Question about Energizer Rechargable Battery with Charger
14.4 B&D firestorm battery will not charge. I got it about a year or so ago online and just now tried to use it. charge is gone and it won't charge. do they wear out if not used?
    Problem Solver:
  • 8 Answers
Yes, Batteries can go bad if not keep charged. The problem may also be the charger itself. If you have a DC Voltmeter, you can check the charger's output...... if no output voltage is apparent (or too low an output voltage, relative to the Battery's voltage, it may be time to replace the charging unit.
Posted on Mar 23, 2009
How can i charge my b&d 12volt ps130 batteries without a charger
A Dewalt 12 V or I use the universal charger works on my B & D Firestorm trimmers battery How technical are you I could Explain to you how to set up a 12V ( > 13VDC) power supply to the terminals on the battery but you have to be Extra careful not to over charge ! You can pick up Firestorm chargers for about $ 15.00 on Ebay
Jun 27, 2016 | Cars & Trucks
My firestorm 24 volt double charger the lite is on but it won't charge the battery
It is charging the battery but the battery is not holding the charge probably from a faulty batter in the pack.so the charge is going in and out at the same time. Take the pack to a battery shop that specialises in replacement batteries to have it checked out . Take the charger also for tests.
Jan 14, 2013 | Tools & Hardware - Others
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
I bought a black and decker pole battery saw, used it once and recharged it to use again,it only ran about 10 minutes and the battery went dead, or to low to do any work. Is all the batterys that...
George, firestorm bats. I believe are for the drills ? There is usually a 2 year warranty on B&D products, either take it back to the store where you purchased or contact Black & Decker : blackanddecker.com
Feb 01, 2010 | Garden
Charging system
When the new alternator was installed did you perform a charging test to ensure it works properly. If it's not the alternator may overcharge the battery causing corrosion to the posts and possible cracking of the battery case. If you don't have the tester at home most auto parts stores can connect theirs and it usually is free.
Good luck to you
Oct 16, 2009 | 1998 Chevrolet Express
Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Sep 12, 2009 | Black & Decker Black And Decker FS24C...
Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Jun 01, 2009 | Black & Decker Black And Decker FS24C...
Short Battery Life on insignia 4gb player
sounds like the rechargeable battery has gone bad.  Replace the battery and don't let the player cook in the wall socket next time.
Mar 24, 2009 | Insignia Pilot MP3 Player
Charging system
I had this car about 10 years ago. Loved it!
You must either clean or replace the battery cable. The corrosion is not allowing the charge to get to the battery.
Many parts houses carry a battery post/terminal cleaner that will aid in getting all of the crud away from the terminal.
You should be sure to remove all of the corrosion!
Good luck
Brian
Sep 06, 2008 | 1985 Nissan 300ZX
Energizer Rechargable Battery with Charger Logo
186 people viewed this question
Top Energizer Electronics - Others Experts
cwradio73
Are you an Energizer Electronics - Other Expert? Answer questions, earn points and help others
