Question about Dewalt 18V Cordless Adhesive Dispenser 10oz DC545K
Dewalt Glue Gun Warming Problem
My Dewalt glue gun just stopped warming up, i don't know what's wrong with it. Does this happen often i thought i bought a reliable brand?
  • 35 Answers
Are you in the UK? The fuse in the plug might need replacing. I had the same problem with glue guns. It's not worth buying an expansive one. The cheap ones might take a bit longer to heat up but the last just as long if not longer. I can never tell when the element will go.
Posted on Nov 01, 2008
Tool shop glue gun
that's just an unfortunate side effect of gravity. it happens to all glue guns. as the element heats the glue it turn into a liquid and oozes out of the nozzle. eventually it would stop when once all the glue in contact with the element has oozed out.
check this out.
Feb 27, 2014 | Tool Shop Dual Temperature Glue Gun 60...
Keeping glue from getting stringy
Whenever I use a hot glue gun I had been getting that stringy glue sticky mess when I get to the end of my gluing. I have been experimenting with different methods for stopping this mess from happening.
The method that I have found to work best takes a bit of retraining. When you are done gluing instead of instinctively picking up with glue gun creating that stringy mess, you lift the tip up a little way away from the project and make a few small circles. Then the glue detaches from the gun and you are free from the mess and able to continue with your project without having to stop and clean up every time you pick up the glue gun.
on Sep 17, 2013 | Crafts & Hobbies
How to use wire stand on glue gun
the wire stand is there to stop the glue from melting and dripping out the end when you aren't using it. simply fold the wire stand out so that the gun can rest at a 45 degree angle. i would still advise you to set the gun on the wire stand on a paper towel or something, because it may still drip a little.
Feb 16, 2013 | FPC Corporation Trigger fed glue gun
Glue does not come out
Can you please provide the brand name and the model gun so that I can try to help you? On most guns, the yellow light means it is still warming and the red light means it is hot and ready to squirt, but i need to know the gun type to be sure
Dec 31, 2012 | Crafts & Hobbies
Hi, can't get Stanley dual melt glue gun to
some users have complained that the trigger fails. when this happens, the glue will not heat up. if it seems to be a problem with the trigger and the gun is relatively new, i would try to return it and get a new one or get your money back
Nov 13, 2012 | Crafts & Hobbies
I bought a Surebonder Fine Tip Hot Glue gun (small, for crafting) about less than 2 months back. It was fine at first until it stopped squirting melted glue and i had to manually push the glue stick from...
My guess is that you left the gun plugged in too long for the amount of glue that you were using. If you are using it for a good squirt every minute or so, you can leave it plugged in, but if your leave it plugged in too long while using too little, then the heat works it's way back up toward the back of the glue stick. First thing that happens is the glue-advancing trigger stops working because the advancing mechanism can't push against the softened glue stick. Leave it run even longer and it melts further back. Then when you turn it off it cools, but the melted glue is now in places it shouldn't be. If you take it apart you might be able to scrape and pry all of the once-melted glue out of it, then you would be back in business. Good luck!
Aug 27, 2012 | Crafts & Hobbies
I have a new Surebonder rechargeable glue gun. I was gluing a large pc. and rushed to get another stick and it would not feed by pulling the trigger, There was one glue stick (partial) still in gun, but...
it sound like the charge ran down, recharable glue guns are not typically recomended for large project becuase heating elements run down batteries very quickly. to get the stick out of your gun, you will need to fully charge it and then after that turn it on and when its warm pull the trigger and the glue should once again come out, For large project I would recommend you purchase a wired (plug in the wall) type glue gun. Thanks for you question
Mar 22, 2011 | Crafts & Hobbies
How do i insert glue stick in to my emhardt electric glue gun
Insert the glue stick into the back of the gun. After doing this plug in the gun and allow it to heat up. When the gun reaches the correct heat level you will be able to pull the trigger of the gun which will pull the stick into the gun. This will only happen if the gun is hot enough.
Aug 16, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Master mechanic glue gun 207 stopped working
Try cleaning the glue stick slot out with acetone (nail polish remover) and a paper towel, or cue tips if you have to get into a small area. that should help to break down any dried glue that may be blocking a new stick from feeding in, or may be blocking the heating element
May 14, 2010 | Crafts & Hobbies
There is a glue build up inside. Most likely in the feeding mechanism, try to heat it up, the unplug, and use like a paper rolled up to try to remove some of the glue. :)
Mar 25, 2010 | Crafts & Hobbies
Dewalt 18V Cordless Adhesive Dispenser 10oz DC545K Logo
170 people viewed this question
Top Dewalt Crafts & Hobbies Experts
Level 1 Expert
Level 1 Expert
Tony Crow
Are you a Dewalt Craft and Hobby Expert? Answer questions, earn points and help others
