Question about Palm Tungsten T3 Handheld
Hotsync problem Using Hotsync manager I want to set Date Book, Address Book, To Do List and Memo pad to synchronise as the default. Each time I set them to synchonise and 'tick' the default square, the required default is not maintained after the immediate subsequent HotSync. I realise this is a minor fault and I have lived with for some time, but if there is a solution, I would be grateful. It is a pain having to ensure that the four fields are synchronised each time without having to remember to reset the perameters ech time. Jon Leigh
SOURCE: HotSync error ((sys 0505) (0,841)
Thanks a lot for the tip. I just deleted the mypalm application and the error message stopped!
Posted on Aug 27, 2008
SOURCE: SYNC LGKU990 to PC
This is what sorted it out for me.
When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
Let me know if that helped.
Posted on Sep 09, 2008
SOURCE: I am unable to HotSync and cannot load HotSync manager
I reinstaled the Palm Desktop again it worked....
Posted on Sep 21, 2008
SOURCE: help
I had the same issue.  I finally upgraded to the current version of Outlook.  That seemed to solve the issue for me.  Syncing a palm is not easy.  I will never buy a Palm again.
Posted on Oct 24, 2008
sycoduck
  • 41 Answers
SOURCE: Palm Tx problem after hotsync
I had the same issue, the palm is stuck in a loop,
I got mine out of this by pressing the power button while the palm was on the screen where the bar goes across the bottom, it asked me if I wanted to erase all data, I said yes, and it reboot normally, I went thru the setup, and all is o.k.
I did have to try this several times, but it eventually worked. Hope this helps, although it looks like this is an older question. I hope you have resolved it.
Posted on Nov 05, 2008
How to move data from Thngsten E2 to new computer?
if you use the latest Hotsync Manager - version 7.0.2, you should click Setting, then Applications.
You will get a list of applications that you can synchronise with your PC. Place a check mark beside those you want/need. Make sure to click the Configure button ( bottom right hand side) and select the Handheld overwrites Desktop for each application. Click on the Set as default...
This should ensure that the data is copied from the handhelp to the PC, and nothing gets overwritten on the handheld.
May 27, 2009 | Palm Tungsten E2 Handheld
Freezes while doing a hotSync
make sure your important data is backed up (by hand if necessary) and do a hard reset (back to factory specs)
this should allow to do a fresh data load from hotsync
Mar 21, 2009 | Palm Z22 Handheld
I updated the Palm m130 to Z22. I lost all my addresses on the m130 whe installing the Z22. Is there anyway to retrieve the lost file?!
The solution to this problem is.. if the m130 still has all the data, then
you need to perform a custom hotsync to overwrite all files on the computer
  1. Click on the ‘Hotsync Manager’ icon and choose ‘Custom’.
  2. Highlight the ‘Datebook’ conduit and click ‘Change’.
  3. Select ‘Handheld overwrites desktop’ and click ‘OK’.
  4. Repeat these steps for the ‘Address’, ‘Todo’, ‘Memo’ and ‘System’ conduits.
  5. ‘Install’ and ‘Install Service Templates’ should be ‘Enabled’.
  6. Perform a ‘Hotsync’ operation by pressing the button on the Hotsync® Cradle, or Cable.
Now that the files are on your computer you need to sync them into the new palm
Same steps but this time Desktop Overwrites handheld
  3. Select ‘Desktop overwrites Handheld’ and click ‘OK’.
Oct 31, 2008 | Computers & Internet
Trying to hotsync my desktop and my 755, and I use Outlook.
if using verizon go into the wireless sync application and select settings> connection> advanced settings> and select enable other sync apps.
Apr 07, 2008 | Palm Treo 755p Smartphone
'Reset' each time after hotsynching
Do you still have administrative access to your laptop? IIRC there are some problems with using PD with a non-admin account.
I would recommend that you back up the "good" backup data on the Laptop. In PD, Choose Tools/Options, the "Data Directory" entry shows where the data is stored (in a subdirectory that looks like the first six characters of the Palm's User ID)
Sep 11, 2005 | Palm Tungsten T3 Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Zire 72 and Outlook 2003 - I think I've tried it all! Doesn't work....
you don't need pocketmirror for zire 72 because palm desktop have outlook conduits to handle outlook synching. inorder for you to sync using outlook you must have the outlook conduits installed which seems you have it already installed. you have to disable some older conduits inorder to avoid conflicts with the conduits. to do these follow these steps: 1. right click on the hotsync manager icon on your system tray 2. click on Custom... 3. select Date Book (Outlook) 4. click on Change... 5. select Do Nothing and set it to default 6. click Ok 7. repeats steps 3-6 for Address Book (Outlook), To Do List (Outlook) and Memo Pad (Outlook)
Sep 07, 2005 | Palm Zire 72 Handheld
Sep 07, 2005 | Palm Zire 72 Special Edition Handheld
Corrupt Date Book Fixed
Updated Instructions Simple fix for a corrupted Date Book sync error (at least it worked for me on my Treo 650). 1). Turn off 'Show Calendar Event' in the Phones 'Options - General Preferences' menu. 2). Turn off phone. 3). Set the Date/Time to the maximum limits (12/31/31) in Preferences. 4). Open the Calendar and view the maximum day 12/31/31. 5). Select 'Purge - (Delete events older then 1 week)' in the Calendars Options menu. 6). Reset the Date/Time to the current day in Preferences. 7). Hotsync (Desktop Calendar overwrites handheld). 8). Hotsync again to make sure you don’t get the error (Synchronize the files). That’s it. =============================== Outlook Calendar The attempt to open the database failed. Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize. OLERR:05-0001 OLERR:0D-0004 OLERR:0D-0001 - Not Synchronized Outlook Calendar synchronization failed OLERR:15-0002 OLERR:06-0001 ===============================
Sep 07, 2005 | Palm Treo 650 Handheld
Synch question
If you have PocketMirror from Chapura (included with certain Palm handhelds), you can choose to install conduits that synchronize MS Outlook with the handheld applications Date Book, Address Book, To Do List, and Memo Pad. You can choose to synchronize these applications with either Palm Desktop or Microsoft Outlook, but not both. If you want to synchronize with Microsoft Outlook, DO NOT install Palm Desktop from the Web. Instead, run the Palm Desktop installer from the CD that came with your handheld and select the option "Synchronize with Microsoft Outlook" when the choice appears. Visit www.PocketMirror.com for more information about Chapura(R) PocketMirror.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Palm Tungsten T3 Handheld Logo
24 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
