Question about Saunacore Special Edition Residential Sauna Heater
Pool and Spa Heaters pros and cons
What are the pros and cons of an electric heat pump versus a natural gas pool heater?
Firstly, the water volume in a pool is huge, so heating them need big amount of energy: fuels or electric, which is up to the kind of water heaters the pool owner use. Secondly, the water temperature requirement is not high:less than 30 C degree will be OK. In other words, the terminal temperature of heat pumps (if used for pools) will not be too high. These two reasons bring the application of heat pumps for swimming pools. In fact, you will say "what an ideal product designed for pools" when you know the performance of this kind of products. The COP of swimming pool heat pumps reaches 5, which means 1 electric can bring 5 heating energy. The number of traditional water heaters (broilers or electric water heaters) will not be more than 1. Nowadays, swimming pool heat pumps are popular in many Europe countries. People install them for pools of their houses. Of coures, more and more pools in gym are also heated by heat pumps. Even in aquaculture farms, heat pumps are installed for fishes, for they need stable and warm water to grow quickly.
Posted on Aug 17, 2012
  • 4 Answers
Water heating is a thermodynamic process using an energy source to heat water above its initial temperature. Typical domestic uses of hot water are for cooking, cleaning, bathing, and space heating. In industry, there are many uses about hot water heat pump .
Domestically, water is traditionally heated in vessels known as water heaters, kettles, cauldrons, pots, or coppers. These metal vessels heat a batch of water, but do not produce a continual supply of heated water at a preset temperature. Rarely, hot water will be naturally occurring, usually from natural hot springs. The temperature will vary based on the consumption rate of hot water; the water becomes cooler as flow is increased.
Appliances for providing a more-or-less constant supply of hot water are variously known as water heaters, hot water heaters, hot water tanks, boilers, heat exchangers, calorifiers, or geysers depending on whether they are heating potable or non-potable water, in domestic or industrial use, their energy source, and in which part of the world they are found.
Posted on May 31, 2012
  • 2,712 Answers
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Posted on Aug 27, 2008
What are the pros of Marey Power Gas Tank less Water Heater?
The pros of the Marey Power Gas Tank less Water Heater are as follows:
1. Available in propane and natural gas
2. DIY installation process optional
3. Very reasonably priced Does not use electricity but does require a 2 D-Cell battery
4. Only uses gas, when water is turned on (decreases natural gas wastes)
5. Equipped with easily adjustable gas and water knobs
6. Digital display makes it easy to read water temperature
7. Very compact design
8. Works great with low water pressure levels
You can have more information about it like how it works and installation process etc.
Jun 23, 2017 | Water Water Heaters
My pool heater does not run,I turn it on and I get a Flow sign and the pump does not run
It would be a big help, if you assist us who would like to help you! Provide more information, be more specific. What heater manufacturer and which model and are you using natural gas or liqu it would be a big help, if you assist us who would like to help you! Provide more information, be more specific. What heater manufacturer and which model and are you using natural gas or propane?
is it a furnace style heater, or is it a heat pump?
otherwise anybody who decides to assist you, is only guessing.
May 19, 2015 | Pool & Spa
Air flow
At 95 I assume you are heating a Spa. I am only heating a pool but I found my answer to same error code was related to reduction in water recycle when my scimmer fap became stuck preventing free flow of water. I would check to see that you don't have some obstruction in your pumping system. A second check might be to make sure your electrical connection to your thermostate is not loose or corroded which might cause the thermostate to not register proper temperature settings.
Jul 12, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
My raypack heater cycles on and off with a big bang each time it tuns on
It may be due to gas "pooling" before it ignites. Check that the pilot assembly is correctly positioned, and the burners and heat exchanger are clear of soot and debris.
Mar 16, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
CLK code will not heAT
Not sure about your specific heater, but if the heat won't go on, it could be the water pressure sensor or one of the temperature sensors.
May 05, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Blows thermal fuse on raypack heater?
If you are talking about the "Roll out sensor" located on the lower left hand side, you have a problem with ventilation..Soot,debris, or possibly a rodent nest on the heat exchanger (Located just under the top cover of the heater). If it is electrical, you may have a bare wire touching the heaters housing (somewhere inside) causing a short. Rodents love to chew the insulation off low voltage wiring.
Oct 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My pool heater suddenly stopped working. It sparks, it calls for heat but then I get a ILO ignition lock out reading. Can this be fixed? please advise. Thanks
Propane...Make sure you have 30% in the tank (and the valve is open on the correct tank). Natural gas...You may have carbon/debris on the ignitor.
Sep 26, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Saunacore Special Edition Residential Sauna Heater  Logo
432 people viewed this question
Top Saunacore Pool & Spa Experts
John B
David Spradling
David Spradling
Jack Evans
Jack Evans
Are you a Saunacore Pool and Spa Expert? Answer questions, earn points and help others
