Question about Raypak REFRACTORY KIT
Why frequently relight my pilot?
Why do I need to frequently relight my pilot?
    President:
  • 2,712 Answers
Check for water run off from above or sprinklers directed at heater. A high wind stack may be needed due to heater location. Millivolt models have a thermocouple or pilot generator that may be faulty or weak. Loose or rusty connections of the thermocouple to the gas valve or loose coil connection, or short in these wires can shut off a pilot.
Posted on Aug 27, 2008
H150 will not light
Posted on May 24, 2009
The LX doesn't have a pilot light, it is direct ignition and lights with a ignitor.
Posted on Oct 13, 2008
2her is pilot light on remeha avantaplus boiler
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
Jan 13, 2016 | Water Heaters
Maytag gas dryer not heating
First make sure you have gas, then open lower section of this dryer you shoul see screws you will see a place to relight the pilot , if you smell gas before doing anything then stop your repair, see if the pilot is lit then push the red button and hold it relight pilot hold this button for a few min's after it relights, if it dosent relight check power goign to gas valve near pilot . Gas units have very little problems you may have just lost gas pressure and need to relight it , let me no ! what you see and we wuill go from there
Jul 27, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Kitchenaid stove top (17 years old) pilot light is out. How can I relight it?
To relight it you need to pick up the top from the front and then relight the pilot that is in the center between the burners with a match or a lighter...
heatman101
Apr 23, 2011 | KitchenAid Microwave Ovens
Best way to relight the pilot without peezo ignition duct heater
You need to hold down the pilot button all the way down (turn selector to pilot).
When pressing the pizo count to 5 then press and repeat. It you just click it constantly you will lose your mind.
Jun 07, 2010 | Dehumidifiers
Pilot light is out need to relight it but do not know where it is located
The pilot is located in the bottom of the stove, you will have to remove the bottom drawer, and you will see the pilot in the back, you can relight it there, if there is no bottom drawer you will have to remove the bottom cover inside the oven and this is the location where you can relight the pilot.
Jan 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
Lochinvar water heater model LTN040G. Can't move dial from "on" past "pilot" to "off" to relight. Seems like there must be something I need to do to make it move, but can't figure it out.
The valve should be able to be depressed at the pilot setting and as you slowly depress it you should get it to move past pilot to off. You do not however need to go to off. You can go back to pilot and relight it and go back to on.
If it will not relight and will not go back to off it sounds like the valve is damaged internally and will need to be replaced.
Aug 07, 2009 | Pool & Spa
Pilot light gone out
My pilot light also just went out on my water wizard 13P when you relight ensure all buttons are equal in height or none depressed then hold far left button down whilst striking ignition button till pilot light ignites keep left hand button depressed for a further 3 seconds after pilot light has ignited I hope you have hot water then
May 22, 2009 | Audiovox Bosch 718 World Cellular Phone
Where is the pilot light located
your unit dioes not have a pillot that would need need relighting, it instead uses a glow bar ignitor. auto pilot.
Dec 15, 2008 | Frigidaire FGB24L2A Gas Single Oven
Relighting the pilot for a rudd heating and air
I dont know of any manufactor that makes a stand alone pilot anymore. (pilot you have to lite). The pilot should lite itself when you turn on the heat.
Sep 24, 2008 | Heating & Cooling
Raypak REFRACTORY KIT Logo
857 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
