Question about Raypak BURNER TRAY ASSEMBLY
Heaters types what types of heaters are they?
    Problem Solver:
  • 15 Answers
THERE ALSO ARE SOLAR PANELS,HELI COIL 4' 12'S ,DEPENDING ON YOU'R POOL SURFACE AREA,&WHERE YOU LIVE SHOULD EXTEND YOU'R SWIMMING SEASON BETWEEN 1.5 TO 3 MONTHS,EVEN MORE WITH A COVER! HOPE THIS HELPS.
Posted on Nov 07, 2008
    President:
  • 2,712 Answers
There are gas powerd heaters and there are electrical powerd heaters.
Posted on Aug 27, 2008
What is the best replace the elements and thermostats or just get a new waterheater
Best is to replace anode rod, and leave elements and thermostats alone until they go out. IF you can get the anode out.
http://waterheatertimer.org/Replace-anode-rod.html
Anode rod prevents tank from rusting. Anode rods deplete over time in most situations, and then tank begins to rust. If the anode can be successfully removed, and updated, then tank rusting stops, and you're tank is good for another 10 years.
So answer to question is: Depends if tank is rusty, and if tank is sitting in drip pan to protect home from possible leak.
http://waterheatertimer.org/Leaking-water-heater.html
Tank-type electric heater is unique since it can last almost indefinitely, with maintenance. Therefore maintaining tank-type electric water heater can pay you $5-10 per month.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Ordinary electric tank type can outlast all other water heaters, and be far simpler to fix yourself than any other type heater: including gas tank-type, electric hybrid tank-type, electric-and-gas tankless etc. More complicated heaters will eventually fail, and the lifespan is limited. Which is argument against buying expensive water heaters that are controlled by computer chip etc. Avoid tankless promotion. Tankless cost more..Period.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
May 01, 2013 | Water Heaters
High temperature thermal cut-out has tripped
Type, model, brand, age of water heater, and general installation of water heater are unknown.
1) Electric tank-type water heater: replace thermostats and test elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) Gas tank-type: replace gas control valve, clean air intake screen/ location varies by brand:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Tankless: call service technician, or replace tankless with tank-type and save money long-term.
4) Add comment and describe water heater using label located on side of unit, and include what you are doing to 'reset' the thermal cut-out.
Jan 04, 2013 | Water Heaters
Pilot light is lit but won't turn on water heater
What band and type water heater do you have? And about how old is the water heater? Add a comment with more information.
Following general information applies to tank-type residential water heater.
If pilot light is working, then thermocouple is good. Otherwise, if thermocouple was bad, or fallen out of place, then there would be no pilot flame.
Carefully read instructions for lighting water heater located on front of tank ... make sure you have the gas control valve set to ON.
At this point, troubleshoot varies widely depending if your water heater is older and air enters front of heater, or if water heater was made after 2007-9 and has sealed combustion chamber and FV system.'
Troubleshoot also varies widely depending if you have power vent and which type of gas control valve.
Copy following link for troubleshoot by type of gas control valve:
Also post detailed question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 16, 2012 | Whirlpool Water Heaters
Turn on gas water heater
Type of water heater, type of gas control valve, symptoms, approximate age of water heater, location of water heater, information from label on side of water heater, things the technician checked, and technician's suggestions are not known.
Copy following link for general troubleshooting by type of gas control valve:
Some of the service manuals are large files and slow to load.
Jul 27, 2012 | Whirlpool Water Heaters
Red light is flashing on my hot water tank, not producing hot water just today
You have tank-type water heater, but type of water heater and control is not known.
For possible help, add a comment and say if you has gas or electric water heater and describe what type of gas valve or control box is giving the error code.
Open following link to identify some basic types of controls:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Jul 08, 2011 | Reliance Natural Gas Water Heater Control
Electric water heater doesnt heat anymore there is power getting to the water heater.
You posted under electric water heater but don't give type of heater or brand or voltage.
For most types and brands of tank-type electric water heater, open following link for full troubleshoot.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If this is a tankless water heater, or boiler-type, or indirect, or hybrid water heater, then add a comment with brand, type and voltage for possibility of more help.
Add a comment any time.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 02, 2011 | Water Heaters
2002 S type 3.0. The heater not working
Heater control valve faulty,
Air lock/blockage to heater matrix,
control unit voltage sender.
Check the above in this order. I assume you are operating heater control functions correctly and the heater display is showing no unusual infor.?
hope this helps. good luck.
Oct 01, 2009 | 2001 Jaguar S-Type
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
Raypak BURNER TRAY ASSEMBLY Logo
143 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
