Question about ASUS EN7600GT/2DHT/256 (256 MB) PCI Express Graphic Card
Distorted images Hi, I have an ASUS EN7600 GT card. I have got it replaced twice already due to distorted images. The distorted images started when i boot up and it won't even let me enter windows startup before dying and my screen goes into sleep mode. Twice I have replaced with a repaired card and both replaced cards died within 1 weeks of replacement with exactly the same problem. I have been using the card for almost 2 years before this problem surfaced. I have running it on a MSI P965 motherboard. Is it a computability problem?
  • 37 Answers
Sounds more like a problem with the drivers and/or the settings for resolution or refresh rate, have you tried to boot into safe mode and uninstall the drivers ? Also when you do this you may want to use a regisrty cleaner to remove all traces to the drivers in your registry as some driver do not remove all trace from the registry upon uninstallation.
Posted on Aug 29, 2008
Hi i replaced my bulb for Sony VPLBW5 now i am not getting a clear picture anymore, its very distorted and something seems very wrong
It's very unlikely that this is a due to a faulty bulb.
It's possible that there is a fault with the projector which existed before you relamped it, (i don't know the exact circumstances) but you could try the following steps
1) If the old lamps still works, remove the new one and replace it with the old one. fire the projector up and see what happens. If nothing happens replace the new one again, making sure you don't touch any glass parts (as it can shorten lamp life) or any other internal parts.
2) Turn the projector on and check the image with different picture sources and cables to rule out a fault there. Is the image distorted while the projectors warms up and displays the startup screen? If the image looks correct the problems is likely to be outwith the projector. If the startup image is distorted then the problem is likely to be with the projector.
You should ensure that the lens is free from obstructions. It won't make much difference in most instances but you could clean it with a soft cloth, taking care not to damage it.
Hopefully these steps will help you fix the problem.
Feb 18, 2011 | Sony VPLBW5 LCD Projector
Distorted picture.
Is the menu text clear on the screen, when it's focused correctly. Or is that also distorted.
If the menu text is OK then the picture signal is dodgy. could be due to a bad earth lead on the video cable.
Is it distorted on all signal inputs
Oct 30, 2009 | Panasonic PT-LB20U Multimedia Projector
Sony DSC-t33 lcd monitor is distorted.Pictures
It's a faulty CCD imager - a very common problem with the T33 - the imager has to be replaced. You can buy it from and replace the CCD yourself (ask seller the instructions).
Oct 10, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Distorted images on LCD and memory card
Yes, it's a CCD problem - a well known problem with the A95. You should contact Canon - they used to offer a free replacement of CCDs for these cameras.
Sep 26, 2009 | Canon PowerShot A95 Digital Camera
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I want to download a suitable driver for my unknown graphics card
You need to know what graphics card is in it. I think it is either a ati or geforce. go to asus website. look for support and find the drivers for it click on this website .
Good luck
May 26, 2009 | ASUS EN7600GT/2DHT/256 (256 MB) PCI...
Scanner working wrong
Distorted images with lines present from scanned pics arises when the power supply is already below the rated output voltage or regulated power supply is defective. try fixing the power supply section but check if it still have a correct output voltage, or replace the power supply with a new one if the power supply of your scanner is a plug in type, or try to plug the scanner somewhere else in your place... hope this help :-)
May 24, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
IRC3200 - Color Printing Distorted
check your counter if already reach 2k
its means you need to replace the itb belt or assy
any question just leave a message
May 21, 2009 | Canon imageRUNNER C3200 Copier
Distorted picture and graphics
it means the resolution of the photos that you have downloaded is small . and when you zoom it , it get distorted .
so try downloading large resolution images .
minimum resolution should be 800 * 600 for good quality ..
Mar 15, 2009 | Computers & Internet
LCD screen & viewfinder are being distorted
Failing CCD- if less than a year old return to vendor. If more than a year old contact Canon This may be eligible for free replacement- due to a faulty batch of chips that were in circulation used my many makers,
Oct 01, 2007 | Canon PowerShot S1 IS Digital Camera
ASUS EN7600GT/2DHT/256 (256 MB) PCI Express Graphic Card Logo
145 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
