Question about Flowtron LE-900 Leaf-Eater Mulcher
Mulchers wearing parts
What are the main wearing parts
    President:
  • 2,712 Answers
Blades have proved to be the main wearing parts. However, they do have a good life expectancy. Blades are made from special material, hardened and heat-treated to a standard which results in a blade that is hard but not brittle.
Posted on Aug 27, 2008
Trying to find replacement parts and manuel and parts list for this wood splitter
g o to youdealer he will sell you a print out for acouple of bucks.
Jan 09, 2016 | Garden
Murray select 22" mulching deck part
from the sounds of what you talking about that part is part of the deck and not servicable
Jun 25, 2012 | Mtd Garden
Broken brass part in gun on power washer
most cases you need to get a new gun assembly
Mar 01, 2012 | Garden
1995 jeep yj 4 cyl manual tran, motor noise, taping, when oil is hot.Changed lifters, still noise, 200.000 km on motor
Two items that are important here.....Did you check the rocker arms for wear and did you check the camshaft to make sure the lobes aren't worn? Also, even a new lifter will not function correctly if the oil pressure in the engine is low. An engine with 200k on it likely has some bearing wear. The oil pump can also wear but generally it won't wear enough to lower the pressure enough to cause lifter noise. If everything in the valvetrain checks out as good, I'd be looking at the bearings. If some are worn (check with plastigage, available at parts stores) replace them and also the pump.
Most times, the rod bearings wear faster than do the mains. You can do rod bearings in the car. If mains are worn, best to do a complete rebuild as cam bearings are likely close behind, and mains should be done out of the car anyhow. (doubt if you will need to go that far though).
Jun 10, 2011 | Jeep Wrangler Cars & Trucks
Looking for a recoil cup for a Troy-bilt chipper vac model 47282 with a tecumseh engine H5065582V. Thanks JR
Tecumseh part #36221 should be the starter cup you are looking for. It is available through www.partstree.com or try your local repair shop. Any shop that handles Tecumseh parts should be able to order it for you.
Dec 01, 2010 | Garden
I need a replacement spinner assembly for an older Flowtron Leaf Eater -- 800, I think. Any suggestions?
Go to www.flowtron.com. There you can find the parts you are looking for like ler-500 spinner assembly for $20.95.
Good Day.
Nov 18, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
Need replacement starter button assembly for HM20P5E Homelite Mulcher. What is part number and where best obtained?
http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF&app=HML531&session=93b2e278-e26b-4f78-a46a-4d23cdcffc43&cat=3&TF=epcFrame&assem=4570&highlightNode=No&selAssem=6491&mdDescrip=HM20P5E%2020%22%20Mulcher%20Walk%20Behind%20Mower%20UT-30160
Appears to be part number JA991228
Oct 23, 2009 | Garden
Oil Changed, New spark plug & filter. No start. Pull cord and makes starting noise then off.
Sounds like contaminated or stale fuel OR dirt/moisture in the carburetor. Remove the float bowl from the carburetor, clean it out, use some carburetor spray cleaner to clean the main jet in the carburetor and reasssemble
Sep 12, 2009 | Garden
What is the Craftsman model number?
The model number is usually under the seat, or on the platform the seat mounts to or on the main frame below the seat area. It will be a number with this format 917.xxxxxx the x's being 6 numbers 0 thru 9. It will be an adhesive sticker with those numbers as well as date codes etc. They are not stamped into the frame anywhere
Sep 08, 2009 | Craftsman Garden
Mulchers storage
when its empty you can store anywhere you like but when its full try and keep in open place due to smell that may burst from the mulcher.
Aug 27, 2008 | Flowtron LE-900 Leaf-Eater Mulcher
Flowtron LE-900 Leaf-Eater Mulcher Logo
224 people viewed this question
Top Flowtron Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
Are you a Flowtron Garden Expert? Answer questions, earn points and help others
