancepartspros.com/part_details.aspx?part_id=2150412&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d111760%26diagram_id%3d335207
The amount of electric going through hte ignitor is what tells the gas valve to stay on. When the ignitor gets old it does not pull enough power anymore. The the burner lights for a bit and then cuts out before it should giving you some heat but not enough. It just sits there and cycles...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Testimonial: "Tips were helpful and response was very quick."
SOURCE: I have a Superba Built-in electric convection
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
