Question about Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only
How to prime my Pool?
How do I prime my pool?
  • cleartec1 May 11, 2010
    need help to prime pump
    President:
  • 2,712 Answers
Prime is the term we use to state that the air has been mostly purged from the pump and the pump is moving water. When you have lost the prime, your pump is no longer pumping water through it. Sometimes it can be very difficult to regain the prime on the pump. This will tell you how to get the prime back in these difficult situations
Posted on Aug 27, 2008
    Problem Solver:
  • 11 Answers
Open the top, dump water in it while it is turned on. If it is struggling to pull water through, you may have a clogged impeller. If not let it prime and when it starts pulling water through quickly, put the cap back on quickly.
Posted on Feb 14, 2009
    Problem Solver:
  • 15 Answers
Sometimes my pump will loose prime and the number one problem i found is my lid on my strainer basket connected to the pump was to tight...go figure but when i loosened it a lil it started to pump....also sometimes if your water level is low then it takes time to fill up in the skimmer and it will loose prime that way so make sure u have adequate amount of water in your pool.
Posted on Jun 28, 2010
4 Suggested Answers
  • 4 Answers
SOURCE: lost prime
Turn off the pump at the timer and remove the lid to your pump where you empty the debris from the basket. Get a hose or bucket and fill that resevoir with water and get the lid back on as quickly as possible. Turn on the pump and it should start to prime. On the filter, there is a air relief valve. Depending on the filter, it will pinch and twist, or there is a knob to uncrew. Doing that as the motor is running allows tbhe air that has built up inside to puge out. Once a steady stream comes out close the relief valve. May need to tryh it more than once.
Posted on Dec 07, 2008
  • 79 Answers
SOURCE: my intex pool pump is surging and won't stay primed???
i think its pump side first as its easier to push water through a filter rarther than trying to **** it , Also the only reason it could loose its prime is through air getting in the system.
Posted on Jun 06, 2009
MOTORWIZJ
  • 1368 Answers
SOURCE: how do you prime the pump for intex ubove ground
THIS HAS PRESSURE ON THE PUMP WHEN IT IS HOOKED UP TO THE POOL , NO PRIMING IS NEEDED. NOW IF IT'S HIGHER THAN THE WATER LINE OF THE POOL THIS KIND OF PUMP WILL NOT WORK , YOU NEED A PUMP THAT HAS A HAIR BASKET . THESE YOU FILL THE BASKET UP AND REPLACE THE LID AND YOU PRIMED IT.. . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
My swimming pool pump is loosing it's prime
is there enough water in pool sometimes skimmers suck air also check the intake union of the pump you have a leak in one of your intake lines
Jul 12, 2014 | Pool & Spa
How to prime an A O Smith pool pump
if the pump is higher than the pool, you should have a ball valve at the front of the pump. close this valve, fill pump housing with water. close the system, open the valve and turn on pump. if the pump is below the pool level, you shouldnt have this problem.
Jun 27, 2014 | AO Smith Pool & Spa
Prime
Hi to prime your pump you fill the strainer basket with water and make sure all connections are tight with no leaks. Once you seal the lid turn on your pump and it should prime. If you have an issue you can force water through the suction line by putting a hose in the skimmer and force the water through your suction line. Time to Open the Swimming Pool
Jun 06, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
Not self priming itself. when it turns off the water pushes back out of the skimmer and pushes the basket up. it loses water and the pump cant re-prime itself.
PRIME PUMP, OPEN AIR VALVE ON FILTER. OR TAKE THE LID OFF YOUR FILTER AND SEE IF IT STARTS TO PUMP... YOU DO HAVE IT PLUMBED RIGHT? THE PIPE COMING OUT OF THE PUMP GOES TO THE FILTER !! I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Aug 28, 2010 | Waterway Inground Pool Pump Champion No....
Can you bypass the heater so pool can prime
The pool return pipes are connected to the heater with pipe unions. You could get a set of unions to match them and make a "U" shaped pipe section to bypass the heater. using a couple of 90's and the unions .
May 31, 2010 | Jandy Laars Lite2 Ld 400,000 Btu Heater
How do you prime the pump for intex ubove ground
May 23, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
My Jet Pump Looses it's prime at night.
I assume the pump is not running at night. If the pump is higher than the pool, and the inlet and outlet to the pool are both under water, then you have a small leak. This could be allowing the water to leak out of the line. Or, if the leak is higher than the pool surface it is allowing air to leak into the line, which allows the prime to run down into the pool. If you found this useful, please vote. Thanks.
Feb 16, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
May 25, 2009 | Jandy PHP High Head Pump 2 HP Up rated
Can't get pump to prime
Is this the first time starting up this season? 1. Make sure pool level is up. 2. Check lid gasket and coat with silicone based lube. 3. Try to fill skimmer or drain line as much as possible. 4. If there ara two suction lines coming in then try to prime pump on just one of them. Gradually open second valve after prime is achieved. 5. If pump sits more than two feet above pool level then you will have to allow ample time for priming (it may take a couple of minutes).6. Make sure strainer drain plug threads are taped up. 7. If able to, try priming through another line.Good Luck
Apr 22, 2009 | Pool & Spa
Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only Logo
1,696 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
