Question about Hayward Sp2805x7 Max-Flo 3/4 Hp Swimming Pool Pump
What Horsepower my pump motor is?
How do I know what Horsepower my pump motor is?
    President:
  • 2,712 Answers
The horsepower should be listed on the nameplate (left) of the pump motor (in very tiny letters - hp). If the motor nameplate is burnt or worn off, sometimes a part number of the impeller (right) can tell us which hp your pump motor is.
Posted on Aug 27, 2008
How do I tell what horsepower wet end pump do I need on my eon spa
Use the information on the motors label.
many times the horsepower and the service factor are not visible because it is intentionally left off. Use the code number or the model number to identify the horsepower with the manufacturer.
Feb 24, 2015 | Pool & Spa
Can I replace my waterway wet end pump model
its not adviseable to go down in Hp (4 to2 )of a pump motor all your jets are not goiing to proform correctly
Aug 26, 2014 | Pool & Spa
Zoeller m267-f pump has power going to the motor but will nut run
Does it have a float switch? Does the motor run when you lift the float switch? If not... then the motor's gone.
Jul 23, 2014 | Zoeller Sump Pump with 25 foot cord 2" 1/2...
I have an 11 year old Jacuzzi Magnum Force 1227 pool pump model 15UMFS. I want to replace it, but don't know how many horsepower it is. Can you tell me?
Probably 1.5 HP but if you can read any of the nameplate data on the motor it would be helpful to confirm. A better approach might be to size the new pump to the volume of water in the pool.
If all you are going to replace is the pumps motor then can you provide at least the amp ratings off the motor? Those should help verify what your old unit's horsepower really is.
John
Apr 14, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
I have a older spa with a Sta Rite pump motor. Without removing the damaged pump I was able to see the model number of the pump through a mirror. I beleive it reads K48M5A3, is there any way that you can...
That would definitely be the model number. The K indicates Capacitor start and run, the 48 indicates the frame size, and the "M" indicates horsepower (1.5 hp, in your case). If your replacing the motor, make sure you get the same Horsepower and Service Factor ratings. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 12, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Have a 12 lengths mechanical deep well, run by a 3HP US Motor. Wants to change the motor to a 1.5 HP to save on power. Tried this but the motor heats up. I presume I have to change the pulley size and or...
Thank you for posting your question here on Fixya.com.
No one can answer that for you without knowing information about the actual installation. In short, you can not lower the horsepower without dropping the load. If reducing the speed of the pump lowers the load enough you could then use a smaller drive motor but the pump will deliver less product as a result. Using a pump curve you should be able to calculate the reduced head from slowing the unit down and the horsepower required at that point of the pump curve. Size the motor accordingly. As a rule though, I doubt you could drop to half the horsepower and still operate the pump on its curve. You may need to put a 2 hp on it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 12, 2010 | Plumbing
I have a motor running 3450 rpm 230 volt 9.6 amp what is my horsepower?
Ok, but I need to know a few things;
Single phase motor or 3 phase motor?
What is the % efficiency?
Feb 17, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Ingersol rand model 3000, serial no 9835350,size 5.5"&5.5"&4"x4",would like to know pumping capacity per/min
If the motor is a 20 horsepower it is pumping app. 80 cubic feet per minute . Here's a good rule of thumb 4 cfm per horse power.
Aug 05, 2009 | Air Tools & Compressors
Spa tub motor need replacing
I havent seen to many motors this old, but today all you really need to know is the horsepower and the frame (either round or square). Pull the old one off and take it to a pool store, and they can probably get it for you.
Also..im not sure but i think A.O. Smith bought out magnetek some years back....
Mar 30, 2009 | Pentair Ultima Series Pump Part Heat Sink...
Air Compressor question
No, When an air compressor is built, it requires a motor or engine to power the process of producing air. The horsepower is not the only component of the equation. It has to be combined with the compressor pump that it runs to produce the air needed. The bigger the horsepower does not necessarily mean more air. Remember to keep your required cfm in mind. Horsepower does not make you work more efficiently, but horsepower working in unison with a quality pump that produces enough cfm for your needs. Make sure when shopping that you look for the running horsepower and not the peak horsepower you get at startup. Some manufacturers have falsely advertised or implied the peak horsepower to be the normal run horsepower. At start-up, there is a surge of power needed to start the motor and can be 1.5-3 times the amount of running power needed. This means the horsepower need for the motor peaks as well, but then drops back down to normal. Many of these manufacturers are involved in a class-action lawsuit for misrepresentation. They have used man’s machismo of “the more horsepower, the better” to their advantage to make sales. These aren’t cars we’re talking about!
Aug 27, 2008 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Hayward Sp2805x7 Max-Flo 3/4 Hp Swimming Pool Pump Logo
214 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
