Question about HP Photosmart C6180 All-In-One InkJet Printer
Error Code I have a C6189, model Q8191a. I am getting an error code 0XC05D0281, I installed brand new HP cartridges, tried the reset list that hp recoomends and still get the error code, can you help me, do I need to get a new printer? Thank You
    Problem Solver:
  • 15 Answers
That's absolutely correct. The exact error message on the printer says "Ink System Failure. Error 0xc05d0281."You need a new printer for that kind of error. Actually there 3 different errors that you may encounter when installing brand new ink cartridges. The error that starts with 0xc18 and 0xc19, we can still recover the printer for that but only once. If the T/S is already done and was not able to resolve the problem, then that's the time that the printer needs to be replaced. For error 0xc05, ther only solution is to replace the printer. It means that the ink system has already been failed and cannot be recovered.
Jiffy Epe
HP Technical Support Representative
Posted on Aug 28, 2008
  • 210 Answers
I had a similar problem of a senseless printer error code with similar useless help from HP for one of my client's HP Photosmart 7510. I also could not find any other relevant help online. But, while searching, I did notice a suggestion to clean the contacts. When I removed the ink cartridge carrier, I noticed a large build-up of ink around the nozzles. Cleaning out the carrier did the trick for me. It couldn't hurt to give it a try.
Follow the steps below if you need them. And, please click "Yes" below if this has helped you at all.
Remove the carrier: Open the printer to access the ink cartridges. Slide out the ink cartridge carrier if it is parked. Remove all of the cartridges. Then flip the lever to the right of the carrier. Grasp the carrier using your thumb on one side and index/middle finger on the right, both near the top, and pull straight upward. Careful, yours may be more full of ink than my client's was.
Clean the carrier: Wash the carrier in a sink with warm/hot water at various angles until all noticeable ink is cleared away. Briefly wash water directly into the carrier's induction screens which contact the sponges of the ink cartridges. This may help a little to flush any ink from the nozzles which might have dried in them while the printer was inoperable.
Remove most of the water: Shake the carrier downward (only while upright) and tip the carrier forward and side ways. But, be careful since some ink will still be contained in the carrier's ink channels. Pay close attention to the induction screens. If you tip it too far or shake while inverted, ink may splash out through the screens or drain back onto the carrier. If this does occur, repeat the cleaning procedure.
Note: Do not attempt to drain all of the ink from the channels, whether through the induction screens or through the nozzles on the underside of the carrier.
Dry the carrier contacts: Lightly wipe the tiny metallic white squares on the backside of the carrier with a dry paper towel. Spot dry the surrounding area, including the nozzle arrays on the underside of the carrier - dab, don't wipe. You should get ink spots on the towel from the nozzles. This is to be expected and is a sign that the nozzles are not clogged (at least not completely).
Inspect the carrier transport: Examine the area with the metal prongs that were exposed when the carrier was removed. Dab dry any areas with ink if you find any, especially near the metal prongs. If you discover any ink on the prongs, use a wet, but drip-dried cloth or towel to continuously dab the prongs until they are clean. Then dab with a dry cloth or towel. Re-inspect and ensure any lint or other debris is removed from the prongs.
Reassemble and test: Return the carrier to the transport, flip the locking lever to the downward position, return the ink cartridges, and then test your printer.
I hope this helped and that all goes well. Please click "Yes" if this has helped you at all.
Posted on Mar 30, 2014
.photosmart c6180 ink system has failed unable to copy recieve fax or printerror 0xc18a001
As always I start with the dreaded question. Did you use a refilled cartridge in your printer? If so, remove it and install a new HP cartridge. Recycled cartridges are famous for this type of failure. By the way the error code is a Windows error code. If you haven't found a solution to the " ink system failure " yet, it is quite easy to reset (using the buttons) on HP C7180. You can find the reset instructions on my website: http://www.inkbank.com.au/webcontent21.htm
Try this:
May 04, 2015 | HP Photosmart C6180 All-In-One InkJet...
How do i fix error code 0xc05d0281
http://h30434.www3.hp.com/t5/Other-Printing-Questions/0xc05d0281-error/td-p/615959
Sep 01, 2014 | HP Photosmart C6180 All-in-One Color...
Error code 0xc05d0281 how do i fix this
Here is the full and complete procedure you can follow to get the issue resolved Hp C7280 ink failure 0xc05d0281
for more you can call the hp support (877-690-9305)
I receive hp catridge error when i refill the catridge and install in my printer.
check if cartridge is genuine
check if it is really a brand new one or fake
power cycle the printer
check if it has an alignment option,align the cartridge with new inks
check if it has a clean utility automatic cleaning
or you can manually clean the contacts on printheads which detects the inks the you inserted
reset the unit if you know how to
different printer has specific way of resetting
most probably you are just getting a rejection error try using theold one if that fixes the issue it means there must be an issue with brand new inks
hope it helps you
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | Office Equipment & Supplies
Hp 3180 print cartridge light blinking
hi,
is the ink cartridge you replaced hp brand or did you refill it this is an incompatibility code from the software. some brands and cartridges are not fully compatible and creates an e code error code. if it is hp brand it is likely a defective sensor chip in the ink cartridge. i would for best assurance return the cartridge for a different one and then recheck. if niot you may need to restore your software or reinstall it most of the time this will fix the problem.
hope this helps..happy computing!
Mar 29, 2009 | HP Photosmart C3180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Print Cartridge Error
Have had much experience with HP AIO models and would try to double check the contacts on the cartridge carriage.. sometimes a q-tip swap dipped in alcohol gently over the contacts will fix this - also note the dates on the ink cartridges (even the new ones) If the dates are previous to the date showing on the machine, this will give this error, but can be worked around by clearing the memory with a factory or full (hard) reset that sets everything back to zero dates. THis usually involves holding down certain button combos while plugging the machine in... Try a search for reset codes on HP site or google with model number and "reset code" to find the proper button combo.
Jan 08, 2009 | HP PSC 1410v All-in-One Printer
Canon Pixma IP600D - error code 6502
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
Please refer to the following link http://www.coldreset.com/modules.php?name=News&file=article&sid=60
Terry
May 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Error code
toner chip is gone replace cartrige
Oct 08, 2007 | Konica Minolta magicolor 2430 DL Laser...
HP Photosmart C6180 All-In-One InkJet Printer Logo
1,337 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
