Question about Golden Technologies Avenger 3 Wheel Electric Scooter
Golden Technologies Avenger Bateery Problem
My grandfather is cruising on the Golden Technologies Avenger 3 scooter for a while no, lately the battery started to drain very quickly, and he needs to charge it quite often.
Any ideas on how to fix this problem?
    Master:
  • 505 Answers
Battery needs replacing when that happens.;
Regards; Aaron
Posted on Sep 16, 2008
I have a Golden Companion 2 three wheeled scooter. The motor will not engage while sitting on the ground. When I put the rear wheels up the motor engages fine and runs fine.
hi check youre batteries when u have it of the ground there is not much current drain on the batteries when its on the ground it takes a lot more current to move it......try and get them load tested.good luck
Sep 05, 2015 | Golden Technologies Golden CompanioN II -...
Chair wont charge lights not comeing on but still has 1/2 power according to lights
depending on age of unit batteries can get bad just like in a car and won't charge. auto parts store can check batteries for you, or garage
Nov 21, 2014 | Golden Technologies Avenger 4 Wheel...
My scooter will not start. The headlight and horn work.
HI,
I AM A GOLDEN TECHNOLOGIES REPAIR TECH.
SEVERAL THINGS CAN BE THE PROBLEM:
1. BATTERY CHARGER CAN BE BAD
2. THROTTLE POT OR SPEED POT CAN BE BAD
3.IF THE FREE WHEEL LEVER IS NOT ENGAGED THE SCOOTER WON'T RUN
4. IF THE CHARGER CORD IS PLUGGED IN IT WON'T RUN
5. FINALLY IF ALL THOSE ITEMS ARE OK YOU HAVE A CONTROLLER PROBLEM, WHICH IS THE MOST LIKLEY PROBLEM...THATS COSTLY
YOU CAN GET HELP BY LOGGING ON TO GOLDEN TECHNOLOGIES.COM AND ENTERING YOUR AREA CODE TO GET LOCAL PROVIDERS TO HELP YOU. OR CALLING 1-800-624-6374
GOOD LUCK
TIM
Apr 27, 2011 | Golden Technologies Companion II Travel...
The motor is screeching and barely moves. Started periodically, now is constant. Drains fully charged battery within minutes.
When the motor is screeching and draining the battery, that indicates that the motor has most likely seized up and is not turning the axle properly, which in turn will drain the batteries quickly as the scooter struggles to move. I strongly recommend discontinuing use of the scooter for your safety until the motor can be replaced; contact the manufacturer for a service call to fully diagnose the problem and give you a quote. If your insurance purchased the scooter for you, they may partially pay for the repair.
Dec 19, 2010 | Golden Technologies Buzz Around 3 Wheel...
Battery fully charged,horn works but no power to drive wheels
Make sure your freewheel brake is in the DRIVE position. Check your owner's manual for the location of the free wheel lever, ususally it is near the rear of the scooter. If the chair is in DRIVE mode but the wheels will not turn, you may have a motor problem which would require replacing the motors.
Oct 11, 2010 | Golden Technologies Avenger 3 Wheel...
WIRING DIAGRAM FOR A PEP-PAL FROM MEGA MOTION CONTROL ON THE POT.
New batteries, scooter will go in reverse, but doesn't want to go forward,what should i do?
Sep 07, 2010 | Golden Technologies Avenger 3 Wheel...
My four wheel golden electic scooter is fully charged but went from fully operational to just clicking and not moving at all. Can you help?
Hi. I have had this problem on many machines. It is normally a stuck brush in the motor. This stops the motor from going. The click you can hear is probably the brake solenoid releasing.
Can also be a faulty connector in the motor or battery leads.
Good luck. Neil.
Jun 09, 2010 | Golden Technologies Avenger 4 Wheel...
Golden avenger goes very slow with good batteries
hi,
ok so you're sure the batteries are ok, and the charger is charging the batteries ,
check the battery connections on the terminal are not loose , they must be tight but don't overdo it,
are the brushes ok ? do they move ok within the motor ? sometimes they can stick therefore you lose power and speed,
Lastly but can cause problems is the speedpot, does it have a lot of up and down movement ? you will be suprised the problems they can cause.
~Regards
GeWiz.
Dec 05, 2009 | Golden Technologies Avenger 3 Wheel...
Sudden stops
Sounds like the brake. Ohm chech the brake (it is attached to the end of the motor). It should be around 35 ohms
Jan 04, 2009 | Golden Technologies Avenger 3 Wheel...
Golden Technologies Avenger 3 Wheel Electric Scooter Logo
151 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
