Question about Olympus Camedia C-3030 Zoom Digital Camera
Can I leave the camera switched on for an extended period withought it going into power off. Reason is I intend to mount it on a hangglider for inflight photos and if it switches of after 30mins or so I'll not be able to switch it back on. Can someone please tell me the facts?
    Master:
  • 852 Answers
By default the 2020 switches on with the LCD 'OFF'. After a month of use I have found no way to have the LCD permanently on. Someone kindly tipped me that if you switch-on by going to A/S/M position the LCD will come on to start with. Very useful tip I've made good use of. But, to have the LCD on all the time is clearly not practical as it would EAT up battery power very quickly. Switching on either to 'P' or to 'A/S/M' gives you the LCD use but EITHER way it auto turns off after a few minutes at most. Natural power protection I guess. So far as I'm aware and seems likely the 3000/3030 are not different - well, it doesn't seem to make sense that they are, as they're much the same camera apart from CCD
Posted on Sep 07, 2005
    Master:
  • 852 Answers
• If you do not operate the camera for three minutes, the camera will be set to the stand-by mode. After four hours in the stand-by mode, the power turns off automatically. (Time varies depending on the type of batteries used.) How will you be operting the camera to take the pictures while in flight? I'm not sure if the remote needs a clear shot to the front of the camera. I'm also not sure what the procedure is to wake the camera from stand-by mode with the remote. You will probably want the LCD off to conserve battery life, and have the camera set in fully automatic mode.
    Master:
  • 852 Answers
I believe you can adjust the amount of time the camera goes in this mode
Playback switch does not operate
PDF]Camera User Guide
gdlp01.c-wss.com/gds/7/0900011217/01/PSA520510CUG-EN.pdf
Switching between Shooting and Playback.....32 .... Please note that Canon digital cameras are intended for personal use and should never be used .... Do not operatethe flash with dirt, dust or other items stuck to its lens. ..... PowerShot A520:.
Repair tips for digital cameras that won't power on. 'Do It ...
camerarepair.blogspot.com/.../simple-fix-for-dead-cameras-that-wont.ht...
Nov 30, 2007 - It was a fix for a Canon A520, but am not sure if it would work for ..... I have a Canon Powershot A540 which will not turn on and lens is stuck out extended.... (even when they are new) in camera mode and not playback mode.
Digital Cameras - Canon PowerShot A520 Digital Camera ...
Dec 02, 2015 | Canon PowerShot A520 Digital Camera
Tip
Problems with batteries
the most common problem with batteries for cameras is the type and brand name that people use in them.
buying cheaper may save you money..but those batteries are cheaper for a reason. they commonly do not hold a strong enough charge to power a digital camera for very long or even at all.
this is called the mAH rating. (milliamp per hour)
look for batteries with at least a 2000 mAH rating.
DO NOT USE: alkaline- they drain fast
nickel cadmium rechargeable-tend to have a memory effect .
you can use the following:
lithium-expensive but work
Ni-MH nickel metal hydride rechargeable- last longer no memory effects best value and most ideal type for digital cameras.
lithium ion rechargeable - best batteries to use however they are the most expensive and harder to find.
  • Insert the batteries correctly into the camera.
  • Don't mix used and unused batteries.
  • Don't mix different types of batteries.
  • Take care not to overcharge rechargeable batteries.
  • Don't leave batteries inside the camera for an extended period of time. Some batteries might leak and damage the camera.
  • Don't expose your batteries to extreme heat or cold.
on Feb 08, 2010 | Cameras
How do i shut the power off it is draining my battery
Probably shorted put somewhere, making a connection and draining your battery.
Sep 16, 2015 | Cars & Trucks
Should the water supply be isolated when the appliance is not in use
Only if it is not going to be used for extended periods of time.
Otherwise it is safe to leave it connected and the supply ON
Going on holidays would be a reason to turn it off
As a side note if you are going away for a period of time and dont have automated water systems etc then take a water reading and comopare it when you get back and if there is a difference then you might have a leak somewhere eg. toilet, faucet etc.
Nov 01, 2011 | Washing Machines
I have a casio ex-z1050 thats dead and i dont have a charger how can i power it up?
u will have to buy a new charger because casio doesn't make its camera with USB charging option. click on this link to buy a new charger.
Apr 16, 2010 | Casio Exilim EXZ1050 Digital Camera
When i start my camera it turns the light green to red and shuts off immeditaly
Green light indicates good battery strength. Red light indicates that your camera has an insufficient or low battery power level and will be automatically powered off. . To continue using the camera, please change your batteries to new ones.
Please note that:
  1. If you don’t intend to use your camera for an extended period of time, please remove the batteries to avoid battery leakage and corrosion.
  2. Do not mix old and new batteries.
  3. Alkaline batteries are generally recommended.
Feb 13, 2010 | Vivitar ViviCam 5355 Digital Camera
All the actions expect taking photos, are "jammed", nothing works. Also, when u turn the camera on, the zoom will go to its most extended position and won't return back.
The internal zoom switch is stuck in the extend position. Don't normally recommend opening the case, but in this case (pun intended) it's necessary. You'll only need to disassemble the camera enough to remove its front face. Please see this link. Only go as far as the 10th picture where the front face is removed, and as mentioned in the article, inspect that little copper plate to see if it's bent. Also read this concerning safety as there is a possibility of electrical shock.
Jan 30, 2010 | Canon PowerShot A540 Digital Camera
After inserting lens it keeps saying lens not attached
I would help to know the error message, but here is what I can tell you.
Having a "Lens error " message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day.
Oct 31, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Sputters past 1/4 idle no power
Put the bike on level ground, support on stands, switch off petrol and drain the carbs. Close the carbs and using the pipe from the tank (disconected) to the carbs fill with a quality carb cleaner and leave overnight. Drain the carbs, connect everything back up and start up. Try and get into the habit of switching off the petrol before you stop the engine, just to partially drain the carbs, esp'ly if you intend to leave for any period of time.
Dec 15, 2008 | 2005 Yamaha V Star Classic
Canon A720is turns on, but lens will not extend
I had the exact same problem. Since my camera is out of warranty, I decided to try to fix it myself; figuring the cost of repairing it would be close to the cost of a new, better camera. If yours is still under warranty, let Canon fix it for the cost of shipping.
I unscrewed all of the screws and carefully pried open the back of the camera. Part of it will come apart easily, but for the part that wouldn't, I slid a razorblade into the crack between the pieces and used it to separate the pieces.
I was shocked by what I found. The "mechanism" for switching between picture and review mode, appears to consist of a tiny black piece of something (doesn't look like metal, but I assume it's conductive). The physical switch that you operate on the back of the camera, appears to push this away from the circuit board. When that happens, the camera goes into review mode.
I assume that over time, this flimsy piece of whatever begins to wear out and eventually won't return to the circuit board. I slipped a small screwdriver under this piece and bent it back towards the circuit board.
That did the trick, The camera now functions as it's supposed to with one exception. Now, when I go into review mode, the lens won't retract (although it will when I power the camera down). Personally, I'm fine with that, because the lens going in and out is a huge waste of battery.
One thing I learned from this is that when you leave your camera inactive for long periods of time, make sure it's in picture mode, as this should reduce the strain on the flexible "switch".
Nov 28, 2008 | Canon PowerShot A720 IS Digital Camera
Olympus Camedia C-3030 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
