Question about Hydrofarm Agrosun Dayspot 60w Grow Light Kit
Hid light output?
What is a hid light output?
    Problem Solver:
  • 19 Answers
LIGHT OUTPUT could also refer to the amount of light emitted from a certain source. For example, a brand new HID light bulb will put out a certain number of "lumens" or "Lux", which are two standard measures of light. As the bulb ages, it will slowly start to put out less and less lumens, thus making the light slightly dimmer
. Apps can be downloaded to any android cell phone that use the phones photo-sensor to measure light output so you can test the output of your bulbs and compare them to specs or other light sources. Some professional growers will change out their bulbs after every crop.
Posted on Apr 13, 2016
    Sergeant:
    Champion:
  • 404 Answers
Bigger is best for yield
Posted on Jan 06, 2009
    President:
  • 2,712 Answers
MH lamps are available in 175,200, 400 and 1000 watt sizes. HPS lamps come in 50, 75, 150, 400 and 1000 watt sizes. San Agro comes in 430w only, but it works with a 400w HPS ballast. Each lamp requires its own ballast, which comes with the fixtures that are designed to use these lamps, and are also available separately.
Posted on Aug 27, 2008
Headlights do not work high or low beam all other lights work
Re: Condensation in Sienna Right Headlight.... - Toyota Sienna Forum
www.siennachat.com/.../4606-condensation-sienna-right-headlight.html
Mar 10, 2009 - 15 posts - ‎9 authors Over the years, I was not a frequent visitor to SiennaClub...but when I did visit, it was... in the right, passenger-side xenon HID headlight of my 2004 Sienna...the light has... Check with your dealer and see if they can do anything about it. .... :o The HID bulb is also a PITA to remove because you are working ... Re: 2004 Sienna no brake lights, radio, heater/AC ...
Jan 4, 2013
Thread: HELP: Both Low Beams don't Work
Nov 27, 2011
Thread: 2000 sienna drl and/or headlight issue
May 7, 2010
Automatic Headlight Option: Useful or Not?
Mar 3, 2010
More results from www.siennachat.com
Toyota 2004 Sienna repair: Replacing HID ballast or ...
toyotarepairsemipro.blogspot.com/.../replacing-hid-ballast-or-computer....
May 1, 2010 - Replacing HID ballast or computer control lighting for the Headlight. Just got a ... Up until now, I did not know I had the option of seeing twice as far with Xenon. Also up to ... In the end after buttoning everything up, the light did work fine. .... Howdo you determine if you have a HID or non-HID light? Reply ...
Oct 15, 2015 | 2004 Toyota Sienna
Why wont HID light systems work in my 2005 dodge dakota?
This may help...
www.blindinghid.com/dodge-hid-kits/
Oct 15, 2012 | 2005 Dodge Dakota
Installing HID headlamp on cbz xtreme
Hi i have New CBZ Xtreme recently launched which has 12v/4Ah battery, i would like to install HID kit for my bike. I normally drive in night about 20-25 kms....is it good to go for hid kit for my bike with this type of battery and will it give good output?
Jul 30, 2012 | 2005 Bajaj CT 100
Hi. I want to improve the output of the headlight and considering changing the standard bulb for an uprated output. But what is my best choice? My night riding is needing better illumination ahead and...
Improving the output of the light will only increase the light ahead of you. Having the light spread out wider will require a lense with different angles to spread out the light. If you could find a BOSCH replacement light for your bike, that would be an upgrade other wise, have you considered auxiliary lights? HID lights provide lots of light and the current draw on the electrical system is about 40-50 percent less than that of regular incandecant bulbs. Hope this helps.
Apr 05, 2011 | 2001 Moto Guzzi California 1100 E.V....
I installed a High beam hid kit and read online that they needed a resistor in that year to trick the computer. after installing the kit and the resistors to the high beams pos and neg it still flashes...
I don't know why you would install resistors inline for an HID kit, they should be 'plug and play'-you plug the connector for your halogen lights into the ballast input for the HID kit, then plug in the HID bulb harness/ bulb to the ballast output, install the bulb into the housing-done. Some people have installed relays to the lights because when the HID's 'light off' the use a lot of power until the bulbs warm up, then they actually consume less than a halogen bulb (usually 35 watts HID to 55 or more halogen). I have HID's in a number of cars and don't have relays hooked up on any, just 'plug and play' and I have no issues whatsoever.
Apr 03, 2011 | Dodge Ram Pickup 1500 Cars & Trucks
I have two HID with Normal lights in it ..while in Low beam both the normal lights light up but when i turn on the HID after 5 mins the bike turns of indicating that there is low battery ... i took the...
common problem with hid's... is the installation your having a power drop... nowadays modern bikes are battery operated due to comp.box and dc cdi... if the system detects an amphere drop it will shut down... things you have to checks... battery terminal should be securely tight... check for loose ground lines, negative lines... hid should have its own harness usually comes up with the hid kit... hid positive and negative line should be connected directly to the battery. no alteration, or jumpers should be done... it adds resistance to the wire causing to power drop... secure the hid relay loose relay terminal will result to amphere shortage... MAKE SURE YOU CONNECT YOUR HID POSITIVE AND NEGATIVE LINE TO THE BATTERY TERMINAL... AND NO LINE SHARING... good day!
Nov 22, 2010 | 2008 Yamaha YZF-R15
Hid light not turning on
the part about the lights that won't turn on may be because there is a blown fuse or a broken relay which needs to be changed, the part about the hid lights there may be a short circuit somewhere.
Apr 03, 2009 | 2006 Mitsubishi Galant
HID fog light
check your connections to the relay, sounds like something is breaking down under load
Feb 18, 2009 | 2005 Chevrolet Silverado
HID headlight
Most likely the HID transformer is not producing the correct voltage to properly charge the HID bulb. 12 volts goes into the transformer, but a lot more comes out. The HID needs a lot of volts to run, hence the need for the abovementioned transformer. But, the transformers are REALLY expensive.
Sep 18, 2008 | 2004 Toyota Sienna
Hydrofarm Agrosun Dayspot 60w Grow Light Kit Logo
532 people viewed this question
Top Hydrofarm Garden Experts
Craig Butler
Craig Butler
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
