Question about Ariens 34 In. Zoom Series Riding Mower
Cutting size question
What cutting size should I use?
I owned and operated a lawn co for 10 yrs I only used a 48" deck with 19hp engine i found this deck size was the most versitile for any and all conditions unless the yard was over 2 acres then I would use 56" deck 48 " manicured the best and never had to worry about scalping or rubbing when in ditch or going around beds if I was to start up another buisness again I would have a 48" 56" and a standard 22" push mower for all my work Darren
Posted on Mar 11, 2009
  • 2,712 Answers
* f your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Posted on Aug 27, 2008
Cutter not working
Hi Jackie, I'm Julie, what brand and model of sewing machine are you using, please?
Aug 05, 2015 | Sewing Machines
Hi there mower works well in top gears but not cutting properly in lower gears
the belt is slipping .wrong size or you need to adj the idler
Jan 05, 2015 | Garden
Broken head bolt
1..Asertain the size of the bolt.
2. down to the hardware/tool suppliers & get a drill bit & a reverse tap.
for that size bolt +tube of cutting paste.
3use a sharp nail & very gently tap the centre of the bolt - this will stop the bit from wavering - dip the bit into the cutting paste & gently drill at least deep enough to give reverse bit enough bite.
4.insert the r/bit into a handle that comes with it - insert into the c/paste & very gently tap it - turning to the left till u feel it lock - continue it the bolt turns out.
TOOLS;drill,nail,hammer,bit & reverse bit .cutting paste.
Jan 15, 2014 | kawasaki Motorcycles
I borrowed my friend's Dremel to cut a few screws...originally she had the EZ Lock Cutting Wheel but it is too big so the smallest they make is not with the EZ Lock head so I was told to get Dremel 420...
I don't know what the numbers are, but the little abrasive cut-off wheels are held on with a mandrel type bit and a screw. Make sure you get the right size wheel and the right size mandrel, they make a couple different sizes, you can't fit the small wheels on the bigger screw. Anyway, I use my cut-off wheels all the time, usually to get stubborn screws out by cutting a slot in the head and turning it out with a flat blade screw driver. The wheels will cut anything, most people scoff when I say that, but it is true, they will cut anything.
Jul 15, 2011 | Dremel Garden
How to lower the blade it's not cutting all the way thru..stand. 12 inch please
a temp fix,put a thin rubber mat under your bridge saw does plunge cuts & has a knob on side of cutting head, your blade must have been changed somewhere even if changed with the same size blade some vary in overall size,good luck
Nov 05, 2010 | Qep Tile Tools 83200 24inch Bridge Saw
Printing Legal size brochure (landscape) that gets cut off
readjust the margins in the printer page set up just before printing
Sep 08, 2017 | HP Inkjet 1200D Printer
The cricut does not cut through the paper, it only scores it enough to see the outline of the image to be cut. I have checked on line and the blade housing is installed correctly. Does the cutter have a...
Yes, there are three rollers that one adjusts your size of the image you are cutting that is on the right hand side of the machine. The other two are on the left side of the machine. The top one is your speed control and the bottom is your pressure. I would move it up to medium when cutting with cardstock or even up to high if it is thick cardstock. Hope this helps, any further questions feel free to ask me.
Dec 30, 2009 | Provo Craft Cricut Disney Font Cartridge
Hand jig saw stops cutting - makes whirring noise - then restarts
Jig saws are not made to cut through aluiminum espescially that size. That is really thick and it sounds like you have worn out the motor trying to cut it. If the saws are hot. Let them cool down then proceed but like I metioned before you are putting a lot of stress on something not made to cut aluminum even with a metal cutting blade
May 21, 2009 | Saws
Ariens 34 In. Zoom Series Riding Mower Logo
301 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
