Question about Olympus Camedia C-2100 Ultra Zoom Digital Camera
Having problems with the flash\ blurred and grainy images
I'm trying to take indoor action shots in a gym (not the greatest lighting so I need to use the flash) with the 2100. I'm having two problems. 1. There is about a 10 sec. delay for the flash to recharge before I can take another shot, is this normal of digital cameras? 2. The shots I am getting are blurred (arms and legs) and grainy images. I have tried the s-prog in action mode and the s mode where you can adjust the shutter speed. If I up the shutter speed the pictures are dark.
    Master:
  • 852 Answers
I haven't seen this with mine, it usually takes about 4 seconds. As the batteries drain it does take longer. I haven't tried this with the 2100 but on some other cameras I've had it does take longer if you use the flash repeatedly. Try manually setting the ISO to 400. I don't know about S-Prg but in S mode the ISO is automaticly set to 100 if you were in auto ISO before. So I would switch to S mode, set the ISO to 400, and use the fastest shutter speed you can, even if you have to under expose a little to freeze the action. You can adjust the brightness or gamma later with software. I can't comment on the grainy, the CCD in my 2100 seems to have much less thermal noise than others. Also remember as you zoom your minimum F-Stop increases, so you get less light into the camera the more you zoom.
Posted on Sep 07, 2005
    Master:
  • 852 Answers
You should not use the flash for these shots (unless you connect a powerful external flash), it won't help you at this distance. You should use the shutter priority mode and experiment with shutter speed (no flash) to get the best result - for sports action it should probably be faster than 1/100 sec. If the light is too low you may use higher ISO setting - 200 or 400 (though higher ISO will result in grainier images, it may be your only option for blur-free photos).
SOURCE:
Pictures are blurry
There are a few things to consider:
-- Are your hands steady as you take the shot, and are you moving the camera before the shutter actually clicks? As a test, put the camera down on a table top and take a picture without moving the camera until well after the shutter clicks. If the resulting image is not blurry--you just proved that your holding technique needs improvement!
--This camera has image stabilization to help you deal with camera shake--do you have this feature turned on in the menu?
--If your subjects are moving and your shutter speed is slow (meaning that the shutter stays open a relatively long time to gather enough light) then you will get blur. And, even if your subject is not moving but the shutter speed is slow, then your camera shake will come back to haunt you.
To fix slow shutter speed, you can either use a flash to freeze the action, or you can manually increase the ISO setting to a higher number, or you can choose a preset like "sports" which will tell the camera you want faster shutter speeds. A higher ISO setting will allow for faster shutter speeds, but it can also result in a grainy look, called "noise" if you set it too high.
Most likely it is your holding technique and the setting you are choosing that is causing the blur. If you are in decently bright light outdoors, you hold your camera steady and wait for the shutter to click, and you have image stabilization on, then you should have sharp pictures. If you are indoors, expect to need a flash.
Nov 25, 2010 | Canon PowerShot SX100 IS Digital Camera
I have the fuji s1000fd and i need to take some indoor basketball photos today what should i set the camera on ? Most of my pix are very yellow.
You need to set the white balance for the kind of light in the gym. Take a few test shots while changing the white balance each time until you're happy with the color. For indoor shots, set your ISO to at least 800 and turn off the flash unless you're 10-12 feet from the action. If the camera has some sort of shake reduction, turn it on.
Mar 13, 2010 | Fuji FinePix S1000FD Digital Camera
What is the best setting for taking indoor action shots? My shots always turn out fuzzy and dark
There is no good solution for this. There's only a limited amount of light indoors.
First, you need the widest aperture you can get on your lens. You can get this by going to the Aperture-priority (A) mode.
Even so, you're shutter speed will most likely be too slow to freeze the action. You can combat this somewhat by raising the ISO. This will increase the noise, but I'd prefer a noisy picture to a blurry picture.
That still probably won't get you great pictures. Since you probably can't rig more floodlights in the gym, you'll be limited to using your flash if the action is taking place close enough to you (and if flash is permitted).
You can gain an additional stop or two with faster lenses, but such lenses can cost more than $2000. Unless _Sports Illustrated_ is paying for your pictures, that's probably not an option at this time.
I realize this doesn't really solve your problem. Unfortunately, as I stated up front, there is no good solution.
Jan 29, 2010 | Sony Alpha DSLR-A100 Digital Camera
Olympus D 555 Blurred action shots
Indoor actions in low-to-moderate light are very difficult. This is why professional photographers pay thousands for DSLRs with high quality high-ISO settings, and thousands more for big and heavy lenses that can shoot with a large aperture (small f-stop number) to get the most light into the lens and onto the sensor.
Your Olympus D-555 only goes to ISO 400, which is not suitable for indoor action shots, and the lens is f/3 to f/5 which is not a fast lens. What you are trying to do is simply not possible with this camera. You need good quality at ISO 1600 (or higher) and f/2.8 or faster for the lens. This will give you 8 to 16 times as much light gathering capability in low light situations, letting you use a much faster shutter to capture action shots in low light.
Dec 30, 2008 | Olympus ImageLink D-555 Zoom Digital...
Shutter Speed too slow on indoor sports for Nikon D60
Maybe. Assuming you can't add more light, you can either increase the ISO and/or open up the aperture. Try going to A (Aperture) mode and opening up the lens all the way. This will give you the fastest shutter speed possible under the conditions. That may or may not be fast enough.
Nov 02, 2008 | Nikon D40x Digital Camera
D60 Shutter Speed
Yes. The question is how good they'll turn out.
You're right that it's because it's darker indoors. You can compensate for this at least in part by raising the ISO. This runs the risk of increased noise, but given the choice between a noisy pic and no pic...
A fast lens may get you a stop or two, but they're expen$ive.
A third option is to increase the amount of light. Multiple flashes around the basket, for example. Or floodlights mounted on the roof...
Oct 29, 2008 | Nikon D40x Digital Camera
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Blurred images with no flash
First, try to get more light, particularly natural light (window); second, try using shutter priority (S mode), setting the shutter speed at not less than 1/50, faster if you are shooting motion/action (check the Properties of the blurred pictures that you've been getting in Camedia software - the shutter speeds are probably too slow because of the low light), and experiment with higher ISO settings (either 200 or Auto, not 400) though there's a trade-off in noise levels.
Sep 11, 2005 | Olympus Camedia C-3020 Zoom Digital Camera
S2 Pro User Questions-Focus Issue
With the camera you have, noise isn't much of an issue when pushing the ISO to 400, 800 or even 1600. Try setting at ISO 400 and change it to manual mode or shutter priority and then choose a faster shutter speed. Take some test shots. If it's still blurred, increase the shutter speed and ISO to 800 and try again.
Sep 04, 2005 | Fuji FinePix S2 Pro Digital Camera
Olympus Camedia C-2100 Ultra Zoom Digital Camera Logo
108 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
