Question about Hydrofarm Hydrorfarm Flco200d Fluorescent Grow Light System 200w Daylight
How to get the right lamp?
What is the right lamp for me?
    President:
  • 2,712 Answers
It depends on your budget. HPS lamps are by far the best overall, but they are also the most costly to purchase and setup (although some less honest growers have a tendency to steal them from college campuses and the like). However, they are the cheapest to operate, and the utility savings does eventually add up.
Posted on Aug 27, 2008
What fuse is it for the tail light in the fuse box on a 2003 Buick Regal
TAIL LAMPS, LIC LAMPS
15 AMP
PANEL DIMMING Fuse, Radio, Headlamp Switch, Instrument Cluster, Heater-A/C Control (CJ3), LR and RR Marker Lamp, LH and RH Tail/Stop/Turn Signal Lamp, LR and RR Park Lamps, Rear License Lamps
Instrument panel fuse box ,location
Fuse Block-I/P
Right side of the I/P, in the right front door opening
Dec 04, 2017 | Buick Cars & Trucks
08 Buick lucerne cxl. Third brake light works as well as front signal lights. No rear brake lights or turn signals. Tail lights and headlights and third brake lights works. Bulbs good. Help
Stop Lamps
The brake pedal position sensor is used to sense the action of the driver application of the brake pedal. The body control module (BCM) provides a 5-volt reference voltage and low reference to the brake pedal position sensor. The position sensor provides an analog voltage signal back to the BCM that will increase as the brake pedal is applied. When the brake is applied, the BCM will then apply battery voltage to the left and right stop/turn signal lamp supply voltage circuits and the center high mounted stop lamp (CHMSL) supply voltage circuit illuminating the stop lamps. At the same time the BCM applies battery voltage through the signal circuit to the transmission control module (TCM) and the engine control module (ECM) indicating that the brakes are applied.
Ground for the stop lamps is supplied as follows:
• G402 provides ground for the left rear stop/tail/turn signal lamps
• G403 provides ground for the right rear stop/tail/turn signal lamps
• G301 provides ground for the CHMSL
The stop lamps on this vehicle will not illuminate unless the ignition is in the accessory, run, or crank positions. When the ignition is in the OFF position the stop lamps will not illuminate when the brake pedal is applied.
Battery voltage from the LT TRN/SIG and RT TRN/SIG fuses located in the rear fuse block is also used by the body control module (BCM) for stop lamp operation.
Turn Signal Lamps
Battery voltage supplied to the body control module (BCM) from the fuses listed below is used for turn signal and hazard lamp operation.
• LT TRN/SIG fuse for the left turn signals
• CTSY/RF TRN fuse for the right front turn signal
• RR TRN/SIG fuse for the right rear turn signal
When the turn signal switch is place in either the LEFT or RIGHT position, ground from G300 is applied through the turn signal switch signal circuit to the BCM indicating the turn signal request. In response to this signal, the BCM applies a pulsating voltage to the front and rear turn signal lamps supply voltage circuits cycling the lamps ON and OFF. At the same time the BCM sends a GMLAN serial data message to the instrument panel cluster (IPC) to cycle the appropriate turn signal indicator ON and OFF.
Ground for the turn signal lamps is supplied as follows:
• G104 provides ground for the left and right front turn signal lamps
Do you have a factory scan tool (tech2) ? Your best bet , take it to the dealer .
Sep 08, 2017 | Buick Cars & Trucks
How can I fix the back lights on my 2002 jeep grand cheroke Laredo.
I assume "back lights" refers to the rear lamps and that "light fixture" refers to the entire right rear lamp assembly. There is a combination flasher in the junction block that controls flashing of the turn signals and the hazard function. The multi-function switch (on steering column?)selects left and right turn signals and the hazard operation. If the left side tail/stop lamp and turn lamp are OK, compare the lamp installation on the left rear with the lamp installation on your new right rear lamp assembly. If all checks out, turn on the park lamps and check the BLK/YEL wire for 12 volts to the tail light filament of the combination lamp. Next, turn the ignition switch on but do not start. Set the turn signal switch (MFS) for a right turn. Check the BRN/RED wire for 12 volts to flash the separate turn lamp. Finally, have someone step on the foot brake and check the WHT/TAN wire for 12 volts to the stop light filament of the combination lamp. If any voltage is missing, the trouble may be in the combination switch, the multi-function switch, or due to a missing ground connection (BLK wire) to the right rear lamp assembly.
Sep 09, 2012 | Jeep 2002 Grand Cherokee LAREDO
Projector does not stay on more that 10 minutes. Some said it could be the bulb or lamp.
hi,
Its because you projectors lamp have to replaced. It is notifying that you have to replace the lamp. if you wish to use the same lamp then you have to reset the lamp hour timer. it is recommended that you have to reset the lamp hour only after replacing the lamp. do the following for reset you projectors lamp hour.
(1) Press the MENU button to display a menu.
(2) Point at the ADVANCED MENU in the menu using
the up arrow/down arrow button, then press the right arrow button.
(3) Point at the OPTION in the left column of the menu
using the up arrow / down arrow button, then press the right arrow button.
(4) Point at the LAMP TIME using the up arrow / down arrow button, then press the right arrowbutton. A dialog will appear.
(5) Press the right arrow button to select "OK" on the dialog. It performs resetting the lamp time.
ok
Apr 29, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
Tv wont stay on . i changed the color wheel and bulb and now it turns on then shuts it self off right away and the lamp light is flashing still
When you changed the lamp did you clean the "lamp temp sensor"? When you removed the lamp housing from its cradle, you can access it from where lamp goes. It can be cleaned with a Q-tip.
Also, there is a little blue safety switch that is located on bottom right of the light engine tray. It MUST be in the DOWN position when the TV back is reattached to TV. You can use tape to hold it in the DOWN position while attaching the back of set.
Also after replacing your lamp did you reset the lamp life?, You can do this by:
1-TV off
2-press mute+1+8+2+Power. This will access factory settings.
3-scroll to "Options". Press right arrow to next menu. scroll to "lamp life" hit right arrow and click reset.
4-power off.
That resets the lamp life hour meter.
Apr 09, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
2001 jaguar s type - Right tail lamp failure message.... I replaced bulbs and fuse and tail lights still don't work but the dual element right break light does illuminate when I press the break also right...
There is a harness that you unplugged for the rear tail lamp. Make sure it is fully pressed and locked. This is always the cause on jags for tail lamp failure.
Dec 14, 2010 | 2001 Jaguar S-Type
I have Mitsubishi WD62525 for the past 5 years. Last week the lamp light came on RED and I replaced it with a newer lamp and the TV still doesn't work. The RED light continues to stay on. Any ideas on what...
check to make sure the lamp cover is pressing the lamp switch in it is at bottom right corner of lamp panel, also make sure lamp is set in properly,another thing to check is the lamp cooling fan panel on right back side,remove and clean filter and replace
Nov 28, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Changed projection lamp. Now Tv does not power on.
hello do you still get a lamp light or a blinking stand by light ? it sounds like the lamp cover is'nt on right or the lamp is'nt in right, remove the lamp and re-install make sure the prongs are on tight also make sure the cover is on right if the t.v. is'nt reading that the cover is in right it wont start up "safty feature"
Apr 01, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Saturn Turn Signal / Dome Light Issues
The interior lamps system consists of 2 main features. Illuminated entry and a battery saver feature that will turn the interior lights off after 20 minutes if they are left On with all doors closed and the ignition Off. The body control module (BCM) controls both of these functions. Battery power is supplied by the BCM through CKT 1732 to the following lamps:
• The dome lamp
• The map lamps
• The rear reading lamps
• The rear dome lamp
• The cargo lamp
• The glove compartment lamp
• The courtesy lamps
• The sunshade lamps
The BCM also controls the ground circuit side of the dome lamp and reading lamps for illuminated entry. The dome lamp and reading lamp will remain on for 20 seconds after the ignition key is removed and the last door is closed. In addition, if the vehicle is equipped with remote keyless entry (RKE), the dome and reading lamps will turn On and stay on for 20 seconds after an UNLOCK signal is received from the keyless entry transmitter.
The reading lamps, dome lamp and map lamps can be turned On at any time by moving the appropriate switch to the On position.
The rear dome lamp is fed battery voltage through CKT 1732 from the BCM, through the liftgate ajar switch, and is grounded through CKT 650 to the rear ground splice pack. The rear dome lamp will turn on when the liftgate is opened. The cargo lamp is fed battery voltage through CKT 1732 from the BCM, through CKT 744 and grounded through the decklid ajar switch.
The courtesy lamps are fed battery power through CKT 1732 and are grounded through CKT 745-- left front, CKT 747--left rear, CKT 748--right rear, CKT 746--right front. These circuits will ground through the door jamb switches. The courtesy lamp will be illuminated when the affected door is opened. For example, when the right rear door is opened, the right rear door courtesy lamp will turn on.
Not a fuse problem , if the BCM had blown fuse other thing's wouldn't be working as well . . Probably wiring or BCM . Using factory diagnostic,s instead of guessing as to what the problem is , is the proper way .
Interior Lamps Diagnosis
Symptom
Procedure
Important: Before proceeding with these diagnostics, check for DTCs. If DTCs are present, complete the associated diagnostics. If the condition still exists, return to this chart.
All of the interior lamps are inoperative when any door is opened.
Chart 1
The dome lamp is inoperative in the ON position, but OK in the door position. The map lamps operate normally.
The dome lamp switch is faulty. Replace the dome lamp switch.
The dome lamp is inoperative in the DOOR position, but is OK in the ON position.
Chart 2
The dome lamp is inoperative in any position and both reading lamps are inoperative.
Disconnect the dome lamp connector (BLK 3-way).
Check for voltage at terminal "C" CKT 1732 ORN wire.
If OK, the dome/map lamp is faulty. If no voltage is present, there is an OPEN in CKT 1732.
Either the right or the left sunshade mirror lamp is inoperative.
Chart 3
Either the right or the left rear reading lamp is inoperative in the ON or the DOOR position.
Chart 4
The rear reading lamp is inoperative in the ON or the DOOR position.
Chart 5
Battery rundown protection is shorted to ground - B1482.
B1482
The left rear reading lamp is inoperative in the ON or the DOOR position.
Chart 6
Dec 12, 2017 | 1998 Saturn SL
Powers off and lamp never comes on (new lamp tested in other ep739)
The lamp might be burn out or you do ot have the computer in the right plug and the right input slected.
Jul 23, 2008 | Optoma EP739 Multimedia Projector
Hydrofarm Hydrorfarm Flco200d Fluorescent Grow Light System 200w Daylight Logo
208 people viewed this question
Top Hydrofarm Garden Experts
Craig Butler
Craig Butler
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
