Question about Raypak DOOR ASSEMBLY
Pool heater Maintenance
How to keep my pool heater in good shape?
    Problem Solver:
  • 11 Answers
It is vitally important that your water chemistry be maintained. Pool water that is acidic or alkaline will attack your heater's internal components in a relatively short time. A monthly (minimum) analysis by a reputable pool store will help you maintain proper water balance and extend the life of everything in your pool, be it pumps and equipment, ladders and handrails, marsite, paint or vinyl liner.
Posted on Jan 03, 2009
  • 2,712 Answers
Pool Heater Maintainance - Gas Pool Heater Gas heaters are the most common type of pool heaters being used presently. The gas heaters work on natural gas or propane tanks. The gas heaters are favorite hide out of spiders and other insects. It is recommended to regularly clean the spider webs and the debris off the heater. For it can clog off the burner openings. You can clean them manually or with the help of a vacuum cleaner as well. The most important thing about maintaining the gas pool heaters is to check the gas supply regularly. Check out the pipes to detect any leakages. You can easily detect the leakages using a soap solution. Prepare a liquid dish soap and warm water in the spray bottle. Now spray the solution on the pipe joints. If you find any bubbles emerging from the surface, you immediately need to repair the pipes. Never use the heater until the pipes are replaced or repaired by a qualified plumber. Pool Heater Maintainance - Electrical Pool Heater Electrical pool heaters are also getting popular these days. The heaters produce the heat with the help of heating elements. The element can get coated with certain minerals present in the atmosphere. This hampers the heating process. You can easily take it out and clean with a wire brush. Some elements get damaged beyond repair. You have to replace the element. Take along the old element with you while looking around for a new one in the market. It is absolutely vital to change the element otherwise it can send some current in the swimming pool. First of all, turn off the power supply to the heater to avoid any injuries. Open up the drain pipe and take out water from it. Fix the new element and test the heater by filling water in your swimming pool so that the heater can work to its full efficiency.
Posted on Aug 27, 2008
    New Friend:
Keep in mind that even with gas heat it usually takes 24h to warm the pool, so you don't turn on the heat and hop in. For a pool that isn't used every day (or almost every day), an active heating system can be a waste of money.
If you don't use the pool all the time, I would consider something that is more "passive". Solar Heaters are pretty cheap, and the energy cost is basically zero. However, they don't provide a lot of heat (less so on a cloudy day), but it may be enough to enjoy the pool without shivering. I'm not a fan of solar covers, unless you have a crank that allows you to easily cover/uncover the pool. The solar cover on our 27ft pool was so difficult to drag on and off (and keep it clean) that we gave up on it. We also ended up dragging a lot of junk into the pool.
You can ask : Jean Milord
Posted on Sep 10, 2015
Pipe boosted are anyone get the same troub
all the warranties are based on the PROPER MAINTENANCE OF WATER CHEMISTRY. if you cannot prove that the water was balanced properly, you will not have a good time passing this through warranty. a severely unbalanced pool can experience this type of failure very quickly.
Aug 18, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Make Your Pool Green!
Energy Efficiency <i>Make Your Pool Green!</i><br /> Pool owners LOVE green pools. Crazy statement if the "green" you're thinking about is unclean, algae-filled water. But when "green" means eco-friendly, a "green" pool is something homeowners should aspire to have in their yards.<br /> Energy Efficiency - Why? Why should I build or upgrade to an energy efficient pool?<br /> <ul> <li><b>1) Reduce Costs:</b> You'll save money. Energy-efficient pool appliances always pay for themselves in reduced electric bills, and then continue to save money for years to come. By choosing pool equipment such a variable speed pump or pool cover, and by establishing good habits like lowering the pool heater when not in use and proper preventative maintenance, costs to a pool owner can be greatly decreased.</li><br /> <li><b>2) Cuts down on energy waste and saves water:</b> Almost all of a pool's heat loss-about 95 percent-occurs at the surface, mostly through evaporation to the air and radiation to the sky. By using a pool cover to prevent heat and water loss, the amount of chemical water treatment will also be reduced. A multispeed or energy efficient pool pump can also significantly reduce the power consumption of a swimming pool by over 65%.</li><br /> <li><b>3) Tax incentives and rebates:</b> Did you know that some states offer tax incentives and rebates for homeowners that purchase energy efficient pool appliances? Check to see what incentives or rebates are available in your state..</li><br /></ul> Energy Efficiency - How? With a combination of pool products and good preventative maintenance habits, you can improve the heating and energy efficiency of your swimming pool.<br /> <ul> <li><i>Pump Efficiency-</i> You can save energy and maintain a comfortable swimming pool temperature by using a smaller, higher efficiency pump and by operating it less. On average, an energy efficient pump will use 30-45% less energy than that of a standard pump. The difference over a season can be immense. Pumps now come in two-speed, four-speed, and variable-speed models, so you can turn the speed down for regular daily use saving a lot of energy, and use higher settings for more thorough, less frequent cleanings. New energy-efficient pumps also move the water more efficiently for further savings. Since pumps circulate the water to keep it clean, the better they work, the less a filter has to work. <ul> <li>The <a href="">Pentair IntelliFlo&reg;</a> High Performance Pump is the world's smartest swimming pool pump. Its onboard computer and intelligent software automatically calculate and program the minimum flow requirements for every pool task - filtering, heating, cleaning, spa jets, water features and more - to optimize performance and minimize energy use. As functions/tasks change, IntelliFlo&reg; self-adjusts to maintain optimal flow rates for further energy savings.</li><br /> <li>With the <a href="">Hayward EcoStar</a> family of pumps, money flows back into your pocket. EcoStar is the industry's most energy efficient variable speed pump, thanks to a super-efficient permanent magnet, totally enclosed fan cooled (TEFC) motor and industry leading hydraulic design. Tests prove that EcoStar can save you up to 90% on energy costs compared to ordinary single speed pumps. EcoStar matches pump flow to a pool's needs, versus running at full power 100% of the time. It's fully programmable with a self-contained 24-hour clock and up to 8 custom speed and timer functions that allow EcoStar to manage flow throughout the day. Whether used in new construction or aftermarket applications, EcoStar is the perfect choice.</li><br /> <li>Pentair has a calculator that you can use to <a href="">calculate your energy savings</a> using an energy efficient pool pump.</li><br /></ul></li> <li><i>Pool Covers-</i> A good pool cover will save energy and water. It can keep the water in your pool an average of 10 degrees warmer, which can cut summertime pool heating costs by up to 90 percent. A cover reduces water and chemical evaporation by up to 70 percent, saving nearly a thousand gallons of water per month. A cover also helps keep your pool clean, which means you'll have to run your filter pump less often, saving even more energy.</li><br /> <li><i>Water temperature efficiency-</i> In addition to a pool cover, there are other ways to help keep the cost of heating your pool to a minimum while you still enjoy a comfortable water temperature. Make use of solar energy by locating your pool in the sunniest part of your yard. If possible, screen it from the cooling, prevailing wind with existing structures such as the house or garage, or add a solidly built fence as a windbreak. The water temperature you desire for your swimming pool not only affects the size of the pool's heater, but also your heating costs if use a gas or heat pump pool heater. Heating your pool with solar energy is by far the most energy-efficient method. If you buy a gas or electric heater, check the yellow-and-black Energy Guide label on the appliance. It shows relative energy-efficiency according to tests by the US Federal Trade Commission (FTC). Pool water temperatures typically range from 78&ordm;F to 82&ordm;F. The energy consumption for each degree rise in temperature will cost 10%-30% more in energy costs, depending on your location. In warmer climates, this percentage is higher because of the relatively low cost of heating a pool at 78&ordm;F.</li><br /> <li><i>Timers-</i> Buy automatic timers for both your pool heater and pump. This will allow you to run them in several short cycles during the day, which is more effective than running them once continuously for several hours a day.</li><br /> <li><i>Preventative Maintenance-</i> Maintain efficient daily operations. Turn down the pool heater when the pool is not in use and maintain appropriate water temperatures when in use (78&deg;-80&deg; for active swimming, 82&deg;-84&deg; for recreational use). Raising the water temperature just 1&deg;F can costs an additional 10 - 30%, depending on your location. Keep a thermometer in the pool to help determine the temperature that is best for your pool and mark the "comfort settings" on the thermostat dial to avoid accidental overheating. Backwash the pool filter only as much as necessary to avoid wasting water and energy and be sure to keep drain systems clear to allow the free flow of water. By far, the most energy efficient lights you can get for the pool are LED or solar powered.</li><br /></ul> Energy Efficiency - Not just for pools! It is also possible to make your spa energy efficient. Portable spas are more energy efficient than in-the-ground spas because they are better insulated and usually have covers. If you have a typical portable spa, your heater will heat water 10 degrees in about 8 hours. If you use your spa once a week, lowering the temperature 3 degrees when not in use will save you approximately 5-10% of your spa heating costs; if you use the spa less often, your savings could be even greater. Don't run the jets unless you are using your spa. The mixture of water and air is great for relaxing the muscles, but it cools the water quickly. Spa covers are important. Be sure to leave the cover on until you are ready to use your spa and replace when you're finished. Remember that the heat that escapes is the heat you must pay to replace.
on Mar 17, 2011 | Pool & Spa
Hayward H series propane pool heater, how do I convert to gas?.
I used to be able to get it through my supplier but the link is now dead and shows product not available. I am sure you can get this through Hayward direct. The last kit I bought was around $200 (my cost, not retail). As for a used kit, I seriously doubt that is an option.
Aug 09, 2014 | Hayward H Series Pool & Spa Heater 200k...
Can you bypass the heater so pool can prime
The pool return pipes are connected to the heater with pipe unions. You could get a set of unions to match them and make a "U" shaped pipe section to bypass the heater. using a couple of 90's and the unions .
May 31, 2010 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Hayward pool heater H100ID keeps blowing GFI
First, I don't see any heaters in my parts wired thru a GFCI. Why did you resolder inputs on board. Usually, those are not repairs that are acceptable. If the pins have shorted, then you need to replace the board. Could be a problem with the ignitor, but this might be one that you will need to call a pro in for. Did you install the heater yourself???
May 19, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Leak in heater after winter freeze
Yes you can just be sure to leave enough room to plumb it back in when your ready.
May 01, 2010 | Teledyne Laars Laars Lite2 Heater 400000...
Expected life time of Sta-Rite heater?
Thank you for posting your question here on
Overall heater life is often dictated more by the pool maintenance history and chemical usage than location. Generally speaking up here in the Midwest you can expect 12 - 15 years of service life from a heater. More if it gets pampered with such treatment as proper winter covering and regular cleaning and maintenance. Far less if chemical issues arise in a pool and are not dealt with properly. A heater can fail in a matter of weeks if water conditions are that poor.
So, to answer your question; with proper installation, maintenance and water treatment I’d put it at 15 – 18 years before the heater will have spent itself from wear.
If this answer does not fix your problem or you are not sure about part or all of this post, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
Mar 23, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Hayward navigator (Gunnite pool) does not move. If I hold by hose, in water, suspended above bottom, the unit does not turn. Hose in good shape , valves in correct position. previous to this it was...
you need to install a turbine kit with "a" frames. sounds like your bearings are bad either on the turbine, "a " frames, or both. A set of shoes would be a good idea as well.
Nov 18, 2009 | Hayward Navigator Pool Cleaner
Old pool/spa heater
Most parts are not avalible. $3600 is a good investment on a house you are selling. If the pool/spa is in good shape the heater would be a plus and a tax break. We bought our house because of all new appliances.
Jan 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
1,122 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
