Question about Mantis Electric Mini Tiller/Cultivator
Crt or srt tiller?
Should I use crt or srt tiller?
    President:
  • 2,712 Answers
* CRT or SRT -- These are two terms you will see on rear-tine tillers only. o Counter Rotating Tines are best for heavier duty jobs and for breaking new ground. o Standard Rotating Tines are good for aerating the soil and help propel the tiller forward.
Posted on Aug 27, 2008
How to cancel the time limit
Disable ?conomie mode or srt factory default or disabe standby timer
Jan 12, 2016 | Televison & Video
What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
go to troy blit and input model number, this will tell you what you need to know
Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
Husqvarna CRT 650 Tiller gearbox is locked up
first check the linkage rods make sure that its not in forward and reverse at the same time if not you need to open it up to find the problem
Jul 25, 2012 | Garden
RALLYS 17 CRT 5HP ROTOTILLER MANUAL
What kind of spark plug is needed for a rally 17 CRT tiller?
Feb 29, 2012 | Yard Machines Garden
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
Aug 14, 2010 | LG 42LE5500 42 in. TV
Engine runs backwards?
Starter clutch needs to be cleaned or replaced. What is the model # and type # on the engine
May 17, 2009 | Husqvarna Garden
I just purchased a troy bilt bronco crt tiller. Put oil and gasoline in. Pulled the cord. It started. Ran maybe 15 or 20 seconds and stopped. When I tried to start it again, the cord would not...
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Mar 29, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
I need a remote control for Sylvania TVRemote Model No SRT 2220F Year 2002
Thank you:
We found a universal remote at BestBuy.
caldwell
Mar 21, 2009 | Sylvania SRT2232S 32" TV
Mantis Electric Mini Tiller/Cultivator Logo
321 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
