Question about Hayward 2 Hp Max-Flo Swimming Pool Pump Sp2815x20
Pumps Capacity? what is the capacity of the pumps?
    President:
  • 2,712 Answers
# Aboveground filter systems and small inground pools (under 10,000 gals) should use a Low Head pump like a Maxim, or Dynamo or Power-Flo. # Pools from 10,000-20,000 gals can use a Medium Head pump like a SuperPump, a Pinnacle or Cygnet. # Pools over 20,000 gals could possibly use the High Head pumps like, Super II, Challenger, Ultra-Flo or the Sta-Rite pumps. # Pool/ Spa combos with at least 3 lines influent and 2 - 3 back to the pool, 2" plumbing may be able to handle the Ultra High Head pumps like NorthStar and the WhisperFlo
Posted on Aug 27, 2008
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
What is capacity in cubic foot?
  • How to Calculate the Capacity of a Washer Tub - About.com Home laundry.about.com > ... > Selecting a Clothes Washer 2016-04-14 · Video embedded · How to calculate the capacity of a washer tub ... your washing machine ... listed in cubic feet. A regular capacity machine is between 3.1 ...
  • Washer buying guide - CNET www.cnet.com > Appliances > Washing Machines 2013-09-12 · Washer buying guide. ... They have a smaller wash capacity, averaging at 1.5 cubic feet, ... What washing machine capacity do I need?
  • Washing machine capacity in cubic feet ... - Yahoo Answers https://answers.yahoo.com/question/index?qid=20121014130558AA2ph3V
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2012-10-14 · Washing machine capacity in cubic feet what does this mean? ... What does DOE stand for in regards to a washing machine's cubic feet?
  • Washing Maching Buying Guide - Warners Stellian ... www.warnersstellian.com/washer-buying-guide washer buying guide: ... Most conventional top load washers range between 3.2 and 3.5 cubic feet. ... The majority of washing machines are 27? wide, ...
  • What Should I Know About Washing Machine Capacity? www.wisegeek.org/what-should-i-know-about-washing-machine-capacity.htm What Should I Know About Washing Machine Capacity? ... A load of synthetic fleece sweaters will take up many cubic feet while not weighing as much.
  • What is the cubic foot capacity of my Kenmore washing ... www.shopyourway.com > Manage My Life > Questions 2009-09-21 · What is the cubic foot capacity of my Kenmore washing machine, model number 110.82984110? Report This by Manage My Life. September 21st, 2009.
  • Geeks On Home: What Is the Standard Cubic Feet for a ... www.geeksonhome.com/info_12199449_standard-cubic-feet-washer-dryer... What Is the Standard Cubic Feet for a Washer & Dryer?. ... What Is the Water Capacity for a Washing Machine? How to Measure Cubic Feet. How to Find the Capacity ...
  • Geeks On Home: Washing Machine Capacity Guide www.geeksonhome.com/info_12116692_washing-machine-capacity-guide.html Washing Machine Capacity Guide. Washing machines turned the chore of washing clothes by hand into an ... They typically have between 3 to 3.8 cubic feet of washing ...
  • May 04, 2016 | Washing Machines
    12 x 20 x 54 container capacity of water
    If the units you are using are inches, then the capacity is 46.8 imperial gallons. I believe that is about 58 US gallons.
    Apr 07, 2016 | Pool & Spa
    I would like to know the coolant capacity on a 1996 bmw 318ti
    Engine lubricant oil capacity: 4 liter / 4.2 U.S. qt / 3.5 imp. qt with filter change Engine coolant capacity: 6.5 liter / 6.9 U.S. qt / 5.7 imp. qt Fuel tank capacity: 65 liter / 17.2 U.S. gal / 14.3 imp. gal Transmission oil capacity: 1 liter / 1.1 U.S. qt / .9 imp. qt Final drive oil capacity: 1.1 liter / 1.2 U.S. qt / 1 imp. qt Battery capacity (Ah): 50 Spark plugs: Bosch F7LDCR, NGK BKR6EK
    Mar 03, 2015 | 1996 BMW 318
    Engine on but do not pump water
    Be sure the inlet and outlet lines are clear. This has a limited suction lift 23' max, be sure you are not exceeding that or the maximum head. each foot is 0.433 Psig so 98 * .433 = 42.43 PSIG.
    Specifications Type Self-priming/Centrifugal Caliber 2 in. Maximum Capacity 160 gal / min Total Head Suction Head Self Priming Time 120 sec / 16 ft Engine Type Air-Cooled, Four-Stroke Rated Horsepower 4.0 @ 4,000 rpm Bore x Stroke 56 x 50mm Displacement 123cc Cooling Forced Air Lubrication Splash Oil Capacity Starting Method Recoil Ignition System Transistor Controlled Dimensions Fuel Tank Capacity 1.2 gal. Recommended Fuel Unleaded Regular Dimensions (LxWxH) Dry Weight A-20070116-1378-130-E
    Dec 08, 2013 | Yamaha YP20G Water Pump 2-Inch, 160 GPM...
    We have a new honda gx390 pressure drain cleaner with bertolini pump we can not get max pressure to the hose can you help
    Assuming that you have a pressure gauge to determine actual system pressure. Without pressure gauge, you could use the sound of the engine as test for capacity pressure (if engine and pump are paired correctly, engine will labor at full throttle under high pressure). Using your machine at rated capacity will decrease the life of the unit. Better to use at 75 ~ 80 percent of cap. (2500psi on your unit). Pressure is developed thru the restriction of the tip/orifice assuming that the pump is working correctly. Tip should be correct for the capacity of the pump. Check the pump capacity for gpm (or test by removing tip connect water supply, then with engine running, catch water in bucket for exactly one min. and measure quantity). Example, 4 gallon per minuite should use a tip with 4gpm markings. If wrong tip size is used, (too large, low pressure, too small, pump will go into unload condition resulting in low pressure) . If thru testing you determin that the correct size tip is installed, suspect valves or unloader. Leaking valves or orings that seal valves will cause low pressure and also cause a pulsating sensation. Worn unloader will cause pressure to rise and fall in a slow cycle. Good luck with your repair
    Apr 26, 2011 | Honda Pressure Washer PSI 3000
    What ton is the R-410A packaged heat pump
    R-410A is a type of refrigerant and not a capacity rating of an air conditoner. 12,000 Btu's equals a 1 Ton of cooling capacity.
    Sep 29, 2010 | Heating & Cooling
    My MayTag performa oversized capacity washer wont spin
    Usually this is caused by the pump being cloged or broken. Remove the pump and clean the pump out. Make sure it spins freely by hand.
    Nov 20, 2008 | Washing Machines
    Hayward 2 Hp Max-Flo Swimming Pool Pump Sp2815x20 Logo
    271 people viewed this question
    Top Hayward Pool & Spa Experts
    Jay Finke
    Jay Finke
    Bill Jordan
    Craig Butler
    Craig Butler
    Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
