Question about Intex 4000 GPH Filter Pump
Pumps safety tips
Are there anty safety tips?
    President:
  • 2,712 Answers
As you know, water and electricity don’t go togather. Make sure to install it right and avoid using it while there is someone in the pool.
Posted on Aug 27, 2008
What is best temperature setting for water heate
120°-125F is safest temperature.
Typical bath-shower is 104-110°F but rarely higher.
130°F can burn the skin in about 1 minute
Serious burns occur in seconds with 140°F and higher.
Use a cooking thermometer to check temperature coming out of tap ... if hot is slow to arrive and never seems to arrive, make sure all single handle faucet cartridges are up to date.
Following link has additional safety tips:
http://waterheatertimer.org/Water-heater-safety-precautions.html
Oct 20, 2017 | Water Water Heaters
Tip
Pressure washer
I have repaired hundreds of pressure washer pumps.( Winterizing)Always tip up pressure washer to get out most of the water.Then purchase pump armor.This is like anti-freeze.If not available use light weight oil.(mineral oil is o.k.Tip back washer and pour a little in.Then pull motor start cord a couple of times and your safe for the winter.
on Oct 17, 2010 | Garden
What is this silver piece in my microwave? what is the result of using the microwave without this piece?
hi..
"Iron with aluminum soleplate quickly smoothes out wrinkles"
product overview...
- Combining a simple, classic design with an array of modern conveniences, this powerful iron quickly and easily smoothes out wrinkles. The unit's fabric-select dial and convenient fabric guide make it easy to choose the right amount of heat needed for the job, while its aluminum soleplate creates crisp creases and comes with a pointed tip that works well for getting into pleats, between buttons, and along seams. Other highlights include an "on" indicator light, a thumb-activated steam-surge button, an anti-drip system that prevents water spotting at low temperatures, a pivoting cord, and a stable heel rest. For enhanced safety and peace of mind, the iron will shut off automatically after 30 seconds of inactivity if left on its soleplate or tipped over on its side; if left vertically on its heel rest, it will shut off after 8 minutes.
  • Iron with aluminum soleplate quickly smoothes out wrinkles
  • Fabric-select dial and convenient fabric guide
  • Thumb-activated steam-surge button; anti-drip system prevents spotting
  • Dry-iron option; pivoting cord; stable heel rest; 3-way auto safety shut-off
  • Full-range fabric/temperature settings
  • Power indicator light
  • Button groove
  • Pivoting cord
  • 2-year limited warranty
  • Note: Product may vary by store
  • Home Depot Protection Plan:.
Nov 14, 2015 | Black and Decker USA Black & Decker F67e...
What does EFO mean
Its an anti flood warning. generally it means something has leaked into the cabinet and water has triggered the safety float on the floor of the cabinet. You will probably find a small leak somewhere which has allowed water to gather under the machine. IE/ Hose, front gasket, pump etc.. If you tip the machine backwards to drain all the water out of the base, it will probably work until the safety switch triggers again. Locate and fix the leak before it gets worse and causes some damage.
Mar 08, 2015 | AEG Washing Machines
MY HEATER STAR RUNNING AND AFTER A MINUTE STOPS
These appliances are equipped with safety switches to protect against overheating and fires. Check that it is level and not tilted. The fan must also be operational. Based on the limited information provided, I can only offer these suggestions.
Dec 06, 2013 | Heating & Cooling
Fault PP
a leak which has activated the flood safety in the base, you can check this by pulling the machine onto a towel and tipping the whole unit forward ie raise the back of the machine off the floor so it is pivoted on the front feet at approx 45 degrees, if water runs out from under the machine you have a leak (the machine may well start to work again now but you need to trace the leak or it will reoccur as soon as the safety is activated again).
Mar 19, 2013 | Bosch Dishwashers
Changed tank on my grill now nothing
When swapping out tanks use caution to not open the valve too far or too fast. The new tanks have a anti tip safety in them that can trigger if the valves are opened too much or too fast. remove the tank. open all valves on the grill close all of them and reconnect the grill. Open the valve only slighly very slow. retry. What is fer supper when do we eat?
Aug 25, 2012 | Char-Broil Grilling
How much antifreeze and water to put in a Suzuki RM80
50/50 anti-freeze and distilled water. Use only dex-cool style anti-freeze with no silica particles. Regular anti-freeze with silica can damage the ceramic washers found in some motorcycle water pumps.
Dec 01, 2010 | Suzuki RM 125 Motorcycles
BMW 86 L7 key turns on all the lights on various gauges but the car does not turn over. Replaced the starter but still the same problem. Could it be an anti theft switch, or electrical problem? Help.
yes, if the security light is on, it would be the anti-theft system. If no light, maybe it's the safety interlock. Try starting in neutral or giggling the shifter. If neither of these, please see my tip at http://www.fixya.com/cars/r6222268-engine_doesnt_crank_turn_over . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Oct 28, 2010 | 1986 BMW L7
Dishwasher pumps even with power off
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Mar 28, 2010 | Viking 24 in. Professional Series VUD040...
Intex 4000 GPH Filter Pump Logo
125 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
