Question about Panasonic Lumix DMC-FZ20 Digital Camera
Pictures have come out blurry and out of focus
I got the FZ20 and have been taking shots around the house just to try it out. I have pretty much kept it on P with the aurofocus. Most of the pictures have come out blurry and out of focus. I am not sure exactly what I need to do to correct this. Yes, I read the manual but still can not figure out the problem. I have noticed the jitter alert seems to be on frequently but there doesn't seem to be any movement. (camera or me) If the camera is set to P, do I still need to adjust any of the settings?
    Master:
  • 903 Answers
The most common problems that most new users encounter are: 1. Trying to focus closer than @7 ft. when zooming at greater than 6x. The camera won't do it, and that zoom is tempting. 2. Not waiting for the lens to focus before completing the shutter press. Try holding the shutter at half-press until you see the steady green indicator, then gently press fully to take the shot while holding as steady as you can. 3. Expecting too much from OIS. If you're seeing the "jitter" icon a lot, that means that you're into the range of slower shutter speeds that OIS might not be able to compensate for.You might try switching to a higher ISO speed (or turning on more lights)-- yes there will be more noise, but it'll quicken the shutter speed, and a non-blurry pic that's noiser is better than a clean blurry one. . . and you'll learn a little about what you're camera will do under different conditions. Also, you have to really make the effort to hold the cam steady, even with OIS, especially when using slow shutter speeds.
Posted on Sep 07, 2005
Nikon coolpix S6000 won't focus
To focus lightly press the shutter button (the one that takes pictures). Pushing it half way tells the camera to focus. When you're ready push it the rest of the way in and it should take a nice crisp photo. If not there's a problem. Take it to a repair shop, replace it, just rely on your smartphone, or learn to deal with blurry pictures. I'd personally go with the smartphone as you always need it anyway.
Mar 27, 2014 | Nikon COOLPIX S6000 Digital Camera
VIEW SCREEN IS SO BLURRY I CAN'T TELL WHAT ITS SHOWING.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Feb 26, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
Focus problems
There are two likely reasons for the blurry pictures. One possibility is, as you surmised, a slow shutter speed. Try mounting the camera on a tripod or other stable support. You might also try turning on the flash.
The other reason is focus, or lack thereof. You didn't specify what cameras you have, but if they're Coolpixes, they most likely have a close-up or macro mode that will allow the lens to focus closer. If you're using a DSLR, you will need some other way to focus closer. Macro lenses, extension tubes, and close-up filters are three ways of achieving this.
Jan 20, 2010 | Cameras
What is the best setting for indoor concerts? Alot of my pictures are blurry & either too dark or too light.
No flash, right? Concert pix are some of the hardest to do. 80% recovery is pretty good.
Don't use a speed slower than 60 (1/60th second).
try us use telephoto as much as possible, leaving the dark areas out of the picture. The camera metering gets confused when you have too much audience and other areas that are not lit up like the stage.
Other "experts" may have more "solutions" for you...
Sep 21, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Mar 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Trouble with sony cyber-shot DSC-T33
try cleaning the lens first.
when taking the picture press down lightly so it will focus. Then press harder for the picture.
Jul 14, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Camera taking blurry pictures
I'm having the same problem with my Panasonic Lumix camera. A year of perfectly clear photos, and now, even after a cleaning, is taking consistently blurry photos. I'm a photographer. I know about half-depressed shutters, focusing on objects, etc. What is wrong with my camera?!?
Nov 14, 2007 | Cameras
Blurry Pictures
Check that you have not got Macro set accidently.
If lighting level are low and the camera is selectinging a slow speed - reset to Apeture Priority -setting 'A' and and be very gentle with the release - the slightest movement will blur an image on long exposure.
Try these thing and if still introuble come back with more detail
Nov 11, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
149 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
