Question about Fuji FinePix S5500 Digital Camera
Do all filters need an adaptor?
Do filters all need an adaptor? I have a s5500 with a 55mm thread on the end. but I take it a hoya 72 IR filter will like all filters need a filter holder? Why dont they just screw in?
    Master:
  • 425 Answers
Yes I can see cokin make screw in filters. Im having a hell of a time trying to find a 55mm filter holder in the uk on the internet.
Posted on Sep 07, 2005
    Master:
  • 425 Answers
You can get screw-in filters, but those that require adaptors or holders are more versatile, as you can use them on a variety of different sized lenses.
SOURCE:
How to install a 52mm filter to a nikon 18-55mm lens
If you have 52mm screw in filters, look at the filter and you will notice that the metal ring has threads. Look at the inside of the rim surrounding you lens front element and you will also see screw threads. Carefully align the filter with the lens threads and screw them together. Do not over tighten or you will have difficulty removing your filter.
Although less common today, unthreaded filters are or were in the past available. If you have unthreaded filters, you will need to buy a 52mm filter adaptor. The adaptor is made in two screw together pieces. Unscrew the two pieces, drop the filter in between them and screw them back together. Then, screw the adaptor onto your lens.
Mar 11, 2014 | Nikon Cameras
E-84 amway water filter
hi , providing you have the whole kit with the mounting head and sump or filter housing the head will have a flow direction, you'll have to cut your pipe and either sweat a fitting or use the provided adaptors usually quick connects, they can be purchased at local plumbing supply shops while your at it pick up some shut off ball valves for when the filters need to be changed. thread on the filter to chamber using rubber washer included. good luck , half hour tops ity will be installed.
Dec 06, 2013 | Amway A101, E84, E-85, E-9225 Compatible...
Would a hoya Infrared R72 filter tamron 72mm lens
That would depend on the filter.
Since Tamron has never made a lens with a fixed focal length of 72mm, I assume the 72mm is referring to the filter thread. I also assume you mean the Hoya RM72 infrared filter. The "72" in the filter name is a description of the filter and has nothing to do with its physical size. One vendor lists the RM72 filter in sizes ranging from 46mm to 77mm. As long as you get the filter to match the thread on the front of the lens then it will screw right on.
May 29, 2012 | Hoya 72mm RM-72 Infrared Filter
How do I fit the Hoya UV filter that I have been sold with my New Nikon D3100?? Darent be too heavy handed as new to this. Thanks.
The filter doesn't go onto the camera, but onto the lens. Assuming it's the proper size, it should just screw into the threads on the front of the lens (the end away from the camera). If the lens hood is on, remove it first.
Nov 07, 2010 | Nikon Cameras
TCON-17 TO ADAPT TO E-510 AND E-620
TCON-17 has a 55mm filter thread.
You will need step up or step down filter adapter ring depending on the filter size of the lens that you are using.
May 25, 2010 | Konica Minolta 6711140 CL49200 Closeup...
My rotating polarizing filter fell apart and I can
Based on the fundamentals of retaining rings, The filter lens probably fits into the ring housing first, and the retainer ring is inserted inside of the ring, following the lens. The retainer will need to be compressed in order to fit inside the ring, but will snap into a groove once in proper position.
I hope this is helpful... Good luck.
Oct 09, 2009 | Hoya 77mm Circular Polarizing Pro 1...
I want to know if I can use a Hoya IR filter R72
Gary short answer a YES! You may need to increase the EV +1
Please rate my help to keep the FREE service online++++Thanks for using FIXYA
Sep 10, 2009 | Nikon D200 Digital Camera with Nikkor AF-S...
Are there filters made for the Finepix S1000fd? If yes can you recommend a seller?
You will need to buy an adapter I believe. Filter kits and auxilary lenses are sold all throughout eBay, KEH.com, bhphotovideo.com, lots of places.
Just make sure your threading is correct. You can get 3 filter kits for $30 or less
Hoya filters are an excellent choice.
Apr 10, 2009 | Fuji FinePix S1000FD Digital Camera
CD400 and IR
Check it by point the lens at an IR source, like a remote control. Click on the remote, if you can see the IR light in the LCD finder, then the camera is sensitive to IR and should work. I think it will. The specs on the CD400 is almost completely the same as the S85 (excepting the obvious differences) and it probably has a lot of the same guts.
Sep 13, 2005 | Sony Mavica MVC-CD400 Digital Camera
Fuji FinePix S5500 Digital Camera Logo
101 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
