Question about Hayward Sand Filter System & Tank 21" 1 1/2 Hp
Pump Size How to Calculate
How do I calculate the pump size needed for me?
    President:
  • 2,712 Answers
Pump Size Calculation: Gauging the correct size for your water garden pump will ensure your pond receives the proper water circulation. Unless the pump you buy is already configured with a built-in fountain head, you'll need to calculate how much a pump can handle before you choose a certain size or model. A good rule of thumb is that pumps should be able to pump out about half the pond volume every hour. So a pump that moves 500 gallons per hour would be appropriate for a 1,000 gallon pond. In order to determine the size pump you'll need, you must calculate several key measurements.
Posted on Aug 27, 2008
  • 4 Answers
There are a number of online sites that have free calculators for pond keepers. Just google garden pond calculator. You will have to start with a pond volume calculator, once you know the approximate amount of water your pond holds, then use the other calculators to figure TDH (total dynamic head), friction loss, etc.
Hope this helps
Raincree
Posted on Jan 03, 2009
Head loss is 70m, and discharge is 6.92
l/s .how calculate pump horse power
Posted on May 03, 2010
    Master:
    Sergeant:
  • 447 Answers
It seems as if youve already got the best solutions
Posted on Oct 02, 2011
What size circulating pump will I need to buy for my closed loop infloor heating system for my garage floor that is 30ft by 40ft? The pex tubing is in the S shape,1ft apart and is a 3 zone configuration if that helps.
Truewoman
Posted on Jan 09, 2010
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: how do i calculate pump size how do select pump
Thank you for posting your question here on Fixya.com.
The short answer is based on amount of fluid needed at the delivery point(s) and at what pressure that fluid needs to be at those points. If it is a pool pump the answer changes slightly since a pool is a closed loop system and you are more concerned with the turnover rate of the water in order to keep it clean. Is there a specific application you need help with? If so please add a comment to this post and I'll see what I can do to assist.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowmotor.net. Positive feedback is appreciated once your problem is solved!
Posted on Mar 11, 2011
How do you measure a ball shape
hi Phyllis.
this link will tell you how.
How to Calculate the Volume of Sphere
if you need more help go to this link.
How do you measure ball shape Google Search
Dec 02, 2017 | Cars & Trucks
Wheel size 559x22mm no manual to help calculate
to calculate anything you need to know the dimensions
what is 559 measurement is it the width,diameter,radius,circumference
and the same for the 22
Then what are you trying to calculate
ask the question again with all the details and you may get an answer
Jul 26, 2015 | Sigma Bc 906 Computer
What inline fuse should be used for 12V power supply from vessel to EV-200 ?
First, type-1 is not an hydraulic system. It's electro-mecanic.
The EV-200 needs 2 power supplies. 1 for the calculation unit ( thru the Seatalk OR by a connection in the ACU ) AND a feed for the pilot motor/pump.
The calculator power ( NMEA ) needs only a 5 amp fuse. The 'high' power needs an eventual 25amp fuse. In fact, the power output to the motor is totally protected from overloads and/or shorts. Have those cables between power distribution and ACU thick enough to handle 20amps on his length ( twice the cable distance between battery and Acu is the lengt to calculate with )
Sep 20, 2017 | Boating
How do i calculate pump size how do select pump
Mar 11, 2011 | Hayward Sand Filter System & Tank 21" 1...
Have a 12 lengths mechanical deep well, run by a 3HP US Motor. Wants to change the motor to a 1.5 HP to save on power. Tried this but the motor heats up. I presume I have to change the pulley size and or...
No one can answer that for you without knowing information about the actual installation. In short, you can not lower the horsepower without dropping the load. If reducing the speed of the pump lowers the load enough you could then use a smaller drive motor but the pump will deliver less product as a result. Using a pump curve you should be able to calculate the reduced head from slowing the unit down and the horsepower required at that point of the pump curve. Size the motor accordingly. As a rule though, I doubt you could drop to half the horsepower and still operate the pump on its curve. You may need to put a 2 hp on it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 12, 2010 | Plumbing
What are the average amp hours used per week on the model mcbr415s
HELLO THERE
I WILL SEND YOU A COUPLE OF SHEETS TO CALCULATE THIS OK
  1. Alphasolar: System load sizing worksheet Calculate your average amp-hours per day requirement ... This is your average amp-hour requirement per day that will be used to size your ...alphasolar.com/alpha_solar_089.htm - Cached
Sep 12, 2009 | Refrigerators
How to calculate cable size
This site may help. Plug in all the information about your load requirements and it will figure out wire and breaker size and even how big a conduit you'd need for the run.
Jun 02, 2009 | Texas Instruments TI-84 Plus Calculator
Load calculation and size of wires
A lot of your questions also have distance that need to be factored in. Copper is way better than aluminum. but in large wires it may be too expensive, also some suppliers only carry aluminum in the largest sizes. If you are doing a lot of electrical, then you need to learn "ohms law." Also most appliances have the amp load printed on them on the I.D. label.
Mar 03, 2008 | Carrier 36KCARMS Air Conditioner
Hayward Sand Filter System & Tank 21" 1 1/2 Hp Logo
7,321 people viewed this question
Top Hayward Garden Experts
Craig Butler
Craig Butler
Bill Boyd
Pushkar Singh
Pushkar Singh
Are you a Hayward Garden Expert? Answer questions, earn points and help others
